1 |
.\" RCSid $Id: wrapBSDF.1,v 1.5 2016/02/02 22:34:00 greg Exp $ |
2 |
.TH WRAPBSDF 1 2/20/2015 RADIANCE |
3 |
.SH NAME |
4 |
wrapBSDF - put XML wrapper around WINDOW6 BSDF data |
5 |
.SH SYNOPSIS |
6 |
.B wrapBSDF |
7 |
8 |
.B \-W |
9 |
10 |
.B \-c |
11 |
12 |
.B "\-a {kf|kh|kq|t3|t4}" |
13 |
14 |
.B "\-u unit" |
15 |
16 |
.B "\-g geom.mgf" |
17 |
18 |
.B "\-f 'x=string;y=string'" |
19 |
20 |
.B "\-s spectr" |
21 |
22 |
.B "\-tb inp" |
23 |
24 |
.B "\-tf inp" |
25 |
26 |
.B "\-rb inp" |
27 |
28 |
.B "\-rf inp" |
29 |
30 |
.B \-U |
31 |
32 |
.B "\-C comm" |
33 |
34 |
.B "input.xml" |
35 |
36 |
.SH DESCRIPTION |
37 |
.I WrapBSDF |
38 |
takes ASCII matrix or tensor tree data given in one or more |
39 |
.I "\-tf, \-tb, \-rf," |
40 |
and |
41 |
.I \-rb |
42 |
options and adds them to the given |
43 |
.I input.xml |
44 |
file or to a standard template suitable for |
45 |
.I Radiance |
46 |
and |
47 |
.I WINDOW6. |
48 |
The |
49 |
.I \-W |
50 |
option may be given to ensure adherence to the |
51 |
.I WINDOW6 |
52 |
requirements, which draws from a standard template |
53 |
and warns the user if the required additional fields are not |
54 |
provided. |
55 |
.PP |
56 |
Fields may be set by one or more |
57 |
.I \-f |
58 |
options, which take pairs of XML tag names and values, such as |
59 |
.I "\-f Manufacturer=ACME". |
60 |
A number of shorthand names are provided corresponding to the |
61 |
following tags (asterisk tags are required with -W): |
62 |
.sp |
63 |
.nf |
64 |
m Manufacturer(*) |
65 |
n Name(*) |
66 |
c ThermalConductivity |
67 |
ef EmissivityFront |
68 |
eb EmissivityBack |
69 |
eo EffectiveOpennessFraction |
70 |
t Thickness(*) |
71 |
h Height |
72 |
w Width |
73 |
.fi |
74 |
.PP |
75 |
If any dimensions are given, thier units will correspond to |
76 |
meters by default, or the |
77 |
.I \-u |
78 |
option may be used to specify one of: |
79 |
meter, foot, inch, centimeter, or millimeter. |
80 |
Any other unit specification will result in an error, and |
81 |
only one set of units may be selected. |
82 |
A "Materials and Geometry Format" file may be provided with the |
83 |
.I \-g |
84 |
option, and will also be in the indicated units. |
85 |
.PP |
86 |
The spectrum corresponding to a particular set of data may be given |
87 |
before the data option using a |
88 |
.I \-s |
89 |
specification, whose argument is either the name of a spectral |
90 |
sensitivity file or one of the standard spectra: |
91 |
Visible, Solar, NIR, CIE-u, CIE-v, CIE-X, or CIE-Z. |
92 |
Different spectra may be given for different distribution data, |
93 |
and the default spectrum is Visible (CIE-Y). |
94 |
.PP |
95 |
The |
96 |
.I \-a |
97 |
option specifies the angular sampling basis for all the data |
98 |
provided, and must be set if any data is given. |
99 |
Legal arguments for this option are: |
100 |
.sp |
101 |
.nf |
102 |
kf Klems full sampling (145x145 matrix) |
103 |
kh Klems half sampling (73x73 matrix) |
104 |
kq Klems quarter sampling (41x41 matrix) |
105 |
t3 Tensor tree isotropic sampling |
106 |
t4 Tensor tree anisotropic sampling |
107 |
.fi |
108 |
.sp |
109 |
In the case of Klems data, the |
110 |
.I \-c |
111 |
option may be specified to include a correction for solid |
112 |
angle, which is necessary to convert flux form factors into |
113 |
BSDF data. |
114 |
Since flux factors rather than BSDF values are computed by |
115 |
.I rfluxmtx(1) |
116 |
and similar sources, this is often necessary for proper conversion. |
117 |
.PP |
118 |
Most options that accept file names |
119 |
can take data from the standard input by using a hyphen ('-') |
120 |
in place of the file, but only one option at most may read from stdin. |
121 |
Data input may be read from another program by beginning the input |
122 |
specification with a quoted exclamation point ('!') followed by the command. |
123 |
.PP |
124 |
The |
125 |
.I \-C |
126 |
option may be used to specify a comment to be inserted near the |
127 |
head of the output. |
128 |
Up to 30 comment strings may be given, and they will appear one |
129 |
after the other in the prologue surrounded by the XML comment syntax. |
130 |
.PP |
131 |
The |
132 |
.I \-U |
133 |
option tells |
134 |
.I wrapBSDF |
135 |
to unlink (remove) input data files following successful completion. |
136 |
These files are often temporary, existing solely for the purposes |
137 |
of data transfer. |
138 |
If given as |
139 |
.I \-UU, |
140 |
then the MGF geometry file given by the |
141 |
.I \-g |
142 |
option (if any) will also be unlinked. |
143 |
.SH EXAMPLE |
144 |
Create an WINDOW6 BSDF from computed transmission matrix: |
145 |
.IP "" .2i |
146 |
rfluxmtx -fa ... | wrapBSDF -W -u millimeter -f 't=5;m=3M;n=Trans30' -c -tb - > Trans30.xml |
147 |
.PP |
148 |
Add a name and MGF geometry to an XML file: |
149 |
150 |
.IP "" .2i |
151 |
wrapBSDF -f 'Name=My Device' -g MyDevice.mgf orig.xml > revised.xml |
152 |
.SH AUTHOR |
153 |
Greg Ward |
154 |
.SH "SEE ALSO" |
155 |
bsdf2klems(1), bsdf2ttree(1), genBSDF(1), mgf2rad(1), |
156 |
pkgBSDF(1), rad2mgf(1), rfluxmtx(1) |
