| 1 |
.\" RCSid $Id: wrapBSDF.1,v 1.2 2015/05/20 08:40:48 greg Exp $
| 2 |
.TH WRAPBSDF 1 2/20/2015 RADIANCE
| 3 |
.SH NAME
| 4 |
wrapBSDF - put XML wrapper around WINDOW6 BSDF data
| 5 |
.SH SYNOPSIS
| 6 |
.B wrapBSDF
| 7 |
| 8 |
.B \-W
| 9 |
| 10 |
.B \-c
| 11 |
| 12 |
.B "\-a {kf|kh|kq|t3|t4}"
| 13 |
| 14 |
.B "\-u unit"
| 15 |
| 16 |
.B "\-g geom.mgf"
| 17 |
| 18 |
.B "\-f 'x=string;y=string'"
| 19 |
| 20 |
.B "\-s spectr"
| 21 |
| 22 |
.B "\-tb inp"
| 23 |
| 24 |
.B "\-tf inp"
| 25 |
| 26 |
.B "\-rb inp"
| 27 |
| 28 |
.B "\-rf inp"
| 29 |
| 30 |
.B "\-C comm"
| 31 |
| 32 |
.B "input.xml"
| 33 |
| 34 |
.SH DESCRIPTION
| 35 |
.I WrapBSDF
| 36 |
takes ASCII matrix or tensor tree data given in one or more
| 37 |
.I "\-tf, \-tb, \-rf,"
| 38 |
and
| 39 |
.I \-rb
| 40 |
options and adds them to the given
| 41 |
.I input.xml
| 42 |
file or to a standard template suitable for
| 43 |
.I Radiance
| 44 |
and
| 45 |
.I WINDOW6.
| 46 |
The
| 47 |
.I \-W
| 48 |
option may be given to ensure adherence to the
| 49 |
.I WINDOW6
| 50 |
requirements, which draws from a standard template
| 51 |
and warns the user if the required additional fields are not
| 52 |
provided.
| 53 |
.PP
| 54 |
Fields may be set by one or more
| 55 |
.I \-f
| 56 |
options, which take pairs of XML tag names and values, such as
| 57 |
.I "\-f Manufacturer=ACME".
| 58 |
A number of shorthand names are provided corresponding to the
| 59 |
following tags (asterisk tags are required with -W):
| 60 |
.sp
| 61 |
.nf
| 62 |
m Manufacturer(*)
| 63 |
n Name(*)
| 64 |
c ThermalConductivity
| 65 |
ef EmissivityFront
| 66 |
eb EmissivityBack
| 67 |
eo EffectiveOpennessFraction
| 68 |
t Thickness(*)
| 69 |
h Height
| 70 |
w Width
| 71 |
.fi
| 72 |
.PP
| 73 |
If any dimensions are given, thier units will correspond to
| 74 |
meters by default, or the
| 75 |
.I \-u
| 76 |
option may be used to specify one of:
| 77 |
meter, foot, inch, centimeter, or millimeter.
| 78 |
Any other unit specification will result in an error, and
| 79 |
only one set of units may be selected.
| 80 |
A "Materials and Geometry Format" file may be provided with the
| 81 |
.I \-g
| 82 |
option, and will also be in the indicated units.
| 83 |
.PP
| 84 |
The spectrum corresponding to a particular set of data may be given
| 85 |
before the data option using a
| 86 |
.I \-s
| 87 |
specification, whose argument is either the name of a spectral
| 88 |
sensitivity file or one of the standard spectra:
| 89 |
Visible, Solar, NIR, CIE-u, CIE-v, CIE-X, or CIE-Z.
| 90 |
Different spectra may be given for different distribution data,
| 91 |
and the default spectrum is Visible (CIE-Y).
| 92 |
.PP
| 93 |
The
| 94 |
.I \-a
| 95 |
option specifies the angular sampling basis for all the data
| 96 |
provided, and must be set if any data is given.
| 97 |
Legal arguments for this option are:
| 98 |
.sp
| 99 |
.nf
| 100 |
kf Klems full sampling (145x145 matrix)
| 101 |
kh Klems half sampling (73x73 matrix)
| 102 |
kq Klems quarter sampling (41x41 matrix)
| 103 |
t3 Tensor tree isotropic sampling
| 104 |
t4 Tensor tree anisotropic sampling
| 105 |
.fi
| 106 |
.sp
| 107 |
In the case of Klems data, the
| 108 |
.I \-c
| 109 |
option may be specified to include a correction for solid
| 110 |
angle, which is necessary to convert flux form factors into
| 111 |
BSDF data.
| 112 |
Since it flux factors rather than BSDF values are computed by
| 113 |
.I rfluxmtx(1)
| 114 |
and similar sources, this is often necessary for proper conversion.
| 115 |
.PP
| 116 |
Most options that accept file names
| 117 |
can take data from the standard input by using a hyphen ('-')
| 118 |
in place of the file, but only one option at most may read from stdin.
| 119 |
Data input may be read from another program by beginning the input
| 120 |
specification with a quoted exclamation point ('!') followed by the command.
| 121 |
.PP
| 122 |
The
| 123 |
.I \-C
| 124 |
option may be used to specify a comment to be inserted near the
| 125 |
head of the output.
| 126 |
Up to 30 comment strings may be given, and they will appear one
| 127 |
after the other in the prologue surrounded by the XML comment syntax.
| 128 |
.SH EXAMPLE
| 129 |
Create an WINDOW6 BSDF from computed transmission matrix:
| 130 |
.IP "" .2i
| 131 |
rfluxmtx -fa ... | wrapBSDF -W -u millimeter -f 't=5;m=3M;n=Trans30' -c -tb - > Trans30.xml
| 132 |
.PP
| 133 |
Add a name and MGF geometry to an XML file:
| 134 |
| 135 |
.IP "" .2i
| 136 |
wrapBSDF -f 'Name=My Device' -g MyDevice.mgf orig.xml > revised.xml
| 137 |
.SH AUTHOR
| 138 |
Greg Ward
| 139 |
.SH "SEE ALSO"
| 140 |
bsdf2klems(1), bsdf2ttree(1), genBSDF(1), mgf2rad(1),
| 141 |
pkgBSDF(1), rad2mgf(1), rfluxmtx(1)
