root/radiance/ray/doc/man/man1/vwright.1
Revision: 1.6
Committed: Tue Mar 11 02:21:46 2008 UTC (16 years, 2 months ago) by greg
1 .\" RCSid "$Id: vwright.1,v 1.5 2007/09/04 17:36:41 greg Exp $"
2 .TH VWRIGHT 1 8/29/96 RADIANCE
3 .SH NAME
4 vwright - normalize a RADIANCE view, shift it to the right
5 .SH SYNOPSIS
6 .B vwright
7 .B distance
8 .br
9 .B vwright
10 .B name
11 .SH DESCRIPTION
12 .I Vwright
13 shifts a RADIANCE view from a picture or view file given on the standard input
14 the specified distance to the right, putting out a complete set of
15 view parameters in a single line on the standard output.
16 This utility is most often used to compute a right-eyed view from
17 a left-eye view for stereo imaging.
18 .PP
19 The
20 .I distance
21 given is in world coordinate units.
22 A negative value indicates a shift to the left rather than the
23 right.
24 .PP
25 The second form substitutes a name prefix in place of the shift
26 distance, and produces constant assignments on the standard output
27 suitable for passing directly to
28 .I rcalc(1).
29 For a given prefix
30 .I N,
31 the constant names are as follows:
32 .sp
33 .nf
34 Nt: view type ('v'==1,'l'==2,'a'==3,'h'==4,'c'==5,'s'==6)
35 Npx: view point x value
36 Npy: view point y value
37 Npz: view point z value
38 Ndx: view direction x value (normalized)
39 Ndy: view direction y value (normalized)
40 Ndz: view direction z value (normalized)
41 Nd: view focal distance
42 Nux: view up vector x value (normalized)
43 Nuy: view up vector y value (normalized)
44 Nuz: view up vector z value (normalized)
45 Nh: view horizontal size
46 Nv: view vertical size
47 Ns: view shift
48 Nl: view lift
49 No: view fore clipping distance
50 Na: view aft clipping distance
51 Nhx: derived horizontal image vector x value (normalized)
52 Nhy: derived horizontal image vector y value (normalized)
53 Nhz: derived horizontal image vector z value (normalized)
54 Nhn: derived horizontal image vector multiplier
55 Nvx: derived vertical image vector x value (normalized)
56 Nvy: derived vertical image vector y value (normalized)
57 Nvz: derived vertical image vector z value (normalized)
58 Nvn: derived vertical image vector multiplier
59 .fi
60 .SH EXAMPLES
61 To start
62 .I rpict(1)
63 on a view .06 meters left of the view in the file "right.vf":
64 .IP "" .2i
65 rpict `vwright -.06 < right.vf` scene.oct > right.pic &
66 .PP
67 To move the
68 .I rad(1)
69 view named "left" 2.5 inches to the right
70 and render from there:
71 .IP "" .2i
72 rad \-v "right `rad \-n \-s \-V \-v left examp.rif | vwright 2.5`" examp.rif &
73 .PP
74 To pass a view to
75 .I rcalc
76 for conversion to some other view:
77 .IP "" .2i
78 rcalc \-n \-e `vwright orig < orig.vf` \-f viewmod.cal \-o view.fmt > new.vf
79 .SH AUTHOR
80 Greg Ward
81 .SH "SEE ALSO"
82 pdfblur(1), rad(1), rcalc(1), rpict(1), rvu(1)
