root/radiance/ray/doc/man/man1/vwright.1
Revision: 1.8
Committed: Sun Jun 14 00:33:15 2009 UTC (16 years ago) by greg
Changes since 1.7: +7 -2 lines
1 .\" RCSid "$Id: vwright.1,v 1.7 2008/11/10 19:08:17 greg Exp $"
2 .TH VWRIGHT 1 8/29/96 RADIANCE
3 .SH NAME
4 vwright - normalize a RADIANCE view, shift it to the right
5 .SH SYNOPSIS
6 .B vwright
7 .B "[ view options ]"
8 .B distance
9 .br
10 .B vwright
11 .B name
12 .SH DESCRIPTION
13 .I Vwright
14 shifts a RADIANCE view
15 the specified distance to the right, putting out a complete set of
16 view parameters in a single line on the standard output.
17 This utility is most often used to compute a right-eyed view from
18 a left-eye view for stereo imaging.
19 .PP
20 If no options are specified on the command line,
21 .I vwright
22 reads a view from its standard input.
23 .PP
24 The
25 .I distance
26 given is in world coordinate units.
27 A negative value indicates a shift to the left rather than the
28 right.
29 .PP
30 The second form substitutes a name prefix in place of the shift
31 distance, and produces constant assignments on the standard output
32 suitable for passing directly to
33 .I rcalc(1).
34 For a given prefix
35 .I N,
36 the constant names are as follows:
37 .sp
38 .nf
39 Nt: view type ('v'==1,'l'==2,'a'==3,'h'==4,'c'==5,'s'==6)
40 Npx: view point x value
41 Npy: view point y value
42 Npz: view point z value
43 Ndx: view direction x value (normalized)
44 Ndy: view direction y value (normalized)
45 Ndz: view direction z value (normalized)
46 Nd: view focal distance
47 Nux: view up vector x value (normalized)
48 Nuy: view up vector y value (normalized)
49 Nuz: view up vector z value (normalized)
50 Nh: view horizontal size
51 Nv: view vertical size
52 Ns: view shift
53 Nl: view lift
54 No: view fore clipping distance
55 Na: view aft clipping distance
56 Nhx: derived horizontal image vector x value (normalized)
57 Nhy: derived horizontal image vector y value (normalized)
58 Nhz: derived horizontal image vector z value (normalized)
59 Nhn: derived horizontal image vector multiplier
60 Nvx: derived vertical image vector x value (normalized)
61 Nvy: derived vertical image vector y value (normalized)
62 Nvz: derived vertical image vector z value (normalized)
63 Nvn: derived vertical image vector multiplier
64 .fi
65 .SH EXAMPLES
66 To start
67 .I rpict(1)
68 on a view .06 meters left of the view in the file "right.vf":
69 .IP "" .2i
70 rpict `vwright -.06 < right.vf` scene.oct > right.hdr &
71 .PP
72 To move the
73 .I rad(1)
74 view named "left" 2.5 inches to the right
75 and render from there:
76 .IP "" .2i
77 rad \-v "right `rad \-n \-s \-V \-v left examp.rif | vwright 2.5`" examp.rif &
78 .PP
79 To pass a view to
80 .I rcalc
81 for conversion to some other view:
82 .IP "" .2i
83 rcalc \-n \-e `vwright orig < orig.vf` \-f viewmod.cal \-o view.fmt > new.vf
84 .SH AUTHOR
85 Greg Ward
86 .SH "SEE ALSO"
87 pdfblur(1), rad(1), rcalc(1), rpict(1), rvu(1)
