1 |
.\" RCSid "$Id: vwright.1,v 1.8 2009/06/14 00:33:15 greg Exp $" |
2 |
.TH VWRIGHT 1 8/29/96 RADIANCE |
3 |
.SH NAME |
4 |
vwright - normalize a RADIANCE view, shift it to the right |
5 |
.SH SYNOPSIS |
6 |
.B vwright |
7 |
.B "[ view options ]" |
8 |
.B distance |
9 |
.br |
10 |
.B vwright |
11 |
12 |
.B name |
13 |
.SH DESCRIPTION |
14 |
In the first form, |
15 |
.I vwright |
16 |
shifts a RADIANCE view |
17 |
the specified distance to the right, putting out a complete set of |
18 |
view parameters in a single line on the standard output. |
19 |
This utility is most often used to compute a right-eyed view from |
20 |
a left-eye view for stereo imaging. |
21 |
.PP |
22 |
If no options are specified on the command line, |
23 |
.I vwright |
24 |
reads a view from its standard input. |
25 |
.PP |
26 |
The |
27 |
.I distance |
28 |
given is in world coordinate units. |
29 |
A negative value indicates a shift to the left rather than the |
30 |
right. |
31 |
.PP |
32 |
The second form substitutes a name prefix in place of the shift |
33 |
distance, and produces constant assignments on the standard output |
34 |
suitable for passing directly to |
35 |
.I rcalc(1). |
36 |
For a given prefix |
37 |
.I N, |
38 |
the constant names are as follows: |
39 |
.sp |
40 |
.nf |
41 |
Nt: view type ('v'==1,'l'==2,'a'==3,'h'==4,'c'==5,'s'==6) |
42 |
Npx: view point x value |
43 |
Npy: view point y value |
44 |
Npz: view point z value |
45 |
Ndx: view direction x value (normalized) |
46 |
Ndy: view direction y value (normalized) |
47 |
Ndz: view direction z value (normalized) |
48 |
Nd: view focal distance |
49 |
Nux: view up vector x value (normalized) |
50 |
Nuy: view up vector y value (normalized) |
51 |
Nuz: view up vector z value (normalized) |
52 |
Nh: view horizontal size |
53 |
Nv: view vertical size |
54 |
Ns: view shift |
55 |
Nl: view lift |
56 |
No: view fore clipping distance |
57 |
Na: view aft clipping distance |
58 |
Nhx: derived horizontal image vector x value (normalized) |
59 |
Nhy: derived horizontal image vector y value (normalized) |
60 |
Nhz: derived horizontal image vector z value (normalized) |
61 |
Nhn: derived horizontal image vector multiplier |
62 |
Nvx: derived vertical image vector x value (normalized) |
63 |
Nvy: derived vertical image vector y value (normalized) |
64 |
Nvz: derived vertical image vector z value (normalized) |
65 |
Nvn: derived vertical image vector multiplier |
66 |
.fi |
67 |
.SH EXAMPLES |
68 |
To start |
69 |
.I rpict(1) |
70 |
on a view .06 meters left of the view in the file "right.vf": |
71 |
.IP "" .2i |
72 |
rpict `vwright -.06 < right.vf` scene.oct > right.hdr & |
73 |
.PP |
74 |
To move the |
75 |
.I rad(1) |
76 |
view named "left" 2.5 inches to the right |
77 |
and render from there: |
78 |
.IP "" .2i |
79 |
rad \-v "right `rad \-n \-s \-V \-v left examp.rif | vwright 2.5`" examp.rif & |
80 |
.PP |
81 |
To pass a view to |
82 |
.I rcalc |
83 |
for conversion to some other view: |
84 |
.IP "" .2i |
85 |
rcalc \-n \-e `vwright orig < orig.vf` \-f viewmod.cal \-o view.fmt > new.vf |
86 |
.SH AUTHOR |
87 |
Greg Ward |
88 |
.SH "SEE ALSO" |
89 |
pdfblur(1), rad(1), rcalc(1), rpict(1), rvu(1) |
