--- ray/doc/man/man1/vwrays.1 2019/11/07 23:20:28 1.11 +++ ray/doc/man/man1/vwrays.1 2022/04/09 17:18:08 1.13 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: vwrays.1,v 1.11 2019/11/07 23:20:28 greg Exp $" +.\" RCSid "$Id: vwrays.1,v 1.13 2022/04/09 17:18:08 greg Exp $" .TH VWRAYS 1 1/15/99 RADIANCE .SH NAME vwrays - compute rays for a given picture or view @@ -47,7 +47,9 @@ with the same setting, providing a much faster way to average pixels over image sets. The .I \-pj -option should be used to jitter sample postions in most cases. +and/or +.I \-pd +options should be used to jitter sample postions in most cases. .PP View options may be any combination of standard view parameters described in the @@ -70,7 +72,10 @@ aspect ratio, unless this ratio is set to zero. The .I \-pj option may be used to jitter samples. -The default value of 0 turns off ray jittering. +The +.I \-pd +option specifies a world-diameter aperture for depth-of-field jittering. +The default value of 0 for both options turns off all ray jittering. .PP If the .I \-d @@ -82,9 +87,7 @@ The .I \-ld switch will also be printed, with .I \-ld+ -if the view file has an aft clipping plane, and -.I \-ld- -otherwise. +if the view has an aft clipping plane. This is useful for passing options to the .I rtrace command line.
