--- ray/doc/man/man1/vwrays.1 2007/09/04 17:36:41 1.5 +++ ray/doc/man/man1/vwrays.1 2021/12/04 16:29:29 1.12 @@ -1,10 +1,10 @@ -.\" RCSid "$Id: vwrays.1,v 1.5 2007/09/04 17:36:41 greg Exp $" +.\" RCSid "$Id: vwrays.1,v 1.12 2021/12/04 16:29:29 greg Exp $" .TH VWRAYS 1 1/15/99 RADIANCE .SH NAME vwrays - compute rays for a given picture or view .SH SYNOPSIS .B vwrays -.B "[ -i -f{a|f|d} | -d ]" +.B "[ -i -u -f{a|f|d} -c rept | -d ]" { .B "view opts .." | @@ -25,6 +25,9 @@ The .I \-i option may be used to specify desired pixel positions on the standard input rather than generating all the pixels for a given view. +If the +.I \-u +option is also given, output will be unbuffered. .PP The .I \-f @@ -34,6 +37,20 @@ Using raw float or double records for example can redu requirements of transferring and interpreting information in .I rtrace. .PP +The +.I \-c +option repeats each pixel the given number of times (default is 1). +This is most useful when sending rays to +.I rcontrib(1) +with the same +.I \-c +setting, providing a much faster way to average pixels over image sets. +The +.I \-pj +and/or +.I \-pd +options should be used to jitter sample postions in most cases. +.PP View options may be any combination of standard view parameters described in the .I rpict(1) @@ -55,7 +72,10 @@ aspect ratio, unless this ratio is set to zero. The .I \-pj option may be used to jitter samples. -The default value of 0 turns off ray jittering. +The +.I \-pd +option specifies a world-diameter aperture for depth-of-field jittering. +The default value of 0 for both options turns off all ray jittering. .PP If the .I \-d @@ -90,8 +110,8 @@ otherwise, which would produce a uniform clipping dist .PP If a picture is given on the command line rather than a set of view options, then the view and image dimensions are taken from the picture file, and -the reported ray origins and directions will exactly match the center of each -pixel in the picture. +the reported ray origins and directions will match the center of each +pixel in the picture (plus optional jitter). .PP If a depth buffer file is given as well, then .I vwrays @@ -105,7 +125,7 @@ for light rays leaving the scene surfaces to strike ea To compute the ray intersection points and returned directions corresponding to a picture and its depth buffer: .IP "" .2i -vwrays scene_v2.pic scene_v2.zbf > scene_v2.pts +vwrays scene_v2.hdr scene_v2.zbf > scene_v2.pts .PP To determine what the dimensions of a given view would be: .IP "" .2i @@ -117,7 +137,7 @@ instead of .I rpict: .IP "" .2i vwrays \-ff \-vf view1.vf \-x 1024 \-y 1024 | -rtrace `vwrays \-d \-vf view1.vf \-x 1024 \-y 1024` \-ffc scene.oct > view1.pic +rtrace `vwrays \-d \-vf view1.vf \-x 1024 \-y 1024` \-ffc scene.oct > view1.hdr .SH AUTHOR Greg Ward Larson .SH ACKNOWLEDGMENT @@ -129,4 +149,4 @@ can reproduce any pixel ordering (i.e., any image orie a rendered picture, it will only produce standard scanline-ordered rays when given a set of view parameters. .SH "SEE ALSO" -rcalc(1), rpict(1), rtcontrib(1), rtrace(1) +rcalc(1), rcode_depth(1), rcontrib(1), rpict(1), rtpict(1), rtrace(1)
