root/radiance/ray/doc/man/man1/vwrays.1
Revision: 1.4
Committed: Mon Sep 19 04:26:08 2005 UTC (19 years, 7 months ago) by greg
Changes since 1.3: +15 -11 lines
1 .\" RCSid "$Id: vwrays.1,v 1.3 2005/05/26 06:55:22 greg Exp $"
2 .TH VWRAYS 1 1/15/99 RADIANCE
3 .SH NAME
4 vwrays - compute rays for a given picture or view
5 .SH SYNOPSIS
6 .B vwrays
7 .B "[ -i -f{a|f|d} | -d ]"
8 {
9 .B "view opts .."
10 |
11 .B picture
12 .B [zbuf]
13 }
14 .SH DESCRIPTION
15 .I Vwrays
16 takes a picture or view specification and computes the ray origin and
17 direction corresponding to each pixel in the image.
18 This information may then be passed to
19 .I rtrace(1)
20 to perform other calculations.
21 If a given pixel has no corresponding ray (because it is outside the
22 legal view boundaries), then six zero values are sent instead.
23 .PP
24 The
25 .I \-i
26 option may be used to specify desired pixel positions on the standard
27 input rather than generating all the pixels for a given view.
28 .PP
29 The
30 .I \-f
31 option may be used to set the record format to something other than the
32 default ASCII.
33 Using raw float or double records for example can reduce the time
34 requirements of transferring and interpreting information in
35 .I rtrace.
36 .PP
37 View options may be any combination of standard view parameters described
38 in the
39 .I rpict(1)
40 manual page, including input from a view file with the
41 .I \-vf
42 option.
43 Additionally, the target X and Y dimensions may be specified with
44 .I \-x
45 and
46 .I \-y
47 options, and the pixel aspect ratio may be given with
48 .I \-pa.
49 The default dimensions are 512x512, with a pixel aspect ratio of 1.0.
50 Just as in
51 .I rpict,
52 the X or the Y dimension will be reduced if necessary
53 to best match the specified pixel
54 aspect ratio, unless this ratio is set to zero.
55 The
56 .I \-pj
57 option may be used to jitter samples.
58 The default value of 0 turns off ray jittering.
59 .PP
60 If the
61 .I \-d
62 option is given, then
63 .I vwrays
64 just prints the computed image dimensions, which are based on the view
65 aspect and the pixel aspect ratio just described.
66 The
67 .I \-ld
68 switch will also be printed, with
69 .I \-ld+
70 if the view file has an aft clipping plane, and
71 .I \-ld-
72 otherwise.
73 This is useful for passing options to the
74 .I rtrace
75 command line.
76 (See below.)
77 .PP
78 If the view contains an aft clipping plane
79 .I (-va
80 option), then the magnitudes of the ray directions will
81 equal the maximum distance for each pixel, which will be interpreted
82 correctly by
83 .I rtrace
84 with the
85 .I \-ld+
86 option.
87 Note that this option should not be given unless there is an aft
88 clipping plane, since the ray direction vectors will be normalized
89 otherwise, which would produce a uniform clipping distance of 1.
90 .PP
91 If a picture is given on the command line rather than a set of view options,
92 then the view and image dimensions are taken from the picture file, and
93 the reported ray origins and directions will exactly match the center of each
94 pixel in the picture.
95 .PP
96 If a depth buffer file is given as well, then
97 .I vwrays
98 computes the intersection point of each pixel ray (equal to the ray origin
99 plus the depth times the ray direction), and reports this instead of the
100 ray origin.
101 The reported ray direction will also be reversed.
102 The interpretation of this data is an image of origins and directions
103 for light rays leaving the scene surfaces to strike each pixel.
104 .SH EXAMPLES
105 To compute the ray intersection points and returned directions corresponding
106 to a picture and its depth buffer:
107 .IP "" .2i
108 vwrays scene_v2.pic scene_v2.zbf > scene_v2.pts
109 .PP
110 To determine what the dimensions of a given view would be:
111 .IP "" .2i
112 vwrays -d -vf myview.vf -x 2048 -y 2048
113 .PP
114 To generate a RADIANCE picture using
115 .I rtrace
116 instead of
117 .I rpict:
118 .IP "" .2i
119 vwrays -ff -vf view1.vf -x 1024 -y 1024 |
120 rtrace `vwrays -d -vf view1.vf -x 1024 -y 1024` -ffc scene.oct > view1.pic
121 .SH AUTHOR
122 Greg Ward Larson
123 .SH ACKNOWLEDGMENT
124 This work was supported by Silicon Graphics, Inc.
125 .SH BUGS
126 Although
127 .I vwrays
128 can reproduce any pixel ordering (i.e., any image orientation) when given
129 a rendered picture, it will only produce standard scanline-ordered rays when
130 given a set of view parameters.
131 .SH "SEE ALSO"
132 rcalc(1), rpict(1), rtcontrib(1), rtrace(1)
