root/Development/ray/doc/man/man1/vwrays.1
Revision: 1.8
Committed: Sat Aug 20 20:57:51 2011 UTC (14 years, 4 months ago) by greg
Changes since 1.7: +5 -2 lines
Added -u option to vwrays for unbuffered output with -i
# User Rev Content
1 greg 1.8 .\" RCSid "$Id: vwrays.1,v 1.7 2011/08/16 02:22:50 greg Exp $"
2 greg 1.1 .TH VWRAYS 1 1/15/99 RADIANCE
3     .SH NAME
4     vwrays - compute rays for a given picture or view
5     .SH SYNOPSIS
6     .B vwrays
7 greg 1.8 .B "[ -i -u -f{a|f|d} | -d ]"
8 greg 1.1 {
9     .B "view opts .."
10     |
11     .B picture
12     .B [zbuf]
13     }
14     .SH DESCRIPTION
15     .I Vwrays
16     takes a picture or view specification and computes the ray origin and
17     direction corresponding to each pixel in the image.
18     This information may then be passed to
19     .I rtrace(1)
20     to perform other calculations.
21     If a given pixel has no corresponding ray (because it is outside the
22     legal view boundaries), then six zero values are sent instead.
23     .PP
24     The
25 greg 1.4 .I \-i
26 greg 1.1 option may be used to specify desired pixel positions on the standard
27     input rather than generating all the pixels for a given view.
28 greg 1.8 If the
29     .I \-u
30     option is also given, output will be unbuffered.
31 greg 1.1 .PP
32     The
33 greg 1.4 .I \-f
34 greg 1.1 option may be used to set the record format to something other than the
35     default ASCII.
36     Using raw float or double records for example can reduce the time
37     requirements of transferring and interpreting information in
38     .I rtrace.
39     .PP
40     View options may be any combination of standard view parameters described
41     in the
42     .I rpict(1)
43     manual page, including input from a view file with the
44     .I \-vf
45     option.
46     Additionally, the target X and Y dimensions may be specified with
47 greg 1.4 .I \-x
48 greg 1.1 and
49 greg 1.4 .I \-y
50 greg 1.1 options, and the pixel aspect ratio may be given with
51 greg 1.4 .I \-pa.
52 greg 1.1 The default dimensions are 512x512, with a pixel aspect ratio of 1.0.
53     Just as in
54     .I rpict,
55     the X or the Y dimension will be reduced if necessary
56     to best match the specified pixel
57     aspect ratio, unless this ratio is set to zero.
58 greg 1.4 The
59     .I \-pj
60     option may be used to jitter samples.
61     The default value of 0 turns off ray jittering.
62 greg 1.1 .PP
63     If the
64 greg 1.4 .I \-d
65 greg 1.1 option is given, then
66     .I vwrays
67     just prints the computed image dimensions, which are based on the view
68     aspect and the pixel aspect ratio just described.
69     The
70 greg 1.4 .I \-ld
71 greg 1.1 switch will also be printed, with
72 greg 1.4 .I \-ld+
73 greg 1.1 if the view file has an aft clipping plane, and
74 greg 1.4 .I \-ld-
75 greg 1.1 otherwise.
76     This is useful for passing options to the
77     .I rtrace
78     command line.
79     (See below.)
80     .PP
81     If the view contains an aft clipping plane
82     .I (-va
83     option), then the magnitudes of the ray directions will
84     equal the maximum distance for each pixel, which will be interpreted
85     correctly by
86     .I rtrace
87     with the
88 greg 1.4 .I \-ld+
89 greg 1.1 option.
90     Note that this option should not be given unless there is an aft
91     clipping plane, since the ray direction vectors will be normalized
92     otherwise, which would produce a uniform clipping distance of 1.
93     .PP
94     If a picture is given on the command line rather than a set of view options,
95     then the view and image dimensions are taken from the picture file, and
96 greg 1.7 the reported ray origins and directions will match the center of each
97     pixel in the picture (plus optional jitter).
98 greg 1.1 .PP
99     If a depth buffer file is given as well, then
100     .I vwrays
101     computes the intersection point of each pixel ray (equal to the ray origin
102     plus the depth times the ray direction), and reports this instead of the
103     ray origin.
104     The reported ray direction will also be reversed.
105     The interpretation of this data is an image of origins and directions
106     for light rays leaving the scene surfaces to strike each pixel.
107     .SH EXAMPLES
108     To compute the ray intersection points and returned directions corresponding
109     to a picture and its depth buffer:
110     .IP "" .2i
111 greg 1.6 vwrays scene_v2.hdr scene_v2.zbf > scene_v2.pts
112 greg 1.1 .PP
113     To determine what the dimensions of a given view would be:
114     .IP "" .2i
115 greg 1.5 vwrays \-d \-vf myview.vf \-x 2048 \-y 2048
116 greg 1.1 .PP
117     To generate a RADIANCE picture using
118     .I rtrace
119     instead of
120     .I rpict:
121     .IP "" .2i
122 greg 1.5 vwrays \-ff \-vf view1.vf \-x 1024 \-y 1024 |
123 greg 1.6 rtrace `vwrays \-d \-vf view1.vf \-x 1024 \-y 1024` \-ffc scene.oct > view1.hdr
124 greg 1.1 .SH AUTHOR
125     Greg Ward Larson
126     .SH ACKNOWLEDGMENT
127     This work was supported by Silicon Graphics, Inc.
128     .SH BUGS
129     Although
130     .I vwrays
131     can reproduce any pixel ordering (i.e., any image orientation) when given
132     a rendered picture, it will only produce standard scanline-ordered rays when
133     given a set of view parameters.
134     .SH "SEE ALSO"
135 greg 1.3 rcalc(1), rpict(1), rtcontrib(1), rtrace(1)
