root/radiance/ray/doc/man/man1/vwrays.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH VWRAYS 1 1/15/99 RADIANCE
3 .SH NAME
4 vwrays - compute rays for a given picture or view
5 .SH SYNOPSIS
6 .B vwrays
7 .B "[ -i -f{a|f|d} | -d ]"
8 {
9 .B "view opts .."
10 |
11 .B picture
12 .B [zbuf]
13 }
14 .SH DESCRIPTION
15 .I Vwrays
16 takes a picture or view specification and computes the ray origin and
17 direction corresponding to each pixel in the image.
18 This information may then be passed to
19 .I rtrace(1)
20 to perform other calculations.
21 If a given pixel has no corresponding ray (because it is outside the
22 legal view boundaries), then six zero values are sent instead.
23 .PP
24 The
25 .I -i
26 option may be used to specify desired pixel positions on the standard
27 input rather than generating all the pixels for a given view.
28 .PP
29 The
30 .I -f
31 option may be used to set the record format to something other than the
32 default ASCII.
33 Using raw float or double records for example can reduce the time
34 requirements of transferring and interpreting information in
35 .I rtrace.
36 .PP
37 View options may be any combination of standard view parameters described
38 in the
39 .I rpict(1)
40 manual page, including input from a view file with the
41 .I \-vf
42 option.
43 Additionally, the target X and Y dimensions may be specified with
44 .I -x
45 and
46 .I -y
47 options, and the pixel aspect ratio may be given with
48 .I -p.
49 The default dimensions are 512x512, with a pixel aspect ratio of 1.0.
50 Just as in
51 .I rpict,
52 the X or the Y dimension will be reduced if necessary
53 to best match the specified pixel
54 aspect ratio, unless this ratio is set to zero.
55 .PP
56 If the
57 .I -d
58 option is given, then
59 .I vwrays
60 just prints the computed image dimensions, which are based on the view
61 aspect and the pixel aspect ratio just described.
62 The
63 .I -ld
64 switch will also be printed, with
65 .I -ld+
66 if the view file has an aft clipping plane, and
67 .I -ld-
68 otherwise.
69 This is useful for passing options to the
70 .I rtrace
71 command line.
72 (See below.)
73 .PP
74 If the view contains an aft clipping plane
75 .I (-va
76 option), then the magnitudes of the ray directions will
77 equal the maximum distance for each pixel, which will be interpreted
78 correctly by
79 .I rtrace
80 with the
81 .I -ld+
82 option.
83 Note that this option should not be given unless there is an aft
84 clipping plane, since the ray direction vectors will be normalized
85 otherwise, which would produce a uniform clipping distance of 1.
86 .PP
87 If a picture is given on the command line rather than a set of view options,
88 then the view and image dimensions are taken from the picture file, and
89 the reported ray origins and directions will exactly match the center of each
90 pixel in the picture.
91 .PP
92 If a depth buffer file is given as well, then
93 .I vwrays
94 computes the intersection point of each pixel ray (equal to the ray origin
95 plus the depth times the ray direction), and reports this instead of the
96 ray origin.
97 The reported ray direction will also be reversed.
98 The interpretation of this data is an image of origins and directions
99 for light rays leaving the scene surfaces to strike each pixel.
100 .SH EXAMPLES
101 To compute the ray intersection points and returned directions corresponding
102 to a picture and its depth buffer:
103 .IP "" .2i
104 vwrays scene_v2.pic scene_v2.zbf > scene_v2.pts
105 .PP
106 To determine what the dimensions of a given view would be:
107 .IP "" .2i
108 vwrays -d -vf myview.vf -x 2048 -y 2048
109 .PP
110 To generate a RADIANCE picture using
111 .I rtrace
112 instead of
113 .I rpict:
114 .IP "" .2i
115 vwrays -ff -vf view1.vf -x 1024 -y 1024 |
116 rtrace `vwrays -d -vf view1.vf -x 1024 -y 1024` -ffc scene.oct > view1.pic
117 .SH AUTHOR
118 Greg Ward Larson
119 .SH ACKNOWLEDGMENT
120 This work was supported by Silicon Graphics, Inc.
121 .SH BUGS
122 Although
123 .I vwrays
124 can reproduce any pixel ordering (i.e., any image orientation) when given
125 a rendered picture, it will only produce standard scanline-ordered rays when
126 given a set of view parameters.
127 .SH "SEE ALSO"
128 rcalc(1), rpict(1), rtrace(1)
