root/Development/ray/doc/man/man1/vwrays.1
Revision: 1.2
Committed: Tue Dec 9 15:59:07 2003 UTC (22 years ago) by greg
CVS Tags: rad3R6P1, rad3R6
Fixed RCSid specification
# User Rev Content
1 greg 1.2 .\" RCSid "$Id$"
2 greg 1.1 .TH VWRAYS 1 1/15/99 RADIANCE
3     .SH NAME
4     vwrays - compute rays for a given picture or view
5     .SH SYNOPSIS
6     .B vwrays
7     .B "[ -i -f{a|f|d} | -d ]"
8     {
9     .B "view opts .."
10     |
11     .B picture
12     .B [zbuf]
13     }
14     .SH DESCRIPTION
15     .I Vwrays
16     takes a picture or view specification and computes the ray origin and
17     direction corresponding to each pixel in the image.
18     This information may then be passed to
19     .I rtrace(1)
20     to perform other calculations.
21     If a given pixel has no corresponding ray (because it is outside the
22     legal view boundaries), then six zero values are sent instead.
23     .PP
24     The
25     .I -i
26     option may be used to specify desired pixel positions on the standard
27     input rather than generating all the pixels for a given view.
28     .PP
29     The
30     .I -f
31     option may be used to set the record format to something other than the
32     default ASCII.
33     Using raw float or double records for example can reduce the time
34     requirements of transferring and interpreting information in
35     .I rtrace.
36     .PP
37     View options may be any combination of standard view parameters described
38     in the
39     .I rpict(1)
40     manual page, including input from a view file with the
41     .I \-vf
42     option.
43     Additionally, the target X and Y dimensions may be specified with
44     .I -x
45     and
46     .I -y
47     options, and the pixel aspect ratio may be given with
48     .I -p.
49     The default dimensions are 512x512, with a pixel aspect ratio of 1.0.
50     Just as in
51     .I rpict,
52     the X or the Y dimension will be reduced if necessary
53     to best match the specified pixel
54     aspect ratio, unless this ratio is set to zero.
55     .PP
56     If the
57     .I -d
58     option is given, then
59     .I vwrays
60     just prints the computed image dimensions, which are based on the view
61     aspect and the pixel aspect ratio just described.
62     The
63     .I -ld
64     switch will also be printed, with
65     .I -ld+
66     if the view file has an aft clipping plane, and
67     .I -ld-
68     otherwise.
69     This is useful for passing options to the
70     .I rtrace
71     command line.
72     (See below.)
73     .PP
74     If the view contains an aft clipping plane
75     .I (-va
76     option), then the magnitudes of the ray directions will
77     equal the maximum distance for each pixel, which will be interpreted
78     correctly by
79     .I rtrace
80     with the
81     .I -ld+
82     option.
83     Note that this option should not be given unless there is an aft
84     clipping plane, since the ray direction vectors will be normalized
85     otherwise, which would produce a uniform clipping distance of 1.
86     .PP
87     If a picture is given on the command line rather than a set of view options,
88     then the view and image dimensions are taken from the picture file, and
89     the reported ray origins and directions will exactly match the center of each
90     pixel in the picture.
91     .PP
92     If a depth buffer file is given as well, then
93     .I vwrays
94     computes the intersection point of each pixel ray (equal to the ray origin
95     plus the depth times the ray direction), and reports this instead of the
96     ray origin.
97     The reported ray direction will also be reversed.
98     The interpretation of this data is an image of origins and directions
99     for light rays leaving the scene surfaces to strike each pixel.
100     .SH EXAMPLES
101     To compute the ray intersection points and returned directions corresponding
102     to a picture and its depth buffer:
103     .IP "" .2i
104     vwrays scene_v2.pic scene_v2.zbf > scene_v2.pts
105     .PP
106     To determine what the dimensions of a given view would be:
107     .IP "" .2i
108     vwrays -d -vf myview.vf -x 2048 -y 2048
109     .PP
110     To generate a RADIANCE picture using
111     .I rtrace
112     instead of
113     .I rpict:
114     .IP "" .2i
115     vwrays -ff -vf view1.vf -x 1024 -y 1024 |
116     rtrace `vwrays -d -vf view1.vf -x 1024 -y 1024` -ffc scene.oct > view1.pic
117     .SH AUTHOR
118     Greg Ward Larson
119     .SH ACKNOWLEDGMENT
120     This work was supported by Silicon Graphics, Inc.
121     .SH BUGS
122     Although
123     .I vwrays
124     can reproduce any pixel ordering (i.e., any image orientation) when given
125     a rendered picture, it will only produce standard scanline-ordered rays when
126     given a set of view parameters.
127     .SH "SEE ALSO"
128     rcalc(1), rpict(1), rtrace(1)
