1 |
.\" RCSid "$Id$" |
2 |
.TH VGAIMAGE 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
vgaimage - RADIANCE picture display program for VGA |
5 |
.SH SYNOPSIS |
6 |
.B vgaimage |
7 |
8 |
.B "\-c ncolors" |
9 |
10 |
.B \-d |
11 |
12 |
.B \-b |
13 |
14 |
.B \-m |
15 |
16 |
.B "\-g gamma" |
17 |
18 |
.B "\-e +/-stops" |
19 |
20 |
.B pixfile |
21 |
.SH DESCRIPTION |
22 |
.I Vgaimage |
23 |
takes the RADIANCE picture file |
24 |
.I pixfile |
25 |
and displays it on a VGA or Super VGA card. |
26 |
The |
27 |
.I \-c |
28 |
option specifies the number of colors to use (default fills color table). |
29 |
The |
30 |
.I \-d |
31 |
option turns off color dithering. |
32 |
The |
33 |
.I \-b |
34 |
option displays the image in black and white (greyscale). |
35 |
The |
36 |
.I \-m |
37 |
option forces monochrome output. |
38 |
The |
39 |
.I \-g |
40 |
option specifies the exponent used in gamma correction; |
41 |
the default value is given by the environment variable GAMMA, or |
42 |
2.2 if GAMMA is undefined. |
43 |
The |
44 |
.I \-e |
45 |
option specifies an exposure compensation in f-stops (powers of two). |
46 |
Only integer stops are allowed, for efficiency. |
47 |
.PP |
48 |
If no |
49 |
.I pixfile |
50 |
is given, input is read from stdin provided either the |
51 |
.I \-b |
52 |
or |
53 |
.I \-m |
54 |
option is in effect. |
55 |
.SH COMMANDS |
56 |
Once a picture is displayed, the user |
57 |
may perform a number of operations. |
58 |
Some of the operations make use of an area of interest, defined by pressing |
59 |
a mouse button and dragging the cursor over a section of the image. |
60 |
Pressing a button and immediately releasing it defines a single point as |
61 |
the area of interest. |
62 |
A command is a single character. |
63 |
.TP 10n |
64 |
.BR q |
65 |
Quit program. |
66 |
.TP |
67 |
.BR <return> |
68 |
Display the radiance averaged over the area of interest. |
69 |
.TP |
70 |
.BR l |
71 |
Display the luminance value in the area of interest. |
72 |
.TP |
73 |
.BR c |
74 |
Display the color in the area of interest. |
75 |
.SH ENVIRONMENT |
76 |
GAMMA the default gamma correction value |
77 |
.SH AUTHORS |
78 |
Greg Ward |
79 |
.SH "SEE ALSO" |
80 |
aedimage(1), pfilt(1), rpict(1), rtrace(1), ximage(1) |
