--- ray/doc/man/man1/total.1 2005/07/13 15:21:28 1.6 +++ ray/doc/man/man1/total.1 2016/03/24 18:48:28 1.9 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: total.1,v 1.6 2005/07/13 15:21:28 greg Exp $" +.\" RCSid "$Id: total.1,v 1.9 2016/03/24 18:48:28 greg Exp $" .TH TOTAL 1 2/3/95 RADIANCE .SH NAME total - sum up columns @@ -19,6 +19,10 @@ total - sum up columns ][ .B \-o{f|d} ][ +.B "\-in M" +][ +.B "\-on M" +][ .B \-tC ][ .B \-N @@ -112,6 +116,14 @@ and the calculation is reset before the next file (wit option). .PP The +.I \-in +option if present, will limit the number of input records read +(per input file). +The +.I \-on +option may be used to limit the total number of outut records produced. +.PP +The .I \-tC option can be used to specify the input and output tab character. The default tab character is TAB. @@ -120,11 +132,11 @@ If no files are given, the standard input is read. .SH EXAMPLE To compute the RMS value of colon-separated columns in a file: .IP "" .2i -total -t: -m -s2 input +total \-t: \-m \-s2 input .PP To produce a running product of values from a file: .IP "" .2i -total -p -1 -r input +total \-p \-1 \-r input .SH BUGS If the input files have varying numbers of columns, mean values will certainly be off. @@ -135,4 +147,4 @@ the tab character is white. .SH AUTHOR Greg Ward .SH "SEE ALSO" -cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1) +cnt(1), neaten(1), rcalc(1), rcollate(1), rlam(1), tabfunc(1)
