--- ray/doc/man/man1/total.1 2003/03/11 19:20:21 1.1 +++ ray/doc/man/man1/total.1 2005/07/13 15:21:28 1.6 @@ -1,4 +1,4 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: total.1,v 1.6 2005/07/13 15:21:28 greg Exp $" .TH TOTAL 1 2/3/95 RADIANCE .SH NAME total - sum up columns @@ -15,6 +15,10 @@ total - sum up columns | .B \-l ][ +.B \-i{f|d}[N] +][ +.B \-o{f|d} +][ .B \-tC ][ .B \-N @@ -64,11 +68,35 @@ For products, the geometric mean is computed. (A logarithmic sum of absolute values is used to avoid overflow, and zero values are silently ignored.) .PP +If the input data is binary, the +.I \-id +or +.I \-if +option may be given for 64-bit double or 32-bit float values, respectively. +Either option may be followed immediately by an optional +count, which defaults to 1, indicating the number of double or float +binary values to read per record on the input file. +(There can be no space between the option and this count.)\0 +Similarly, the +.I \-od +and +.I \-of +options specify binary double or float output, respectively. +These options do not need a count, as this will be determined by the +number of input channels. +.PP A count can be given as the number of lines to read before computing a result. -By default, +Normally, .I total -reads each file to its end before producing its result, but the +reads each file to its end before producing its result, +but this behavior may be overridden by inserting blank lines in +the input. +For each blank input line, total produces a result as if the +end-of-file had been reached. +If two blank lines immediately follow each other, total closes +the file and proceeds to the next one (after reporting the result). +The .I \-N option (where N is a decimal integer) tells .I total @@ -77,7 +105,7 @@ every N input lines. In addition, the .I \-r option can be specified to override reinitialization and thus -give a running total every N lines. +give a running total every N lines (or every blank line). If the end of file is reached, the current total is printed and the calculation is reset before the next file (with or without the .I \-r @@ -107,4 +135,4 @@ the tab character is white. .SH AUTHOR Greg Ward .SH "SEE ALSO" -cnt(1), lam(1), neat(1), rcalc(1), tabfunc(1) +cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1)
