| 1 |
greg |
1.12 |
.\" RCSid "$Id: total.1,v 1.11 2019/07/20 00:57:43 greg Exp $"
| 2 |
greg |
1.1 |
.TH TOTAL 1 2/3/95 RADIANCE
| 3 |
.SH NAME
| 4 |
total - sum up columns
| 5 |
.SH SYNOPSIS
| 6 |
.B total
| 7 |
| 8 |
.B \-m
| 9 |
| 10 |
.B \-sE
| 11 |
| 12 |
.B \-p
| 13 |
| 14 |
.B \-u
| 15 |
| 16 |
.B \-l
| 17 |
| 18 |
greg |
1.4 |
.B \-i{f|d}[N]
| 19 |
| 20 |
.B \-o{f|d}
| 21 |
| 22 |
greg |
1.9 |
.B "\-in M"
| 23 |
| 24 |
.B "\-on M"
| 25 |
| 26 |
greg |
1.1 |
.B \-tC
| 27 |
| 28 |
.B \-N
| 29 |
| 30 |
.B \-r
| 31 |
| 32 |
| 33 |
file ..
| 34 |
| 35 |
.SH DESCRIPTION
| 36 |
.I Total
| 37 |
sums up columns of real numbers from one or more files
| 38 |
and prints out the result on its standard output.
| 39 |
.PP
| 40 |
By default,
| 41 |
.I total
| 42 |
computes the straigt sum of each input column, but multiplication
| 43 |
can be specified instead with the
| 44 |
.I \-p
| 45 |
option.
| 46 |
Likewise, the
| 47 |
.I \-u
| 48 |
option means find the upper limit (maximum), and
| 49 |
.I \-l
| 50 |
means find the lower limit (minimum).
| 51 |
.PP
| 52 |
Sums of powers can be computed by giving an exponent with the
| 53 |
.I \-s
| 54 |
option.
| 55 |
(Note that there is no space between the
| 56 |
.I \-s
| 57 |
and the exponent.)
| 58 |
This exponent can be any real number, positive or negative.
| 59 |
The absolute value of the input is always taken before the
| 60 |
power is computed in order to avoid complex results.
| 61 |
Thus,
| 62 |
.I \-s1
| 63 |
will produce a sum of absolute values.
| 64 |
The default power (zero) is interpreted as a straight sum without
| 65 |
taking absolute values.
| 66 |
.PP
| 67 |
The
| 68 |
.I \-m
| 69 |
option can be used to compute the mean rather than the total.
| 70 |
For sums, the arithmetic mean is computed.
| 71 |
greg |
1.10 |
If a power is also specified using the
| 72 |
.I \-s
| 73 |
option, the inverse power will be applied to the averaged result.
| 74 |
greg |
1.1 |
For products, the geometric mean is computed.
| 75 |
(A logarithmic sum of absolute values is used to avoid overflow, and
| 76 |
zero values are silently ignored.)
| 77 |
.PP
| 78 |
greg |
1.4 |
If the input data is binary, the
| 79 |
.I \-id
| 80 |
or
| 81 |
.I \-if
| 82 |
option may be given for 64-bit double or 32-bit float values, respectively.
| 83 |
Either option may be followed immediately by an optional
| 84 |
count, which defaults to 1, indicating the number of double or float
| 85 |
binary values to read per record on the input file.
| 86 |
(There can be no space between the option and this count.)\0
| 87 |
Similarly, the
| 88 |
.I \-od
| 89 |
and
| 90 |
.I \-of
| 91 |
options specify binary double or float output, respectively.
| 92 |
These options do not need a count, as this will be determined by the
| 93 |
number of input channels.
| 94 |
.PP
| 95 |
greg |
1.1 |
A count can be given as the number of lines to read before
| 96 |
computing a result.
| 97 |
greg |
1.6 |
Normally,
| 98 |
greg |
1.1 |
.I total
| 99 |
greg |
1.6 |
reads each file to its end before producing its result,
| 100 |
but this behavior may be overridden by inserting blank lines in
| 101 |
the input.
| 102 |
For each blank input line, total produces a result as if the
| 103 |
end-of-file had been reached.
| 104 |
If two blank lines immediately follow each other, total closes
| 105 |
the file and proceeds to the next one (after reporting the result).
| 106 |
The
| 107 |
greg |
1.1 |
.I \-N
| 108 |
option (where N is a decimal integer) tells
| 109 |
.I total
| 110 |
to produce a result and reset the calculation after
| 111 |
every N input lines.
| 112 |
In addition, the
| 113 |
.I \-r
| 114 |
option can be specified to override reinitialization and thus
| 115 |
greg |
1.6 |
give a running total every N lines (or every blank line).
| 116 |
greg |
1.12 |
This option also turns off the usual output flushing at each total.
| 117 |
greg |
1.1 |
If the end of file is reached, the current total is printed
| 118 |
and the calculation is reset before the next file (with or without the
| 119 |
.I \-r
| 120 |
option).
| 121 |
.PP
| 122 |
The
| 123 |
greg |
1.9 |
.I \-in
| 124 |
option if present, will limit the number of input records read
| 125 |
(per input file).
| 126 |
The
| 127 |
.I \-on
| 128 |
option may be used to limit the total number of outut records produced.
| 129 |
.PP
| 130 |
The
| 131 |
greg |
1.1 |
.I \-tC
| 132 |
option can be used to specify the input and output tab character.
| 133 |
The default tab character is TAB.
| 134 |
.PP
| 135 |
If no files are given, the standard input is read.
| 136 |
greg |
1.11 |
.SH EXAMPLES
| 137 |
greg |
1.1 |
To compute the RMS value of colon-separated columns in a file:
| 138 |
.IP "" .2i
| 139 |
greg |
1.7 |
total \-t: \-m \-s2 input
| 140 |
greg |
1.1 |
.PP
| 141 |
To produce a running product of values from a file:
| 142 |
.IP "" .2i
| 143 |
greg |
1.7 |
total \-p \-1 \-r input
| 144 |
greg |
1.1 |
.SH BUGS
| 145 |
If the input files have varying numbers of columns, mean values
| 146 |
will certainly be off.
| 147 |
.I Total
| 148 |
will ignore missing column entries if the tab separator is a non-white
| 149 |
character, but cannot tell where a missing column should have been if
| 150 |
the tab character is white.
| 151 |
.SH AUTHOR
| 152 |
Greg Ward
| 153 |
.SH "SEE ALSO"
| 154 |
greg |
1.11 |
cnt(1), neaten(1), rcalc(1), rcollate(1), rlam(1), rsplit(1), tabfunc(1)
