| 1 |
.\" RCSid "$Id: total.1,v 1.4 2005/06/02 04:47:26 greg Exp $"
| 2 |
.TH TOTAL 1 2/3/95 RADIANCE
| 3 |
.SH NAME
| 4 |
total - sum up columns
| 5 |
.SH SYNOPSIS
| 6 |
.B total
| 7 |
| 8 |
.B \-m
| 9 |
| 10 |
.B \-sE
| 11 |
| 12 |
.B \-p
| 13 |
| 14 |
.B \-u
| 15 |
| 16 |
.B \-l
| 17 |
| 18 |
.B \-i{f|d}[N]
| 19 |
| 20 |
.B \-o{f|d}
| 21 |
| 22 |
.B \-tC
| 23 |
| 24 |
.B \-N
| 25 |
| 26 |
.B \-r
| 27 |
| 28 |
| 29 |
file ..
| 30 |
| 31 |
.SH DESCRIPTION
| 32 |
.I Total
| 33 |
sums up columns of real numbers from one or more files
| 34 |
and prints out the result on its standard output.
| 35 |
.PP
| 36 |
By default,
| 37 |
.I total
| 38 |
computes the straigt sum of each input column, but multiplication
| 39 |
can be specified instead with the
| 40 |
.I \-p
| 41 |
option.
| 42 |
Likewise, the
| 43 |
.I \-u
| 44 |
option means find the upper limit (maximum), and
| 45 |
.I \-l
| 46 |
means find the lower limit (minimum).
| 47 |
.PP
| 48 |
Sums of powers can be computed by giving an exponent with the
| 49 |
.I \-s
| 50 |
option.
| 51 |
(Note that there is no space between the
| 52 |
.I \-s
| 53 |
and the exponent.)
| 54 |
This exponent can be any real number, positive or negative.
| 55 |
The absolute value of the input is always taken before the
| 56 |
power is computed in order to avoid complex results.
| 57 |
Thus,
| 58 |
.I \-s1
| 59 |
will produce a sum of absolute values.
| 60 |
The default power (zero) is interpreted as a straight sum without
| 61 |
taking absolute values.
| 62 |
.PP
| 63 |
The
| 64 |
.I \-m
| 65 |
option can be used to compute the mean rather than the total.
| 66 |
For sums, the arithmetic mean is computed.
| 67 |
For products, the geometric mean is computed.
| 68 |
(A logarithmic sum of absolute values is used to avoid overflow, and
| 69 |
zero values are silently ignored.)
| 70 |
.PP
| 71 |
If the input data is binary, the
| 72 |
.I \-id
| 73 |
or
| 74 |
.I \-if
| 75 |
option may be given for 64-bit double or 32-bit float values, respectively.
| 76 |
Either option may be followed immediately by an optional
| 77 |
count, which defaults to 1, indicating the number of double or float
| 78 |
binary values to read per record on the input file.
| 79 |
(There can be no space between the option and this count.)\0
| 80 |
Similarly, the
| 81 |
.I \-od
| 82 |
and
| 83 |
.I \-of
| 84 |
options specify binary double or float output, respectively.
| 85 |
These options do not need a count, as this will be determined by the
| 86 |
number of input channels.
| 87 |
.PP
| 88 |
A count can be given as the number of lines to read before
| 89 |
computing a result.
| 90 |
By default,
| 91 |
.I total
| 92 |
reads each file to its end before producing its result, but the
| 93 |
.I \-N
| 94 |
option (where N is a decimal integer) tells
| 95 |
.I total
| 96 |
to produce a result and reset the calculation after
| 97 |
every N input lines.
| 98 |
In addition, the
| 99 |
.I \-r
| 100 |
option can be specified to override reinitialization and thus
| 101 |
give a running total every N lines.
| 102 |
If the end of file is reached, the current total is printed
| 103 |
and the calculation is reset before the next file (with or without the
| 104 |
.I \-r
| 105 |
option).
| 106 |
.PP
| 107 |
The
| 108 |
.I \-tC
| 109 |
option can be used to specify the input and output tab character.
| 110 |
The default tab character is TAB.
| 111 |
.PP
| 112 |
At least one set of totals is produced for each input file.
| 113 |
If no files are given, the standard input is read.
| 114 |
If a file contains any blank lines, then the total is reported
| 115 |
at that point as if it constituted the end of file, and the tallies
| 116 |
are reset.
| 117 |
.SH EXAMPLE
| 118 |
To compute the RMS value of colon-separated columns in a file:
| 119 |
.IP "" .2i
| 120 |
total -t: -m -s2 input
| 121 |
.PP
| 122 |
To produce a running product of values from a file:
| 123 |
.IP "" .2i
| 124 |
total -p -1 -r input
| 125 |
.SH BUGS
| 126 |
If the input files have varying numbers of columns, mean values
| 127 |
will certainly be off.
| 128 |
.I Total
| 129 |
will ignore missing column entries if the tab separator is a non-white
| 130 |
character, but cannot tell where a missing column should have been if
| 131 |
the tab character is white.
| 132 |
.SH AUTHOR
| 133 |
Greg Ward
| 134 |
.SH "SEE ALSO"
| 135 |
cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1)
