root/Development/ray/doc/man/man1/total.1
Revision: 1.5
Committed: Tue Jun 21 02:34:22 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.4: +5 -1 lines
Documented new behavior with blank input lines in total(1)
1 .\" RCSid "$Id: total.1,v 1.4 2005/06/02 04:47:26 greg Exp $"
2 .TH TOTAL 1 2/3/95 RADIANCE
3 .SH NAME
4 total - sum up columns
5 .SH SYNOPSIS
6 .B total
7 [
8 .B \-m
9 ][
10 .B \-sE
11 |
12 .B \-p
13 |
14 .B \-u
15 |
16 .B \-l
17 ][
18 .B \-i{f|d}[N]
19 ][
20 .B \-o{f|d}
21 ][
22 .B \-tC
23 ][
24 .B \-N
25 [
26 .B \-r
27 ]]
28 [
29 file ..
30 ]
31 .SH DESCRIPTION
32 .I Total
33 sums up columns of real numbers from one or more files
34 and prints out the result on its standard output.
35 .PP
36 By default,
37 .I total
38 computes the straigt sum of each input column, but multiplication
39 can be specified instead with the
40 .I \-p
41 option.
42 Likewise, the
43 .I \-u
44 option means find the upper limit (maximum), and
45 .I \-l
46 means find the lower limit (minimum).
47 .PP
48 Sums of powers can be computed by giving an exponent with the
49 .I \-s
50 option.
51 (Note that there is no space between the
52 .I \-s
53 and the exponent.)
54 This exponent can be any real number, positive or negative.
55 The absolute value of the input is always taken before the
56 power is computed in order to avoid complex results.
57 Thus,
58 .I \-s1
59 will produce a sum of absolute values.
60 The default power (zero) is interpreted as a straight sum without
61 taking absolute values.
62 .PP
63 The
64 .I \-m
65 option can be used to compute the mean rather than the total.
66 For sums, the arithmetic mean is computed.
67 For products, the geometric mean is computed.
68 (A logarithmic sum of absolute values is used to avoid overflow, and
69 zero values are silently ignored.)
70 .PP
71 If the input data is binary, the
72 .I \-id
73 or
74 .I \-if
75 option may be given for 64-bit double or 32-bit float values, respectively.
76 Either option may be followed immediately by an optional
77 count, which defaults to 1, indicating the number of double or float
78 binary values to read per record on the input file.
79 (There can be no space between the option and this count.)\0
80 Similarly, the
81 .I \-od
82 and
83 .I \-of
84 options specify binary double or float output, respectively.
85 These options do not need a count, as this will be determined by the
86 number of input channels.
87 .PP
88 A count can be given as the number of lines to read before
89 computing a result.
90 By default,
91 .I total
92 reads each file to its end before producing its result, but the
93 .I \-N
94 option (where N is a decimal integer) tells
95 .I total
96 to produce a result and reset the calculation after
97 every N input lines.
98 In addition, the
99 .I \-r
100 option can be specified to override reinitialization and thus
101 give a running total every N lines.
102 If the end of file is reached, the current total is printed
103 and the calculation is reset before the next file (with or without the
104 .I \-r
105 option).
106 .PP
107 The
108 .I \-tC
109 option can be used to specify the input and output tab character.
110 The default tab character is TAB.
111 .PP
112 At least one set of totals is produced for each input file.
113 If no files are given, the standard input is read.
114 If a file contains any blank lines, then the total is reported
115 at that point as if it constituted the end of file, and the tallies
116 are reset.
117 .SH EXAMPLE
118 To compute the RMS value of colon-separated columns in a file:
119 .IP "" .2i
120 total -t: -m -s2 input
121 .PP
122 To produce a running product of values from a file:
123 .IP "" .2i
124 total -p -1 -r input
125 .SH BUGS
126 If the input files have varying numbers of columns, mean values
127 will certainly be off.
128 .I Total
129 will ignore missing column entries if the tab separator is a non-white
130 character, but cannot tell where a missing column should have been if
131 the tab character is white.
132 .SH AUTHOR
133 Greg Ward
134 .SH "SEE ALSO"
135 cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1)
