root/radiance/ray/doc/man/man1/total.1
Revision: 1.7
Committed: Tue Sep 4 17:36:41 2007 UTC (17 years, 10 months ago) by greg
CVS Tags: rad4R1, rad4R0, rad3R9
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: total.1,v 1.6 2005/07/13 15:21:28 greg Exp $"
2 .TH TOTAL 1 2/3/95 RADIANCE
3 .SH NAME
4 total - sum up columns
5 .SH SYNOPSIS
6 .B total
7 [
8 .B \-m
9 ][
10 .B \-sE
11 |
12 .B \-p
13 |
14 .B \-u
15 |
16 .B \-l
17 ][
18 .B \-i{f|d}[N]
19 ][
20 .B \-o{f|d}
21 ][
22 .B \-tC
23 ][
24 .B \-N
25 [
26 .B \-r
27 ]]
28 [
29 file ..
30 ]
31 .SH DESCRIPTION
32 .I Total
33 sums up columns of real numbers from one or more files
34 and prints out the result on its standard output.
35 .PP
36 By default,
37 .I total
38 computes the straigt sum of each input column, but multiplication
39 can be specified instead with the
40 .I \-p
41 option.
42 Likewise, the
43 .I \-u
44 option means find the upper limit (maximum), and
45 .I \-l
46 means find the lower limit (minimum).
47 .PP
48 Sums of powers can be computed by giving an exponent with the
49 .I \-s
50 option.
51 (Note that there is no space between the
52 .I \-s
53 and the exponent.)
54 This exponent can be any real number, positive or negative.
55 The absolute value of the input is always taken before the
56 power is computed in order to avoid complex results.
57 Thus,
58 .I \-s1
59 will produce a sum of absolute values.
60 The default power (zero) is interpreted as a straight sum without
61 taking absolute values.
62 .PP
63 The
64 .I \-m
65 option can be used to compute the mean rather than the total.
66 For sums, the arithmetic mean is computed.
67 For products, the geometric mean is computed.
68 (A logarithmic sum of absolute values is used to avoid overflow, and
69 zero values are silently ignored.)
70 .PP
71 If the input data is binary, the
72 .I \-id
73 or
74 .I \-if
75 option may be given for 64-bit double or 32-bit float values, respectively.
76 Either option may be followed immediately by an optional
77 count, which defaults to 1, indicating the number of double or float
78 binary values to read per record on the input file.
79 (There can be no space between the option and this count.)\0
80 Similarly, the
81 .I \-od
82 and
83 .I \-of
84 options specify binary double or float output, respectively.
85 These options do not need a count, as this will be determined by the
86 number of input channels.
87 .PP
88 A count can be given as the number of lines to read before
89 computing a result.
90 Normally,
91 .I total
92 reads each file to its end before producing its result,
93 but this behavior may be overridden by inserting blank lines in
94 the input.
95 For each blank input line, total produces a result as if the
96 end-of-file had been reached.
97 If two blank lines immediately follow each other, total closes
98 the file and proceeds to the next one (after reporting the result).
99 The
100 .I \-N
101 option (where N is a decimal integer) tells
102 .I total
103 to produce a result and reset the calculation after
104 every N input lines.
105 In addition, the
106 .I \-r
107 option can be specified to override reinitialization and thus
108 give a running total every N lines (or every blank line).
109 If the end of file is reached, the current total is printed
110 and the calculation is reset before the next file (with or without the
111 .I \-r
112 option).
113 .PP
114 The
115 .I \-tC
116 option can be used to specify the input and output tab character.
117 The default tab character is TAB.
118 .PP
119 If no files are given, the standard input is read.
120 .SH EXAMPLE
121 To compute the RMS value of colon-separated columns in a file:
122 .IP "" .2i
123 total \-t: \-m \-s2 input
124 .PP
125 To produce a running product of values from a file:
126 .IP "" .2i
127 total \-p \-1 \-r input
128 .SH BUGS
129 If the input files have varying numbers of columns, mean values
130 will certainly be off.
131 .I Total
132 will ignore missing column entries if the tab separator is a non-white
133 character, but cannot tell where a missing column should have been if
134 the tab character is white.
135 .SH AUTHOR
136 Greg Ward
137 .SH "SEE ALSO"
138 cnt(1), neaten(1), rcalc(1), rlam(1), tabfunc(1)
