root/radiance/ray/doc/man/man1/total.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH TOTAL 1 2/3/95 RADIANCE
3 .SH NAME
4 total - sum up columns
5 .SH SYNOPSIS
6 .B total
7 [
8 .B \-m
9 ][
10 .B \-sE
11 |
12 .B \-p
13 |
14 .B \-u
15 |
16 .B \-l
17 ][
18 .B \-tC
19 ][
20 .B \-N
21 [
22 .B \-r
23 ]]
24 [
25 file ..
26 ]
27 .SH DESCRIPTION
28 .I Total
29 sums up columns of real numbers from one or more files
30 and prints out the result on its standard output.
31 .PP
32 By default,
33 .I total
34 computes the straigt sum of each input column, but multiplication
35 can be specified instead with the
36 .I \-p
37 option.
38 Likewise, the
39 .I \-u
40 option means find the upper limit (maximum), and
41 .I \-l
42 means find the lower limit (minimum).
43 .PP
44 Sums of powers can be computed by giving an exponent with the
45 .I \-s
46 option.
47 (Note that there is no space between the
48 .I \-s
49 and the exponent.)
50 This exponent can be any real number, positive or negative.
51 The absolute value of the input is always taken before the
52 power is computed in order to avoid complex results.
53 Thus,
54 .I \-s1
55 will produce a sum of absolute values.
56 The default power (zero) is interpreted as a straight sum without
57 taking absolute values.
58 .PP
59 The
60 .I \-m
61 option can be used to compute the mean rather than the total.
62 For sums, the arithmetic mean is computed.
63 For products, the geometric mean is computed.
64 (A logarithmic sum of absolute values is used to avoid overflow, and
65 zero values are silently ignored.)
66 .PP
67 A count can be given as the number of lines to read before
68 computing a result.
69 By default,
70 .I total
71 reads each file to its end before producing its result, but the
72 .I \-N
73 option (where N is a decimal integer) tells
74 .I total
75 to produce a result and reset the calculation after
76 every N input lines.
77 In addition, the
78 .I \-r
79 option can be specified to override reinitialization and thus
80 give a running total every N lines.
81 If the end of file is reached, the current total is printed
82 and the calculation is reset before the next file (with or without the
83 .I \-r
84 option).
85 .PP
86 The
87 .I \-tC
88 option can be used to specify the input and output tab character.
89 The default tab character is TAB.
90 .PP
91 If no files are given, the standard input is read.
92 .SH EXAMPLE
93 To compute the RMS value of colon-separated columns in a file:
94 .IP "" .2i
95 total -t: -m -s2 input
96 .PP
97 To produce a running product of values from a file:
98 .IP "" .2i
99 total -p -1 -r input
100 .SH BUGS
101 If the input files have varying numbers of columns, mean values
102 will certainly be off.
103 .I Total
104 will ignore missing column entries if the tab separator is a non-white
105 character, but cannot tell where a missing column should have been if
106 the tab character is white.
107 .SH AUTHOR
108 Greg Ward
109 .SH "SEE ALSO"
110 cnt(1), lam(1), neat(1), rcalc(1), tabfunc(1)
