root/radiance/ray/doc/man/man1/tmesh2rad.1
Revision: 1.3
Committed: Tue Sep 4 17:36:41 2007 UTC (17 years, 8 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1
Changes since 1.2: +18 -18 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: tmesh2rad.1,v 1.2 2003/12/09 15:59:07 greg Exp $"
2 .TH TMESH2RAD 1 3/18/96 RADIANCE
3 .SH NAME
4 tmesh2rad - convert a triangular mesh to a RADIANCE scene description
5 .SH SYNOPSIS
6 .B tmesh2rad
7 [
8 .B "\-o obj"
9 ][
10 .B "\-m mat"
11 ][
12 .B "\-p pat"
13 ]
14 [
15 .B input ..
16 ]
17 .SH DESCRIPTION
18 .I Tmesh2rad
19 converts one or more triangle-mesh files to a RADIANCE scene description.
20 The
21 .I \-o
22 option may be used to assign a default object name.
23 The single letter "T" is used if no name is given on the command
24 line or in the file.
25 The
26 .I \-m
27 option may be used to assign a default material name.
28 The non-material "void" is used as a default if none is given on the
29 command line or in the file.
30 The
31 .I \-p
32 option may be used to assign a default picture for a surface
33 pattern.
34 If none is given on the command line or in the file, the surface
35 will not have an associated pattern.
36 .SH "FILE FORMAT"
37 A triangle-mesh is a free-format ASCII file
38 composed of the following eight primitive
39 types.
40 Each primitive is begun with a single, white-space-delimited letter:
41 .TP 10n
42 .BI # \ Comment
43 Whatever follows up until the end of line is passed as a comment
44 to the output.
45 Note that there must be at least one space or tab
46 following the pound-sign.
47 .TP
48 .BI o \ name
49 The white-space-delimited string
50 .I name
51 is used as a prefix for all following output triangles.
52 .TP
53 .BI m \ material
54 The white-space-delimited string
55 .I material
56 is used as the modifier name for all following output triangles.
57 .TP
58 .BI p \ picture
59 The white-space-delimited string
60 .I picture
61 is used as the name of the RADIANCE picture file
62 to be used as a pattern for
63 all following output triangles with properly defined vertices.
64 (See
65 .I i
66 primitive below.)\0
67 .TP
68 .BI v " id x y z"
69 Defines the vertex
70 .I id
71 with 3-dimensional coordinates
72 .I "x, y"
73 and
74 .I z.
75 The identifier,
76 .I id
77 must be some small, non-negative integer value.
78 If the same integer is used for a later vertex definition,
79 this definition will be lost, though any triangles using the
80 vertex prior to its redefinition will be unaffected.
81 .TP
82 .BI n " nx ny nz"
83 Defines a surface normal vector with the 3-dimensional components
84 .I "nx, ny"
85 and
86 .I nz.
87 This vector will be associated with the most recently defined
88 vertex, and is often placed on the same line as the vertex
89 definition for clarity.
90 The vector need not be normalized.
91 .TP
92 .BI i " u v"
93 Defines a picture index for the most recently defined vertex.
94 The
95 .I u
96 value will be used to lookup the horizontal pixel coordinate
97 in the currently defined picture.
98 The
99 .I v
100 value will be used to lookup the vertical pixel coordinate.
101 (See the RADIANCE reference manual for details on picture coordinate
102 values.)\0
103 As with associated surface normals, picture indices are interpolated
104 using barycentric coordinates based on the triangle vertices.
105 If these coordinates are calculated correctly, this
106 should result in a smooth mapping of a pattern onto the
107 surface mesh.
108 .TP
109 .BI t " id1 id2 id3"
110 Create a triangle connecting the three vertices identified by
111 .I "id1, id2"
112 and
113 .I id3.
114 The right-hand rule is used to determine the default surface
115 normal orientation, and this should not be too far from the
116 associated vertex normals (if any).
117 All three vertices must have an associated normal if the triangle
118 is to be smoothed.
119 If a picture file is defined and all three vertices have pattern
120 indices associated with them, then this picture will be used as a
121 pattern to modify the triangle's color.
122 .PP
123 We realize there are many similar
124 T-mesh file formats in existence, and that it would have been just
125 as easy to support one of these formats directly.
126 The disadvantage to supporting an existing format is that conversion
127 from other formats might prove difficult.
128 It was our hope to provide a "greatest common multiple" format that
129 would support all similar T-mesh formats, rather than supporting
130 WaveFront's .obj format (for example) and being unable to associate
131 a pattern with an object.
132 Converting from other formats should be relatively straightforward.
133 In many cases, an
134 .I "awk(1), rcalc(1)"
135 or even a
136 .I sed(1)
137 script should be sufficient.
138 .SH EXAMPLE
139 Here is an example T-mesh file:
140 .sp
141 .RS
142 .nf
143 # Our object name:
144 o test_object
145 # Our material:
146 m puce
147 # Our vertices:
148 v 1 10 15 5
149 v 2 10 \-15 5
150 v 3 0 \-15 0
151 v 4 \-10 15 \-5
152 # Two triangles joined together:
153 t 1 2 3
154 t 2 3 4
155 .fi
156 .RE
157 .sp
158 Which generates the following output:
159 .sp
160 .RS
161 .nf
162 ## T-mesh read from: <stdin>
163
164 # Our material:
165
166 # Our vertices:
167
168 # Two triangles joined together:
169
170 puce polygon test_object.1
171 0
172 0
173 9
174 10 15 5
175 10 \-15 5
176 0 \-15 0
177
178 puce polygon test_object.2
179 0
180 0
181 9
182 10 \-15 5
183 0 \-15 0
184 \-10 15 \-5
185 .fi
186 .RE
187 .sp
188 .PP
189 Here is another example:
190 .sp
191 .RS
192 .nf
193 # A partial cylinder:
194 m BluePlastic
195 v 1 \-14.673 \-3.119 50 n \-0.95677 \-0.203374 1.17936e\-10
196 v 2 \-12.136 \-8.817 \-50 n \-0.791363 \-0.574922 4.84915e\-10
197 v 3 \-12.136 \-8.817 50 n \-0.791363 \-0.574922 4.84915e\-10
198 t 1 2 3
199 m OrangePlastic
200 v 1 \-7.501 \-12.991 50 n \-0.549094 \-0.812427 \-1.45812e\-09
201 v 2 \-12.136 \-8.817 50 n \-0.791363 \-0.574922 4.84915e\-10
202 v 3 \-12.136 \-8.817 \-50 n \-0.791363 \-0.574922 4.84915e\-10
203 t 1 2 3
204 m BluePlastic
205 v 1 \-1.568 \-14.918 50 n \-0.171094 \-0.965568 \-5.69788e\-09
206 v 2 \-7.501 \-12.991 50 n \-0.549094 \-0.812427 \-1.45812e\-09
207 v 3 \-7.501 \-12.991 \-50 n \-0.429001 \-0.881759 \-3.6502e\-09
208 t 1 2 3
209 .fi
210 .RE
211 .sp
212 Note that the same three vertices were used repeatedly, and
213 intermingled with the triangle definitions.
214 .SH AUTHOR
215 Greg Ward
216 .SH BUGS
217 Triangle smoothing doesn't work very well for glass or trans
218 material types in Radiance, since textures cause distorted
219 transmission through these materials.
220 It is best to use the dielectric material type if smooth
221 transmission is desired.
222 .SH "SEE ALSO"
223 arch2rad(1), awk(1), ies2rad(1), thf2rad(1),
224 oconv(1), rcalc(1), sed(1), xform(1)
