root/Development/ray/doc/man/man1/thf2rad.1
Revision: 1.3
Committed: Fri Nov 5 03:31:36 2004 UTC (21 years, 2 months ago) by greg
State: FILE REMOVED
1 .\" RCSid "$Id: thf2rad.1,v 1.2 2003/12/09 15:59:07 greg Exp $"
2 .TH THF2RAD 1 11/15/93 RADIANCE
3 .SH NAME
4 thf2rad - convert GDS things file to RADIANCE description
5 .SH SYNOPSIS
6 .B thf2rad
7 [
8 .B "\-n name"
9 ][
10 .B "\-r rad"
11 ]
12 [
13 .B input ..
14 ]
15 .SH DESCRIPTION
16 .I Thf2rad
17 converts one or more GDS things files to a RADIANCE scene description.
18 The material names for the surfaces will be those assigned in GDS.
19 The
20 .I \-n
21 option may be used to give a name prefix to all the surfaces.
22 The
23 .I \-r
24 option may be used to specify a radius for line segments.
25 By default, this value is zero, which means that lines will be ignored.
26 By setting it to some positive value, cylinders of the given radius
27 will represent lines.
28 .SH EXAMPLE
29 To translate two things files into one RADIANCE file with the prefix "gds":
30 .IP "" .2i
31 thf2rad -n gds building1.thf building2.thf > building1+2.rad
32 .PP
33 To create an octree directly from a things file, giving lines a radius
34 of .1:
35 .IP "" .2i
36 oconv source.rad materials.rad '\\!thf2rad -r .1 building1.thf' > building1.oct
37 .SH AUTHOR
38 Greg Ward and Charles Ehrlich
39 .SH "SEE ALSO"
40 arch2rad(1), ies2rad(1), oconv(1), xform(1)
