root/Development/ray/doc/man/man1/tabfunc.1
Revision: 1.3
Committed: Thu Jan 1 19:31:45 2004 UTC (21 years, 8 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
1 .\" RCSid "$Id: tabfunc.1,v 1.2 2003/12/09 15:59:07 greg Exp $"
2 .TH TABFUNC 1 10/8/97 RADIANCE
3 .SH NAME
4 tabfunc - convert table to functions for rcalc, etc.
5 .SH SYNOPSIS
6 .B tabfunc
7 [
8 .B \-i
9 ]
10 func1 [func2 ..]
11 .SH DESCRIPTION
12 .I Tabfunc
13 reads a table of numbers from the standard input and converts it to
14 an expression suitable for
15 .I icalc(1),
16 .I rcalc(1)
17 and their cousins.
18 The input must consist of a M x N matrix of real numbers, with exactly
19 one row per line.
20 The number of columns must always be the same in each line,
21 separated by whitespace and/or commas, with no missing values.
22 The first column is always the independent variable, whose value
23 indexes all of the other elements.
24 This value does not need to be evenly spaced, but it must be either
25 monotonically increasing or monotonically decreasing.
26 (I.e. it cannot go up and then down, or down and then up.)\0
27 Maximum input line width is 4096 characters and the maximum number of
28 data rows is 1024.
29 Input lines not beginning with a numerical value will be silently ignored.
30 .PP
31 The command-line arguments given to
32 .I tabfunc
33 are the names to be assigned to each column.
34 .I Tabfunc
35 then produces a single function for each column given.
36 If there are some columns which should be skipped, the dummy name
37 "0" may be given instead of a valid identifier.
38 (It is not necessary to specify a dummy name for extra columns at
39 the end of the matrix.)\0
40 .PP
41 The
42 .I \-i
43 option causes
44 .I tabfunc
45 to produce a description that will interpolate values in between
46 those given for the independent variable on the input.
47 .SH EXAMPLE
48 To convert a small data table and feed it to rcalc for some
49 calculation:
50 .IP "" .2i
51 rcalc -e `tabfunc f1 f2 < table.dat` -f com.cal
52 .SH AUTHOR
53 Greg Ward
54 .SH "SEE ALSO"
55 cnt(1), icalc(1), neaten(1), rcalc(1), rlam(1), total(1)
