root/radiance/ray/doc/man/man1/tabfunc.1
Revision: 1.3
Committed: Thu Jan 1 19:31:45 2004 UTC (21 years, 4 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: tabfunc.1,v 1.2 2003/12/09 15:59:07 greg Exp $"
2 greg 1.1 .TH TABFUNC 1 10/8/97 RADIANCE
3     .SH NAME
4     tabfunc - convert table to functions for rcalc, etc.
5     .SH SYNOPSIS
6     .B tabfunc
7     [
8     .B \-i
9     ]
10     func1 [func2 ..]
11     .SH DESCRIPTION
12     .I Tabfunc
13     reads a table of numbers from the standard input and converts it to
14     an expression suitable for
15 greg 1.3 .I icalc(1),
16 greg 1.1 .I rcalc(1)
17     and their cousins.
18     The input must consist of a M x N matrix of real numbers, with exactly
19     one row per line.
20     The number of columns must always be the same in each line,
21     separated by whitespace and/or commas, with no missing values.
22     The first column is always the independent variable, whose value
23     indexes all of the other elements.
24     This value does not need to be evenly spaced, but it must be either
25     monotonically increasing or monotonically decreasing.
26     (I.e. it cannot go up and then down, or down and then up.)\0
27     Maximum input line width is 4096 characters and the maximum number of
28     data rows is 1024.
29     Input lines not beginning with a numerical value will be silently ignored.
30     .PP
31     The command-line arguments given to
32     .I tabfunc
33     are the names to be assigned to each column.
34     .I Tabfunc
35     then produces a single function for each column given.
36     If there are some columns which should be skipped, the dummy name
37     "0" may be given instead of a valid identifier.
38     (It is not necessary to specify a dummy name for extra columns at
39     the end of the matrix.)\0
40     .PP
41     The
42     .I \-i
43     option causes
44     .I tabfunc
45     to produce a description that will interpolate values in between
46     those given for the independent variable on the input.
47     .SH EXAMPLE
48     To convert a small data table and feed it to rcalc for some
49     calculation:
50     .IP "" .2i
51     rcalc -e `tabfunc f1 f2 < table.dat` -f com.cal
52     .SH AUTHOR
53     Greg Ward
54     .SH "SEE ALSO"
55 greg 1.3 cnt(1), icalc(1), neaten(1), rcalc(1), rlam(1), total(1)
