root/radiance/ray/doc/man/man1/rxpiece.1
Revision: 1.1
Committed: Wed Jun 4 20:32:24 2025 UTC (11 days, 13 hours ago) by greg
feat(rxpiece): Added rxpiece to standard distribution
1 .\" RCSid "$Id: rpiece.1,v 1.4 2018/03/20 02:40:38 greg Exp $"
2 .TH RXPIECE 1 6/4/2025 RADIANCE
3 .SH NAME
4 rxpiece - render tiles in a RADIANCE picture/depth buffer
5 .SH SYNOPSIS
6 .B rxpiece
7 [
8 .B "\-n nproc"
9 ][
10 .B "\-x xres"
11 ][
12 .B "\-y yres"
13 ][
14 .B "\-X xdiv"
15 ][
16 .B "\-Y ydiv"
17 ][
18 .B "\-f{f|c}"
19 ][
20 .B "\-d ref_depth/unit"
21 ]
22 [
23 .B $EVAR
24 ]
25 [
26 .B @file
27 ]
28 [
29 rpict options
30 ]
31 .B "\-o picture"
32 .B octree
33 .SH DESCRIPTION
34 .I Rxpiece
35 renders a RADIANCE picture a tile at a time.
36 This is useful for running multiple cooperating
37 processes to create a single picture.
38 Output is written to a memory-mapped file specified with the
39 .I \-o
40 argument.
41 The format will be determined by the
42 .I \-p
43 and
44 .I \-f
45 options.
46 The first is detailed in the
47 .I rpict(1)
48 man page, and the second may be
49 .I \-fc
50 for uncompressed common-exponent format or
51 .I \-ff
52 for float picture (matrix) output.
53 An output depth map may be given as well with the
54 .I \-z
55 option, which will be stored as raw float by default,
56 but can be written as a 16-bit/depth encoding if the
57 .I \-d
58 option is used to specify a reference depth/unit.
59 (See
60 .I rcode_depth(1).)
61 .PP
62 The overall picture dimensions will be
63 .I xres
64 by
65 .I yres
66 or smaller, depending on the
67 .I \-pa
68 option and other view options, and the picture will be rendered in
69 .I xdiv
70 by
71 .I ydiv
72 tiles.
73 .PP
74 If the output picture file already exists, new tiles will
75 be rendered into it.
76 In this way, multiple invocations of
77 .I rxpiece
78 may be used with or without the
79 .I \-n
80 multiprocessing option.
81 .PP
82 Options may be given on the command line and/or read from the
83 environment and/or read from a file.
84 A command argument beginning with a dollar sign ('$') is immediately
85 replaced by the contents of the given environment variable.
86 A command argument beginning with an at sign ('@') is immediately
87 replaced by the contents of the given file.
88 .SH EXAMPLE
89 Run 8
90 .I rxpiece
91 processes and create an encoded depth map with a 10-meter reference:
92 .IP "" .2i
93 rxpiece -n 8 -d 10/meter -z scene.dpt -o scene.hdr scene.oct
94 .SH NOTES
95 Unfortunately, memory-mapped files are not supported across a
96 network, so
97 .I rxpiece
98 only works on a single machine.
99 If network rendering is desired, use
100 .I rpiece(1),
101 instead.
102 .PP
103 The main advantage of
104 .I rxpiece
105 over
106 .I rpiece
107 is the
108 .I \-n
109 multiprocessing option, which requires only a single invocation
110 to render a tiled picture efficiently.
111 .I Rxpiece
112 also supports more output types and options, such as float and
113 depth map results.
114 Because it avoids the need for a sync file, preferring a shared
115 memory map, tile assignment and recovery is faster and more robust
116 on a single machine.
117 .PP
118 The output picture is not run-length encoded, and can be quite
119 large.
120 Once the picture is finished, the
121 .I ra_rgbe(1)
122 program with the \-r option may be used to convert to a run\-length
123 encoded picture for more efficient storage, although
124 .I pfilt(1)
125 or any of the other Radiance picture filters will do the same
126 thing.
127 .PP
128 The ALRM signal may be used to gracefully terminate an
129 .I rxpiece
130 process after it finishes the tile it is working on.
131 This permits other currently running or subsequently started
132 .I rxpiece
133 process(es) to continue rendering tiles with no lost effort.
134 .SH AUTHOR
135 Greg Ward
136 .SH "SEE ALSO"
137 getinfo(1), pfilt(1), ra_rgbe(1), rcode_depth(1), rcomb(1),
138 rmtxop(1), rpict(1), rpiece(1), rtpict(1), ximage(1)
