root/Development/ray/doc/man/man1/rxfluxmtx.1
Revision: 1.4
Committed: Fri Nov 14 23:51:42 2025 UTC (8 days, 23 hours ago) by greg
Changes since 1.3: +18 -1 lines
feat(rfluxmtx,rxfluxmtx): Added bin sample jittering for smoother visual results
1 .\" RCSid "$Id: rxfluxmtx.1,v 1.3 2025/11/10 23:35:55 greg Exp $"
2 .TH RXFLUXMTX 1 10/23/2025 RADIANCE
3 .SH NAME
4 rxfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5 .SH SYNOPSIS
6 .B rxfluxmtx
7 [
8 .B \-W
9 ][
10 .B "-bj frac"
11 ] [
12 .B "rcontrib options"
13 ]
14 .B "{ sender.rad | view | - }"
15 .B receivers.rad
16 .B "[ -i system.oct ]"
17 .B "[ system.rad .. ]"
18 .SH DESCRIPTION
19 .I rxfluxmtx
20 samples rays uniformly over the surface given in
21 .I sender.rad
22 and records rays arriving at surfaces in the file
23 .I receivers.rad,
24 producing a flux transfer matrix per receiver.
25 A system octree to which the receivers will be appended may be given with a
26 .I \-i
27 option following the receiver file.
28 Additional system surfaces may be given in one or more
29 .I system.rad
30 files, which are compiled before the receiver file into an octree used
31 to perform the simulation.
32 .PP
33 If a single hyphen ('-') is given in place of the view or sender file, then
34 .I rxfluxmtx
35 computes matrix rows based upon the provided ray sample origins and directions,
36 which may be surface normals if the
37 .I \-I+
38 option is applied.
39 The
40 .I \-y
41 option is required to specify the number of output rows for pass-through mode.
42 .PP
43 Alternatively, a view specification may be given on the command-line
44 to produce coefficient picture output, in which case both the
45 .I \-x
46 and
47 .I \-y
48 options must be present to set the desired picture dimensions.
49 The related
50 .I \-pj,
51 .I \-pd,
52 and
53 .I \-pa
54 options may be used to set the pixel jitter, depth-of-field, and
55 aspect ratio, respectively.
56 This avoids the need to call
57 .I vwrays(1),
58 as required by
59 .I rfluxmtx.
60 .PP
61 The
62 .I \-W+
63 option turns on verbose mode, and the
64 .I \-t
65 option sets the number of seconds between progress reports, similar to
66 .I rcontrib(1).
67 Likewise, the
68 .I \-c
69 option specifies the number of times to repeat each sample.
70 However, the
71 .I rcontrib
72 options
73 .I \-p,
74 .I \-b,
75 .I \-bn,
76 .I \-m,
77 and
78 .I \-M
79 options are controlled by
80 .I rxfluxmtx
81 and may not be set by the user.
82 .PP
83 The
84 .I \-bj
85 option sets the amount of bin jittering, which blurs the boundaries of
86 receiver bins and is generally recommended when creating a view that may
87 include direct visibility of the receiver surface(s).
88 It is best used in combination with the
89 .I \-c
90 and
91 .I \-pj
92 options described above.
93 (The default jitter is 0, leaving sharp bin boundaries.)\0
94 .PP
95 The sample count, unless set by the
96 .I \-c
97 option, defaults to 10000 when a sender file is given, or to 1 for
98 view and pass-through modes.
99 .SH VARIABLES
100 The sender and receiver scene files given to
101 .I rxfluxmtx
102 contain controlling parameters in special comments of the form:
103 .nf
104
105 #@rxfluxmtx variable=value ..
106 or:
107 #@rfluxmtx variable=value ..
108
109 .fi
110 At minimum, both sender and receiver must specify one of the
111 hemisphere sampling types, and there must be at least
112 one surface in each file.
113 .TP 10n
114 .BI h =u
115 Set hemisphere sampling to "uniform," meaning a single bin
116 of (cosine-distributed) samples.
117 In the case of distant "source" primitives, this is the only
118 sampling method that supports arbitrary receiver sizes.
119 The other methods below require a full hemispherical source.
120 .TP
121 .BI h =kf
122 Divide the hemisphere using the LBNL/Klems "full" sampling basis.
123 (Use "h=-kf" for left-handed coordinates.)
124 .TP
125 .BI h =kh
126 Divide the hemisphere using the LBNL/Klems "half" sampling basis.
127 (Use "h=-kh" for left-handed coordinates.)
128 .TP
129 .BI h =kq
130 Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
131 (Use "h=-kq" for left-handed coordinates.)
132 .TP
133 .BI h =rN
134 Divide the hemisphere using Reinhart's substructuring of the Tregenza
135 sky pattern with
136 .I N
137 divisions in each dimension.
138 If it is not given,
139 .I N
140 defaults to 1, which is just the Tregenza sky.
141 (Use "h=-rN" for left-handed coordinates.)
142 .TP
143 .BI h =cie
144 Divide the hemisphere into CIE sky scanner directions, which is
145 similar to Tregenza but with different starting azimuths and
146 reversing row direction at each new altitude.
147 (Use "h=-cie" for left-handed coordinates.)
148 .TP
149 .BI h =scN
150 Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
151 .I NxN
152 grid over the square.
153 (Use "h=-scN" for left-handed coordinates.)
154 .TP
155 .BI u =[-]{X|Y|Z|ux,uy,uz}
156 Orient the "up" direction for the hemisphere using the indicated axis or direction
157 vector.
158 .TP
159 .BI o =output_spec
160 Send the matrix data for this receiver to the indicated file specification.
161 Single or double quotes may be used to contain strings with spaces, and
162 the usual "%s" and "%d" formats incorporate the modifier name and/or
163 bin number, as with
164 .I rcontrib.
165 Command (piped) output is not supported.
166 .PP
167 If no output_spec directive is given, it must be specified by a
168 .I \-o
169 setting on the command-line, since output to stdout is not supported.
170 The input and output file formats are controlled by the
171 .I \-fio
172 option, which may use a single letter for identical i/o formats.
173 The input format matters only in pass-through mode, for which
174 ASCII input is supported.
175 The default setting is
176 .I \-faf.
177 ASCII output is unsupported, since it interferes with
178 efficient recovery when using the
179 .I \-r
180 option.
181 .PP
182 In normal execution, only a single sender surface is sampled, but it may be
183 comprised of any number of subsurfaces, as in a triangle mesh or similar.
184 The surface normal will be computed as the average of all the constituent
185 subsurfaces.
186 The subsurfaces themselves must be planar, thus only
187 .I polygon
188 and
189 .I ring
190 surface primitives are supported.
191 Other primitives will be silently ignored and will have no effect on the calculation.
192 .PP
193 In the receiver file, the
194 .I source
195 primitive is supported as well, and multiple receivers (and multiple output
196 matrices) may be identified by different modifier names.
197 (Make sure that surfaces using the same modifier are grouped together,
198 and that the modifiers are unique and not used elsewhere in the
199 scene description.)\0
200 Though it may be counter-intuitive, receivers are often light sources,
201 since samples end up there in a backwards ray-tracing system such as RADIANCE.
202 When using local geometry, the overall aperture shape should be close to flat.
203 Large displacements may give rise to errors due to a convex receiver's
204 larger profile at low angles of incidence.
205 .PP
206 Rays always emanate from the back side of the sender surface and arrive at the
207 front side of receiver surfaces.
208 In this way, a receiver surface may be reused as a sender in a subsequent
209 .I rxfluxmtx
210 calculation and the resulting matrices will concatenate properly.
211 (Note that it is important to keep receiver surfaces together, otherwise a
212 "duplicate modifier" error will result.)\0
213 .SH EXAMPLES
214 To generate a flux transfer matrix connecting input and output apertures
215 on a light pipe:
216 .IP "" .2i
217 rxfluxmtx -o lpipe.mtx int_aperture.rad ext_aperture.rad lpipe.rad
218 .PP
219 To generate a set of DC view component pictures with 9 jittered samples/pixel:
220 .IP "" .2i
221 rxfluxmtx -vf v1.vf -x 512 -y 512 -c 9 -pj .8 -fc reinhart_M4.rad -i scene1.oct
222 .PP
223 To compute a workplane irradiance matrix for each window in a space:
224 .IP "" .2i
225 rxfluxmtx -faf - windows_kf.rad -i scene2.oct < workplane_pts.txt
226 .SH NOTES
227 The main differences between
228 .I rfluxmtx(1)
229 and
230 .I rxfluxmtx
231 is that the latter does not run a separate
232 .I rcontrib
233 process.
234 Instead, it relies on a unix-only C++ class definition that offers full
235 control over i/o.
236 This allows an unlimited number of receivers, a
237 .I \-r
238 recovery option, and streamlines operations.
239 .SH AUTHOR
240 Greg Ward
241 .SH "SEE ALSO"
242 genBSDF(1), getinfo(1), pvsum(1), rcalc(1), rcollate(1), rcomb(1), rcontrib(1),
243 rcrop(1), rfluxmtx(1), rmtxop(1), vwrays(1), wrapBSDF(1)
