| 1 |
.\" RCSid "$Id: rxfluxmtx.1,v 1.2 2025/10/24 16:52:14 greg Exp $"
| 2 |
.TH RXFLUXMTX 1 10/23/2025 RADIANCE
| 3 |
.SH NAME
| 4 |
rxfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rxfluxmtx
| 7 |
| 8 |
.B \-W
| 9 |
| 10 |
.B "rcontrib options"
| 11 |
| 12 |
.B "{ sender.rad | view | - }"
| 13 |
.B receivers.rad
| 14 |
.B "[ -i system.oct ]"
| 15 |
.B "[ system.rad .. ]"
| 16 |
.SH DESCRIPTION
| 17 |
.I rxfluxmtx
| 18 |
samples rays uniformly over the surface given in
| 19 |
.I sender.rad
| 20 |
and records rays arriving at surfaces in the file
| 21 |
.I receivers.rad,
| 22 |
producing a flux transfer matrix per receiver.
| 23 |
A system octree to which the receivers will be appended may be given with a
| 24 |
.I \-i
| 25 |
option following the receiver file.
| 26 |
Additional system surfaces may be given in one or more
| 27 |
.I system.rad
| 28 |
files, which are compiled before the receiver file into an octree used
| 29 |
to perform the simulation.
| 30 |
.PP
| 31 |
If a single hyphen ('-') is given in place of the view or sender file, then
| 32 |
.I rxfluxmtx
| 33 |
computes matrix rows based upon the provided ray sample origins and directions,
| 34 |
which may be surface normals if the
| 35 |
.I \-I+
| 36 |
option is applied.
| 37 |
The
| 38 |
.I \-y
| 39 |
option is required to specify the number of output rows for pass-through mode.
| 40 |
.PP
| 41 |
Alternatively, a view specification may be given on the command-line
| 42 |
to produce coefficient picture output, in which case both the
| 43 |
.I \-x
| 44 |
and
| 45 |
.I \-y
| 46 |
options must be present to set the desired picture dimensions.
| 47 |
The related
| 48 |
.I \-pj,
| 49 |
.I \-pd,
| 50 |
and
| 51 |
.I \-pa
| 52 |
options may be used to set the pixel jitter, depth-of-field, and
| 53 |
aspect ratio, respectively.
| 54 |
This avoids the need to call
| 55 |
.I vwrays(1),
| 56 |
as required by
| 57 |
.I rfluxmtx.
| 58 |
.PP
| 59 |
The
| 60 |
.I \-W+
| 61 |
option turns on verbose mode, and the
| 62 |
.I \-t
| 63 |
option sets the number of seconds between progress reports, similar to
| 64 |
.I rcontrib(1).
| 65 |
However, the
| 66 |
.I rcontrib
| 67 |
options
| 68 |
.I \-p,
| 69 |
.I \-b,
| 70 |
.I \-bn,
| 71 |
.I \-m,
| 72 |
and
| 73 |
.I \-M
| 74 |
options are controlled by
| 75 |
.I rxfluxmtx
| 76 |
and may not be set by the user.
| 77 |
.PP
| 78 |
The sample count, unless set by the
| 79 |
.I \-c
| 80 |
option, defaults to 10000 when a sender file is given, or to 1 for
| 81 |
view and pass-through modes.
| 82 |
.SH VARIABLES
| 83 |
The sender and receiver scene files given to
| 84 |
.I rxfluxmtx
| 85 |
contain controlling parameters in special comments of the form:
| 86 |
.nf
| 87 |
| 88 |
#@rxfluxmtx variable=value ..
| 89 |
or:
| 90 |
#@rfluxmtx variable=value ..
| 91 |
| 92 |
.fi
| 93 |
At minimum, both sender and receiver must specify one of the
| 94 |
hemisphere sampling types, and there must be at least
| 95 |
one surface in each file.
| 96 |
.TP 10n
| 97 |
.BI h =u
| 98 |
Set hemisphere sampling to "uniform," meaning a single bin
| 99 |
of (cosine-distributed) samples.
| 100 |
In the case of distant "source" primitives, this is the only
| 101 |
sampling method that supports arbitrary receiver sizes.
| 102 |
The other methods below require a full hemispherical source.
| 103 |
.TP
| 104 |
.BI h =kf
| 105 |
Divide the hemisphere using the LBNL/Klems "full" sampling basis.
| 106 |
(Use "h=-kf" for left-handed coordinates.)
| 107 |
.TP
| 108 |
.BI h =kh
| 109 |
Divide the hemisphere using the LBNL/Klems "half" sampling basis.
| 110 |
(Use "h=-kh" for left-handed coordinates.)
| 111 |
.TP
| 112 |
.BI h =kq
| 113 |
Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
| 114 |
(Use "h=-kq" for left-handed coordinates.)
| 115 |
.TP
| 116 |
.BI h =rN
| 117 |
Divide the hemisphere using Reinhart's substructuring of the Tregenza
| 118 |
sky pattern with
| 119 |
.I N
| 120 |
divisions in each dimension.
| 121 |
If it is not given,
| 122 |
.I N
| 123 |
defaults to 1, which is just the Tregenza sky.
| 124 |
(Use "h=-rN" for left-handed coordinates.)
| 125 |
.TP
| 126 |
.BI h =cie
| 127 |
Divide the hemisphere into CIE sky scanner directions, which is
| 128 |
similar to Tregenza but with different starting azimuths and
| 129 |
reversing row direction at each new altitude.
| 130 |
(Use "h=-cie" for left-handed coordinates.)
| 131 |
.TP
| 132 |
.BI h =scN
| 133 |
Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
| 134 |
.I NxN
| 135 |
grid over the square.
| 136 |
(Use "h=-scN" for left-handed coordinates.)
| 137 |
.TP
| 138 |
.BI u =[-]{X|Y|Z|ux,uy,uz}
| 139 |
Orient the "up" direction for the hemisphere using the indicated axis or direction
| 140 |
vector.
| 141 |
.TP
| 142 |
.BI o =output_spec
| 143 |
Send the matrix data for this receiver to the indicated file specification.
| 144 |
Single or double quotes may be used to contain strings with spaces, and
| 145 |
the usual "%s" and "%d" formats incorporate the modifier name and/or
| 146 |
bin number, as with
| 147 |
.I rcontrib.
| 148 |
Command (piped) output is not supported.
| 149 |
.PP
| 150 |
If no output_spec directive is given, it must be specified by a
| 151 |
.I \-o
| 152 |
setting on the command-line, since output to stdout is not supported.
| 153 |
The input and output file formats are controlled by the
| 154 |
.I \-fio
| 155 |
option, which may use a single letter for identical i/o formats.
| 156 |
The input format matters only in pass-through mode, for which
| 157 |
ASCII input is supported.
| 158 |
The default setting is
| 159 |
.I \-faf.
| 160 |
ASCII output is unsupported, since it interferes with
| 161 |
efficient recovery when using the
| 162 |
.I \-r
| 163 |
option.
| 164 |
.PP
| 165 |
In normal execution, only a single sender surface is sampled, but it may be
| 166 |
comprised of any number of subsurfaces, as in a triangle mesh or similar.
| 167 |
The surface normal will be computed as the average of all the constituent
| 168 |
subsurfaces.
| 169 |
The subsurfaces themselves must be planar, thus only
| 170 |
.I polygon
| 171 |
and
| 172 |
.I ring
| 173 |
surface primitives are supported.
| 174 |
Other primitives will be silently ignored and will have no effect on the calculation.
| 175 |
.PP
| 176 |
In the receiver file, the
| 177 |
.I source
| 178 |
primitive is supported as well, and multiple receivers (and multiple output
| 179 |
matrices) may be identified by different modifier names.
| 180 |
(Make sure that surfaces using the same modifier are grouped together,
| 181 |
and that the modifiers are unique and not used elsewhere in the
| 182 |
scene description.)\0
| 183 |
Though it may be counter-intuitive, receivers are often light sources,
| 184 |
since samples end up there in a backwards ray-tracing system such as RADIANCE.
| 185 |
When using local geometry, the overall aperture shape should be close to flat.
| 186 |
Large displacements may give rise to errors due to a convex receiver's
| 187 |
larger profile at low angles of incidence.
| 188 |
.PP
| 189 |
Rays always emanate from the back side of the sender surface and arrive at the
| 190 |
front side of receiver surfaces.
| 191 |
In this way, a receiver surface may be reused as a sender in a subsequent
| 192 |
.I rxfluxmtx
| 193 |
calculation and the resulting matrices will concatenate properly.
| 194 |
(Note that it is important to keep receiver surfaces together, otherwise a
| 195 |
"duplicate modifier" error will result.)\0
| 196 |
.SH EXAMPLES
| 197 |
To generate a flux transfer matrix connecting input and output apertures
| 198 |
on a light pipe:
| 199 |
.IP "" .2i
| 200 |
rxfluxmtx -o lpipe.mtx int_aperture.rad ext_aperture.rad lpipe.rad
| 201 |
.PP
| 202 |
To generate a set of DC view component pictures with 9 jittered samples/pixel:
| 203 |
.IP "" .2i
| 204 |
rxfluxmtx -vf v1.vf -x 512 -y 512 -c 9 -pj .8 -fc reinhart_M4.rad -i scene1.oct
| 205 |
.PP
| 206 |
To compute a workplane irradiance matrix for each window in a space:
| 207 |
.IP "" .2i
| 208 |
rxfluxmtx -faf - windows_kf.rad -i scene2.oct < workplane_pts.txt
| 209 |
.SH NOTES
| 210 |
The main differences between
| 211 |
.I rfluxmtx(1)
| 212 |
and
| 213 |
.I rxfluxmtx
| 214 |
is that the latter does not run a separate
| 215 |
.I rcontrib
| 216 |
process.
| 217 |
Instead, it relies on a unix-only C++ class definition that offers full
| 218 |
control over i/o.
| 219 |
This allows an unlimited number of receivers, a
| 220 |
.I \-r
| 221 |
recovery option, and streamlines operations.
| 222 |
.SH AUTHOR
| 223 |
Greg Ward
| 224 |
.SH "SEE ALSO"
| 225 |
genBSDF(1), getinfo(1), pvsum(1), rcalc(1), rcollate(1), rcomb(1), rcontrib(1),
| 226 |
rcrop(1), rfluxmtx(1), rmtxop(1), vwrays(1), wrapBSDF(1)
