root/Development/ray/doc/man/man1/rxfluxmtx.1
Revision: 1.4
Committed: Fri Nov 14 23:51:42 2025 UTC (21 hours, 16 minutes ago) by greg
Changes since 1.3: +18 -1 lines
feat(rfluxmtx,rxfluxmtx): Added bin sample jittering for smoother visual results
# User Rev Content
1 greg 1.4 .\" RCSid "$Id: rxfluxmtx.1,v 1.3 2025/11/10 23:35:55 greg Exp $"
2 greg 1.1 .TH RXFLUXMTX 1 10/23/2025 RADIANCE
3     .SH NAME
4     rxfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5     .SH SYNOPSIS
6     .B rxfluxmtx
7     [
8     .B \-W
9 greg 1.4 ][
10     .B "-bj frac"
11 greg 1.1 ] [
12     .B "rcontrib options"
13     ]
14     .B "{ sender.rad | view | - }"
15     .B receivers.rad
16     .B "[ -i system.oct ]"
17     .B "[ system.rad .. ]"
18     .SH DESCRIPTION
19     .I rxfluxmtx
20     samples rays uniformly over the surface given in
21     .I sender.rad
22     and records rays arriving at surfaces in the file
23     .I receivers.rad,
24     producing a flux transfer matrix per receiver.
25     A system octree to which the receivers will be appended may be given with a
26     .I \-i
27     option following the receiver file.
28     Additional system surfaces may be given in one or more
29     .I system.rad
30     files, which are compiled before the receiver file into an octree used
31     to perform the simulation.
32     .PP
33     If a single hyphen ('-') is given in place of the view or sender file, then
34     .I rxfluxmtx
35     computes matrix rows based upon the provided ray sample origins and directions,
36     which may be surface normals if the
37     .I \-I+
38     option is applied.
39     The
40     .I \-y
41     option is required to specify the number of output rows for pass-through mode.
42     .PP
43     Alternatively, a view specification may be given on the command-line
44     to produce coefficient picture output, in which case both the
45     .I \-x
46     and
47     .I \-y
48     options must be present to set the desired picture dimensions.
49     The related
50     .I \-pj,
51     .I \-pd,
52     and
53     .I \-pa
54     options may be used to set the pixel jitter, depth-of-field, and
55     aspect ratio, respectively.
56     This avoids the need to call
57     .I vwrays(1),
58     as required by
59     .I rfluxmtx.
60     .PP
61     The
62     .I \-W+
63     option turns on verbose mode, and the
64     .I \-t
65     option sets the number of seconds between progress reports, similar to
66     .I rcontrib(1).
67 greg 1.4 Likewise, the
68     .I \-c
69     option specifies the number of times to repeat each sample.
70 greg 1.1 However, the
71     .I rcontrib
72     options
73     .I \-p,
74     .I \-b,
75     .I \-bn,
76     .I \-m,
77     and
78     .I \-M
79     options are controlled by
80     .I rxfluxmtx
81     and may not be set by the user.
82     .PP
83 greg 1.4 The
84     .I \-bj
85     option sets the amount of bin jittering, which blurs the boundaries of
86     receiver bins and is generally recommended when creating a view that may
87     include direct visibility of the receiver surface(s).
88     It is best used in combination with the
89     .I \-c
90     and
91     .I \-pj
92     options described above.
93     (The default jitter is 0, leaving sharp bin boundaries.)\0
94     .PP
95 greg 1.1 The sample count, unless set by the
96     .I \-c
97     option, defaults to 10000 when a sender file is given, or to 1 for
98     view and pass-through modes.
99     .SH VARIABLES
100     The sender and receiver scene files given to
101     .I rxfluxmtx
102     contain controlling parameters in special comments of the form:
103     .nf
104
105     #@rxfluxmtx variable=value ..
106     or:
107     #@rfluxmtx variable=value ..
108
109     .fi
110     At minimum, both sender and receiver must specify one of the
111     hemisphere sampling types, and there must be at least
112     one surface in each file.
113     .TP 10n
114     .BI h =u
115     Set hemisphere sampling to "uniform," meaning a single bin
116     of (cosine-distributed) samples.
117     In the case of distant "source" primitives, this is the only
118     sampling method that supports arbitrary receiver sizes.
119     The other methods below require a full hemispherical source.
120     .TP
121     .BI h =kf
122     Divide the hemisphere using the LBNL/Klems "full" sampling basis.
123     (Use "h=-kf" for left-handed coordinates.)
124     .TP
125     .BI h =kh
126     Divide the hemisphere using the LBNL/Klems "half" sampling basis.
127     (Use "h=-kh" for left-handed coordinates.)
128     .TP
129     .BI h =kq
130     Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
131     (Use "h=-kq" for left-handed coordinates.)
132     .TP
133     .BI h =rN
134     Divide the hemisphere using Reinhart's substructuring of the Tregenza
135     sky pattern with
136     .I N
137     divisions in each dimension.
138     If it is not given,
139     .I N
140     defaults to 1, which is just the Tregenza sky.
141     (Use "h=-rN" for left-handed coordinates.)
142     .TP
143     .BI h =cie
144     Divide the hemisphere into CIE sky scanner directions, which is
145     similar to Tregenza but with different starting azimuths and
146     reversing row direction at each new altitude.
147     (Use "h=-cie" for left-handed coordinates.)
148     .TP
149     .BI h =scN
150     Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
151     .I NxN
152     grid over the square.
153     (Use "h=-scN" for left-handed coordinates.)
154     .TP
155     .BI u =[-]{X|Y|Z|ux,uy,uz}
156     Orient the "up" direction for the hemisphere using the indicated axis or direction
157     vector.
158     .TP
159     .BI o =output_spec
160 greg 1.2 Send the matrix data for this receiver to the indicated file specification.
161     Single or double quotes may be used to contain strings with spaces, and
162     the usual "%s" and "%d" formats incorporate the modifier name and/or
163     bin number, as with
164     .I rcontrib.
165 greg 1.1 Command (piped) output is not supported.
166 greg 1.2 .PP
167     If no output_spec directive is given, it must be specified by a
168     .I \-o
169     setting on the command-line, since output to stdout is not supported.
170     The input and output file formats are controlled by the
171 greg 1.1 .I \-fio
172 greg 1.2 option, which may use a single letter for identical i/o formats.
173     The input format matters only in pass-through mode, for which
174 greg 1.1 ASCII input is supported.
175 greg 1.3 The default setting is
176     .I \-faf.
177 greg 1.1 ASCII output is unsupported, since it interferes with
178 greg 1.3 efficient recovery when using the
179 greg 1.1 .I \-r
180 greg 1.3 option.
181 greg 1.1 .PP
182     In normal execution, only a single sender surface is sampled, but it may be
183     comprised of any number of subsurfaces, as in a triangle mesh or similar.
184     The surface normal will be computed as the average of all the constituent
185     subsurfaces.
186     The subsurfaces themselves must be planar, thus only
187     .I polygon
188     and
189     .I ring
190     surface primitives are supported.
191     Other primitives will be silently ignored and will have no effect on the calculation.
192     .PP
193     In the receiver file, the
194     .I source
195     primitive is supported as well, and multiple receivers (and multiple output
196     matrices) may be identified by different modifier names.
197     (Make sure that surfaces using the same modifier are grouped together,
198     and that the modifiers are unique and not used elsewhere in the
199     scene description.)\0
200     Though it may be counter-intuitive, receivers are often light sources,
201     since samples end up there in a backwards ray-tracing system such as RADIANCE.
202     When using local geometry, the overall aperture shape should be close to flat.
203     Large displacements may give rise to errors due to a convex receiver's
204     larger profile at low angles of incidence.
205     .PP
206     Rays always emanate from the back side of the sender surface and arrive at the
207     front side of receiver surfaces.
208     In this way, a receiver surface may be reused as a sender in a subsequent
209     .I rxfluxmtx
210     calculation and the resulting matrices will concatenate properly.
211     (Note that it is important to keep receiver surfaces together, otherwise a
212     "duplicate modifier" error will result.)\0
213     .SH EXAMPLES
214     To generate a flux transfer matrix connecting input and output apertures
215     on a light pipe:
216     .IP "" .2i
217 greg 1.3 rxfluxmtx -o lpipe.mtx int_aperture.rad ext_aperture.rad lpipe.rad
218 greg 1.1 .PP
219 greg 1.2 To generate a set of DC view component pictures with 9 jittered samples/pixel:
220 greg 1.1 .IP "" .2i
221 greg 1.2 rxfluxmtx -vf v1.vf -x 512 -y 512 -c 9 -pj .8 -fc reinhart_M4.rad -i scene1.oct
222 greg 1.1 .PP
223     To compute a workplane irradiance matrix for each window in a space:
224     .IP "" .2i
225     rxfluxmtx -faf - windows_kf.rad -i scene2.oct < workplane_pts.txt
226     .SH NOTES
227     The main differences between
228     .I rfluxmtx(1)
229     and
230     .I rxfluxmtx
231     is that the latter does not run a separate
232     .I rcontrib
233     process.
234     Instead, it relies on a unix-only C++ class definition that offers full
235     control over i/o.
236     This allows an unlimited number of receivers, a
237     .I \-r
238 greg 1.3 recovery option, and streamlines operations.
239 greg 1.1 .SH AUTHOR
240     Greg Ward
241     .SH "SEE ALSO"
242     genBSDF(1), getinfo(1), pvsum(1), rcalc(1), rcollate(1), rcomb(1), rcontrib(1),
243     rcrop(1), rfluxmtx(1), rmtxop(1), vwrays(1), wrapBSDF(1)
