root/Development/ray/doc/man/man1/rxfluxmtx.1
Revision: 1.2
Committed: Fri Oct 24 16:52:14 2025 UTC (2 weeks, 2 days ago) by greg
Changes since 1.1: +17 -8 lines
docs(rxfluxmtx): wording corrections and clarifications
1 .\" RCSid "$Id: rxfluxmtx.1,v 1.1 2025/10/23 23:34:59 greg Exp $"
2 .TH RXFLUXMTX 1 10/23/2025 RADIANCE
3 .SH NAME
4 rxfluxmtx - compute flux transfer matrix(es) for RADIANCE scene
5 .SH SYNOPSIS
6 .B rxfluxmtx
7 [
8 .B \-W
9 ] [
10 .B "rcontrib options"
11 ]
12 .B "{ sender.rad | view | - }"
13 .B receivers.rad
14 .B "[ -i system.oct ]"
15 .B "[ system.rad .. ]"
16 .SH DESCRIPTION
17 .I rxfluxmtx
18 samples rays uniformly over the surface given in
19 .I sender.rad
20 and records rays arriving at surfaces in the file
21 .I receivers.rad,
22 producing a flux transfer matrix per receiver.
23 A system octree to which the receivers will be appended may be given with a
24 .I \-i
25 option following the receiver file.
26 Additional system surfaces may be given in one or more
27 .I system.rad
28 files, which are compiled before the receiver file into an octree used
29 to perform the simulation.
30 .PP
31 If a single hyphen ('-') is given in place of the view or sender file, then
32 .I rxfluxmtx
33 computes matrix rows based upon the provided ray sample origins and directions,
34 which may be surface normals if the
35 .I \-I+
36 option is applied.
37 The
38 .I \-y
39 option is required to specify the number of output rows for pass-through mode.
40 .PP
41 Alternatively, a view specification may be given on the command-line
42 to produce coefficient picture output, in which case both the
43 .I \-x
44 and
45 .I \-y
46 options must be present to set the desired picture dimensions.
47 The related
48 .I \-pj,
49 .I \-pd,
50 and
51 .I \-pa
52 options may be used to set the pixel jitter, depth-of-field, and
53 aspect ratio, respectively.
54 This avoids the need to call
55 .I vwrays(1),
56 as required by
57 .I rfluxmtx.
58 .PP
59 The
60 .I \-W+
61 option turns on verbose mode, and the
62 .I \-t
63 option sets the number of seconds between progress reports, similar to
64 .I rcontrib(1).
65 However, the
66 .I rcontrib
67 options
68 .I \-p,
69 .I \-b,
70 .I \-bn,
71 .I \-m,
72 and
73 .I \-M
74 options are controlled by
75 .I rxfluxmtx
76 and may not be set by the user.
77 .PP
78 The sample count, unless set by the
79 .I \-c
80 option, defaults to 10000 when a sender file is given, or to 1 for
81 view and pass-through modes.
82 .SH VARIABLES
83 The sender and receiver scene files given to
84 .I rxfluxmtx
85 contain controlling parameters in special comments of the form:
86 .nf
87
88 #@rxfluxmtx variable=value ..
89 or:
90 #@rfluxmtx variable=value ..
91
92 .fi
93 At minimum, both sender and receiver must specify one of the
94 hemisphere sampling types, and there must be at least
95 one surface in each file.
96 .TP 10n
97 .BI h =u
98 Set hemisphere sampling to "uniform," meaning a single bin
99 of (cosine-distributed) samples.
100 In the case of distant "source" primitives, this is the only
101 sampling method that supports arbitrary receiver sizes.
102 The other methods below require a full hemispherical source.
103 .TP
104 .BI h =kf
105 Divide the hemisphere using the LBNL/Klems "full" sampling basis.
106 (Use "h=-kf" for left-handed coordinates.)
107 .TP
108 .BI h =kh
109 Divide the hemisphere using the LBNL/Klems "half" sampling basis.
110 (Use "h=-kh" for left-handed coordinates.)
111 .TP
112 .BI h =kq
113 Divide the hemisphere using the LBNL/Klems "quarter" sampling basis.
114 (Use "h=-kq" for left-handed coordinates.)
115 .TP
116 .BI h =rN
117 Divide the hemisphere using Reinhart's substructuring of the Tregenza
118 sky pattern with
119 .I N
120 divisions in each dimension.
121 If it is not given,
122 .I N
123 defaults to 1, which is just the Tregenza sky.
124 (Use "h=-rN" for left-handed coordinates.)
125 .TP
126 .BI h =cie
127 Divide the hemisphere into CIE sky scanner directions, which is
128 similar to Tregenza but with different starting azimuths and
129 reversing row direction at each new altitude.
130 (Use "h=-cie" for left-handed coordinates.)
131 .TP
132 .BI h =scN
133 Subdivide the hemisphere using the Shirley-Chiu square-to-disk mapping with an
134 .I NxN
135 grid over the square.
136 (Use "h=-scN" for left-handed coordinates.)
137 .TP
138 .BI u =[-]{X|Y|Z|ux,uy,uz}
139 Orient the "up" direction for the hemisphere using the indicated axis or direction
140 vector.
141 .TP
142 .BI o =output_spec
143 Send the matrix data for this receiver to the indicated file specification.
144 Single or double quotes may be used to contain strings with spaces, and
145 the usual "%s" and "%d" formats incorporate the modifier name and/or
146 bin number, as with
147 .I rcontrib.
148 Command (piped) output is not supported.
149 .PP
150 If no output_spec directive is given, it must be specified by a
151 .I \-o
152 setting on the command-line, since output to stdout is not supported.
153 The input and output file formats are controlled by the
154 .I \-fio
155 option, which may use a single letter for identical i/o formats.
156 The input format matters only in pass-through mode, for which
157 ASCII input is supported.
158 ASCII output is unsupported, since it interferes with
159 efficient recovery in the
160 .I \-r
161 mode.
162 The default setting is
163 .I \-faf.
164 .PP
165 In normal execution, only a single sender surface is sampled, but it may be
166 comprised of any number of subsurfaces, as in a triangle mesh or similar.
167 The surface normal will be computed as the average of all the constituent
168 subsurfaces.
169 The subsurfaces themselves must be planar, thus only
170 .I polygon
171 and
172 .I ring
173 surface primitives are supported.
174 Other primitives will be silently ignored and will have no effect on the calculation.
175 .PP
176 In the receiver file, the
177 .I source
178 primitive is supported as well, and multiple receivers (and multiple output
179 matrices) may be identified by different modifier names.
180 (Make sure that surfaces using the same modifier are grouped together,
181 and that the modifiers are unique and not used elsewhere in the
182 scene description.)\0
183 Though it may be counter-intuitive, receivers are often light sources,
184 since samples end up there in a backwards ray-tracing system such as RADIANCE.
185 When using local geometry, the overall aperture shape should be close to flat.
186 Large displacements may give rise to errors due to a convex receiver's
187 larger profile at low angles of incidence.
188 .PP
189 Rays always emanate from the back side of the sender surface and arrive at the
190 front side of receiver surfaces.
191 In this way, a receiver surface may be reused as a sender in a subsequent
192 .I rxfluxmtx
193 calculation and the resulting matrices will concatenate properly.
194 (Note that it is important to keep receiver surfaces together, otherwise a
195 "duplicate modifier" error will result.)\0
196 .SH EXAMPLES
197 To generate a flux transfer matrix connecting input and output apertures
198 on a light pipe:
199 .IP "" .2i
200 rxfluxmtx int_aperture.rad ext_aperture.rad lpipe.rad > lpipe.mtx
201 .PP
202 To generate a set of DC view component pictures with 9 jittered samples/pixel:
203 .IP "" .2i
204 rxfluxmtx -vf v1.vf -x 512 -y 512 -c 9 -pj .8 -fc reinhart_M4.rad -i scene1.oct
205 .PP
206 To compute a workplane irradiance matrix for each window in a space:
207 .IP "" .2i
208 rxfluxmtx -faf - windows_kf.rad -i scene2.oct < workplane_pts.txt
209 .SH NOTES
210 The main differences between
211 .I rfluxmtx(1)
212 and
213 .I rxfluxmtx
214 is that the latter does not run a separate
215 .I rcontrib
216 process.
217 Instead, it relies on a unix-only C++ class definition that offers full
218 control over i/o.
219 This allows an unlimited number of receivers, a
220 .I \-r
221 recovery option, and simplifies internal operations.
222 .SH AUTHOR
223 Greg Ward
224 .SH "SEE ALSO"
225 genBSDF(1), getinfo(1), pvsum(1), rcalc(1), rcollate(1), rcomb(1), rcontrib(1),
226 rcrop(1), rfluxmtx(1), rmtxop(1), vwrays(1), wrapBSDF(1)
