root/radiance/ray/doc/man/man1/rvu.1
Revision: 1.5
Committed: Thu Aug 21 07:05:58 2008 UTC (16 years, 10 months ago) by greg
CVS Tags: rad4R1, rad4R0
Changes since 1.4: +10 -3 lines
1 .\" RCSid "$Id: rvu.1,v 1.4 2005/06/14 03:34:14 greg Exp $"
2 .TH RVU 1 1/1/04 RADIANCE
3 .SH NAME
4 rvu - generate RADIANCE images interactively
5 .SH SYNOPSIS
6 .B rvu
7 [
8 .B "rpict options"
9 ][
10 .B "\-n nproc"
11 ][
12 .B "\-o dev"
13 ][
14 .B \-b
15 ][
16 .B "\-pe exposure"
17 ]
18 [
19 .B $EVAR
20 ]
21 [
22 .B @file
23 ]
24 .B octree
25 .br
26 .B "rvu [ options ] \-defaults"
27 .br
28 .B "rvu \-devices"
29 .SH DESCRIPTION
30 .I Rvu
31 generates RADIANCE images using
32 .I octree.
33 (The octree may be given as the output of a command enclosed in quotes
34 and preceded by a `!'.)\0
35 Options specify the viewing parameters as well as
36 giving some control over the calculation.
37 Options may be given on the command line and/or read from the
38 environment and/or read from a file.
39 A command argument beginning with a dollar sign ('$') is immediately
40 replaced by the contents of the given environment variable.
41 A command argument beginning with an at sign ('@') is immediately
42 replaced by the contents of the given file.
43 The options are the same as for rpict(1), with a few notable exceptions.
44 The
45 .I "\-r, \-z, \-S, \-P, \-PP"
46 and
47 .I \-t
48 options are not supported, and
49 .I \-o
50 specifies which output device is being used instead of the output
51 file.
52 The
53 .I "\-x, \-y"
54 and
55 .I \-pa
56 options are unnecessary, since
57 .I rvu
58 scales the display image to the specified output device.
59 Additionally, the
60 .I \-b
61 option improves the display on greyscale monitors, and
62 .I \-pe
63 may be used to set an initial exposure value.
64 .PP
65 The
66 .I \-n
67 option may be used to specify multiple processes,
68 to accelerate rendering.
69 .PP
70 In the second form, the default values
71 for the options are printed with a brief explanation.
72 In the third form, the list of supported output devices
73 is displayed.
74 .PP
75 .I rvu
76 starts rendering the image from the selected viewpoint and
77 gradually improves the resolution of the display until
78 interrupted by keyboard input.
79 .I rvu
80 then issues a prompt (usually ':') and accepts a command
81 line from the user.
82 .I rvu
83 may also stop its calculation and wait for command input if
84 the resolution of the display has reached the resolution of the
85 graphics device.
86 At this point, it will give the 'done:' prompt and await further
87 instructions.
88 If
89 .I rvu
90 runs out of memory due to lack of resources to store its computed
91 image, it will give the 'out of memory:' prompt.
92 At this prompt, the user can save the image, quit, or even restart
93 a new image, although this is not generally recommended
94 on virtual memory machines for efficiency reasons.
95 .PP
96 .I rvu
97 is not meant to be a rendering program, and we strongly recommend that
98 .I rpict(1)
99 be used instead for that purpose.
100 Since
101 .I rpict(1)
102 does not store its image in memory or update any display of its output,
103 it is much faster and less wasteful of its resources than
104 .I rvu.
105 .I rvu
106 is intended as a quick interactive program for deciding viewpoints
107 and debugging scene descriptions and is not suited for producing
108 polished images.
109 .SH COMMANDS
110 Once the program starts, a number of commands can be used
111 to control it.
112 A command is given by its name, which can be abbreviated,
113 followed by its arguments.
114 .TP 10n
115 .BI aim " [ mag [ x y z ] ]"
116 Zoom in by
117 .I "mag"
118 on point
119 .I "x y z".
120 The view point is held constant;
121 only the view direction and size are changed.
122 If
123 .I "x y z"
124 is missing, the cursor is used to select the view center.
125 A negative magnification factor means zoom out.
126 The default factor is one.
127 .TP
128 .BR ^C
129 Interrupt.
130 Go to the command line.
131 .TP
132 .BI exposure " [ spec ]"
133 Adjust exposure.
134 The number
135 .I spec
136 is a multiplier used to compensate the average exposure.
137 A value of 1 renormalizes the image to the computed average, which
138 is usually done immediately after startup.
139 If
140 .I spec
141 begins with a '+' or '-',
142 the compensation is interpreted in f-stops (ie. the power of two).
143 If
144 .I spec
145 begins with an '=', an absolute setting is performed.
146 An '=' by itself permits interactive display and setting of the exposure.
147 If
148 .I spec
149 begins with an '@', the exposure is adjusted to present similar
150 visibility to what would be experienced in the real environment.
151 If
152 .I spec
153 is absent, or an '@' is followed by nothing, then
154 the cursor is used to pick a specific image
155 location for normalization.
156 .TP
157 .BI focus " [distance]"
158 Set focus distance for depth-of-field sampling.
159 If a distance in world coordinates is absent, then the cursor
160 is used to choose a point in the scene on which to focus.
161 (The focus distance setting does not affect rendering in
162 .I rview,
163 but can be used in
164 .I rpict
165 with the
166 .I \-pd
167 option to simulate depth-of-field on views saved from
168 .I rview.)
169 .TP
170 .BI frame " [ xmin ymin xmax ymax ]"
171 Set frame for refinement.
172 If coordinates are absent, the cursor is used to
173 pick frame boundaries.
174 If ``all'' is specified, the frame is reset to the entire image.
175 .TP
176 .BR free
177 Free cached object structures and associated data.
178 This command may be useful when memory is low and a completely
179 different view is being generated from the one previous.
180 .TP
181 .BI last " [ file ]"
182 Restore the previous view.
183 If a view or picture
184 .I file
185 is specified, the parameters are taken from the last view entry
186 in the file.
187 .TP
188 .BI L " [ vw [ rfile ] ]"
189 Load parameters for view
190 .I vw
191 from the
192 .I rad(1)
193 input file,
194 .I rfile.
195 Both
196 .I vw
197 and
198 .I rfile
199 must be given the first call, but subsequent calls will use the last
200 .I rfile
201 as a default, and "1" as the default view (ie. the first view
202 appearing in
203 .I rfile).
204 If
205 .I rvu
206 was started by
207 .I rad,
208 then the
209 .I rfile
210 parameter will initially default to the rad input file used.
211 .TP
212 .BI move " [ mag [ x y z ] ]"
213 Move camera
214 .I mag
215 times closer to point
216 .I "x y z".
217 For a perspective projection (or fisheye view),
218 only the view point is changed;
219 the view direction and size remain constant.
220 The view size must be modified in a parallel projection since
221 it determines magnification.
222 If
223 .I "x y z"
224 is missing, the cursor is used to select the view center.
225 A negative magnification factor decreases the object size.
226 The default factor is one.
227 Care must be taken to avoid moving behind or inside other objects.
228 .TP
229 .BI new " [ nproc ]"
230 Restart the image, using the specified number of rendering processes.
231 Usually used after the "set" command.
232 .TP
233 .BI pivot " angle [ elev [ mag [ x y z ] ] ]"
234 Similar to the "move" command, but pivots the view about a selected point.
235 The
236 .I angle
237 is measured in degrees around the view up vector using the right hand rule.
238 The optional
239 .I elev
240 is the elevation in degrees from the pivot point; positive raises the view point
241 to look downward and negative lowers the view point to look upward.
242 .TP
243 .BR quit
244 Quit the program.
245 .TP
246 .BR ^R
247 Redraw the image.
248 Use when the display gets corrupted.
249 On some displays, occassionally forcing a redraw can improve appearance,
250 as more color information is available and the driver can make a better
251 color table selection.
252 .TP
253 .BI rotate " angle [ elev [ mag ] ]"
254 Rotate the camera horizontally by
255 .I angle
256 degrees.
257 If an elevation is specified, the camera looks upward
258 .I elev
259 degrees.
260 (Negative means look downward.)
261 .TP
262 .BI set " [ var [ val ] ]"
263 Check/change program variable.
264 If
265 .I var
266 is absent, the list of available variables is displayed.
267 If
268 .I val
269 is absent, the current value of the variable is displayed
270 and changed interactively.
271 Otherwise, the variable
272 .I var
273 assumes the value
274 .I val.
275 Variables include:
276 ambient value (av),
277 ambient value weight (aw),
278 ambient bounces (ab),
279 ambient accuracy (aa),
280 ambient divisions (ad),
281 ambient radius (ar),
282 ambient samples (as),
283 black&white (b),
284 back face visibility (bv),
285 direct jitter (dj),
286 direct sampling (ds),
287 direct threshold (dt),
288 direct visibility (dv),
289 irradiance (i),
290 limit weight (lw),
291 limit recursion (lr),
292 medium extinction (me),
293 medium albedo (ma),
294 medium eccentricity (mg),
295 medium sampling (ms),
296 pixel sample (ps),
297 pixel threshold (pt),
298 specular jitter (sj),
299 specular threshold (st), and
300 uncorrelated sampling (u).
301 Once a variable has been changed, the "new" command can be used
302 to recompute the image with the new parameters.
303 If a program variable is not available here, it may show up under
304 some other command or it may be impossible to change
305 once the program is running.
306 .TP
307 .BI trace " [ xbeg ybeg zbeg xdir ydir zdir ]"
308 Trace a ray.
309 If the ray origin and direction are absent, the cursor is used
310 to pick a location in the image to trace.
311 The object intersected and its material, location and value are displayed.
312 .TP
313 .BI view " [ file [ comments ] ]"
314 Check/change view parameters.
315 If
316 .I file
317 is present, the view parameters are appended to a file, followed by
318 .I comments
319 if any.
320 Alternatively, view options may be given directly on the command line
321 instead of an output view file.
322 Otherwise, view parameters are displayed and changed interactively.
323 .TP
324 .BI V " [ vw [ rfile ] ]"
325 Append the current view as view
326 .I vw
327 in the rad file
328 .I rfile.
329 Compliment to
330 .I L
331 command.
332 Note that the view is simply appended to the file, and previous
333 views with the same name should be removed before using the file
334 with
335 .I rad.
336 .TP
337 .BI write " [ file ]"
338 Write picture to
339 .I file.
340 If argument is missing, the current file name is used.
341 .TP
342 .BR ^Z
343 Stop the program.
344 The screen will be redrawn when the program resumes.
345 .SH ENVIRONMENT
346 RAYPATH the directories to check for auxiliary files.
347 DISPLAY_GAMMA the value to use for monitor gamma correction.
348 .SH AUTHOR
349 Greg Ward
350 .SH "SEE ALSO"
351 getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1)
