root/radiance/ray/doc/man/man1/rvu.1
Revision: 1.4
Committed: Tue Jun 14 03:34:14 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
Changes since 1.3: +5 -5 lines
Had to change new -R rendering option to -u to avoid conflict with rpiece
1 .\" RCSid "$Id: rvu.1,v 1.3 2005/06/13 20:07:55 greg Exp $"
2 .TH RVU 1 1/1/04 RADIANCE
3 .SH NAME
4 rvu - generate RADIANCE images interactively
5 .SH SYNOPSIS
6 .B rvu
7 [
8 .B "rpict options"
9 ][
10 .B "\-o dev"
11 ][
12 .B \-b
13 ][
14 .B "\-pe exposure"
15 ]
16 [
17 .B $EVAR
18 ]
19 [
20 .B @file
21 ]
22 .B octree
23 .br
24 .B "rvu [ options ] \-defaults"
25 .br
26 .B "rvu \-devices"
27 .SH DESCRIPTION
28 .I Rvu
29 generates RADIANCE images using
30 .I octree.
31 (The octree may be given as the output of a command enclosed in quotes
32 and preceded by a `!'.)\0
33 Options specify the viewing parameters as well as
34 giving some control over the calculation.
35 Options may be given on the command line and/or read from the
36 environment and/or read from a file.
37 A command argument beginning with a dollar sign ('$') is immediately
38 replaced by the contents of the given environment variable.
39 A command argument beginning with an at sign ('@') is immediately
40 replaced by the contents of the given file.
41 The options are the same as for rpict(1), with a few notable exceptions.
42 The
43 .I "\-r, \-z, \-S, \-P, \-PP"
44 and
45 .I \-t
46 options are not supported, and
47 .I \-o
48 specifies which output device is being used instead of the output
49 file.
50 The
51 .I "\-x, \-y"
52 and
53 .I \-pa
54 options are unnecessary, since
55 .I rvu
56 scales the display image to the specified output device.
57 Additionally, the
58 .I \-b
59 option improves the display on greyscale monitors, and
60 .I \-pe
61 may be used to set an initial exposure value.
62 .PP
63 In the second form, the default values
64 for the options are printed with a brief explanation.
65 In the third form, the list of supported output devices
66 is displayed.
67 .PP
68 .I rvu
69 starts rendering the image from the selected viewpoint and
70 gradually improves the resolution of the display until
71 interrupted by keyboard input.
72 .I rvu
73 then issues a prompt (usually ':') and accepts a command
74 line from the user.
75 .I rvu
76 may also stop its calculation and wait for command input if
77 the resolution of the display has reached the resolution of the
78 graphics device.
79 At this point, it will give the 'done:' prompt and await further
80 instructions.
81 If
82 .I rvu
83 runs out of memory due to lack of resources to store its computed
84 image, it will give the 'out of memory:' prompt.
85 At this prompt, the user can save the image, quit, or even restart
86 a new image, although this is not generally recommended
87 on virtual memory machines for efficiency reasons.
88 .PP
89 .I rvu
90 is not meant to be a rendering program, and we strongly recommend that
91 .I rpict(1)
92 be used instead for that purpose.
93 Since
94 .I rpict(1)
95 does not store its image in memory or update any display of its output,
96 it is much faster and less wasteful of its resources than
97 .I rvu.
98 .I rvu
99 is intended as a quick interactive program for deciding viewpoints
100 and debugging scene descriptions and is not suited for producing
101 polished images.
102 .SH COMMANDS
103 Once the program starts, a number of commands can be used
104 to control it.
105 A command is given by its name, which can be abbreviated,
106 followed by its arguments.
107 .TP 10n
108 .BI aim " [ mag [ x y z ] ]"
109 Zoom in by
110 .I "mag"
111 on point
112 .I "x y z".
113 The view point is held constant;
114 only the view direction and size are changed.
115 If
116 .I "x y z"
117 is missing, the cursor is used to select the view center.
118 A negative magnification factor means zoom out.
119 The default factor is one.
120 .TP
121 .BR ^C
122 Interrupt.
123 Go to the command line.
124 .TP
125 .BI exposure " [ spec ]"
126 Adjust exposure.
127 The number
128 .I spec
129 is a multiplier used to compensate the average exposure.
130 A value of 1 renormalizes the image to the computed average, which
131 is usually done immediately after startup.
132 If
133 .I spec
134 begins with a '+' or '-',
135 the compensation is interpreted in f-stops (ie. the power of two).
136 If
137 .I spec
138 begins with an '=', an absolute setting is performed.
139 An '=' by itself permits interactive display and setting of the exposure.
140 If
141 .I spec
142 begins with an '@', the exposure is adjusted to present similar
143 visibility to what would be experienced in the real environment.
144 If
145 .I spec
146 is absent, or an '@' is followed by nothing, then
147 the cursor is used to pick a specific image
148 location for normalization.
149 .TP
150 .BI focus " [distance]"
151 Set focus distance for depth-of-field sampling.
152 If a distance in world coordinates is absent, then the cursor
153 is used to choose a point in the scene on which to focus.
154 (The focus distance setting does not affect rendering in
155 .I rview,
156 but can be used in
157 .I rpict
158 with the
159 .I \-pd
160 option to simulate depth-of-field on views saved from
161 .I rview.)
162 .TP
163 .BI frame " [ xmin ymin xmax ymax ]"
164 Set frame for refinement.
165 If coordinates are absent, the cursor is used to
166 pick frame boundaries.
167 If ``all'' is specified, the frame is reset to the entire image.
168 .TP
169 .BR free
170 Free cached object structures and associated data.
171 This command may be useful when memory is low and a completely
172 different view is being generated from the one previous.
173 .TP
174 .BI last " [ file ]"
175 Restore the previous view.
176 If a view or picture
177 .I file
178 is specified, the parameters are taken from the last view entry
179 in the file.
180 .TP
181 .BI L " [ vw [ rfile ] ]"
182 Load parameters for view
183 .I vw
184 from the
185 .I rad(1)
186 input file,
187 .I rfile.
188 Both
189 .I vw
190 and
191 .I rfile
192 must be given the first call, but subsequent calls will use the last
193 .I rfile
194 as a default, and "1" as the default view (ie. the first view
195 appearing in
196 .I rfile).
197 If
198 .I rvu
199 was started by
200 .I rad,
201 then the
202 .I rfile
203 parameter will initially default to the rad input file used.
204 .TP
205 .BI move " [ mag [ x y z ] ]"
206 Move camera
207 .I mag
208 times closer to point
209 .I "x y z".
210 For a perspective projection (or fisheye view),
211 only the view point is changed;
212 the view direction and size remain constant.
213 The view size must be modified in a parallel projection since
214 it determines magnification.
215 If
216 .I "x y z"
217 is missing, the cursor is used to select the view center.
218 A negative magnification factor decreases the object size.
219 The default factor is one.
220 Care must be taken to avoid moving behind or inside other objects.
221 .TP
222 .BR new
223 Restart the image.
224 Usually used after the "set" command.
225 .TP
226 .BI pivot " angle [ elev [ mag [ x y z ] ] ]"
227 Similar to the "move" command, but pivots the view about a selected point.
228 The
229 .I angle
230 is measured in degrees around the view up vector using the right hand rule.
231 The optional
232 .I elev
233 is the elevation in degrees from the pivot point; positive raises the view point
234 to look downward and negative lowers the view point to look upward.
235 .TP
236 .BR quit
237 Quit the program.
238 .TP
239 .BR ^R
240 Redraw the image.
241 Use when the display gets corrupted.
242 On some displays, occassionally forcing a redraw can improve appearance,
243 as more color information is available and the driver can make a better
244 color table selection.
245 .TP
246 .BI rotate " angle [ elev [ mag ] ]"
247 Rotate the camera horizontally by
248 .I angle
249 degrees.
250 If an elevation is specified, the camera looks upward
251 .I elev
252 degrees.
253 (Negative means look downward.)
254 .TP
255 .BI set " [ var [ val ] ]"
256 Check/change program variable.
257 If
258 .I var
259 is absent, the list of available variables is displayed.
260 If
261 .I val
262 is absent, the current value of the variable is displayed
263 and changed interactively.
264 Otherwise, the variable
265 .I var
266 assumes the value
267 .I val.
268 Variables include:
269 ambient value (av),
270 ambient value weight (aw),
271 ambient bounces (ab),
272 ambient accuracy (aa),
273 ambient divisions (ad),
274 ambient radius (ar),
275 ambient samples (as),
276 black&white (b),
277 back face visibility (bv),
278 direct jitter (dj),
279 direct sampling (ds),
280 direct threshold (dt),
281 direct visibility (dv),
282 irradiance (i),
283 limit weight (lw),
284 limit recursion (lr),
285 medium extinction (me),
286 medium albedo (ma),
287 medium eccentricity (mg),
288 medium sampling (ms),
289 pixel sample (ps),
290 pixel threshold (pt),
291 specular jitter (sj),
292 specular threshold (st), and
293 uncorrelated sampling (u).
294 Once a variable has been changed, the "new" command can be used
295 to recompute the image with the new parameters.
296 If a program variable is not available here, it may show up under
297 some other command or it may be impossible to change
298 once the program is running.
299 .TP
300 .BI trace " [ xbeg ybeg zbeg xdir ydir zdir ]"
301 Trace a ray.
302 If the ray origin and direction are absent, the cursor is used
303 to pick a location in the image to trace.
304 The object intersected and its material, location and value are displayed.
305 .TP
306 .BI view " [ file [ comments ] ]"
307 Check/change view parameters.
308 If
309 .I file
310 is present, the view parameters are appended to a file, followed by
311 .I comments
312 if any.
313 Alternatively, view options may be given directly on the command line
314 instead of an output view file.
315 Otherwise, view parameters are displayed and changed interactively.
316 .TP
317 .BI V " [ vw [ rfile ] ]"
318 Append the current view as view
319 .I vw
320 in the rad file
321 .I rfile.
322 Compliment to
323 .I L
324 command.
325 Note that the view is simply appended to the file, and previous
326 views with the same name should be removed before using the file
327 with
328 .I rad.
329 .TP
330 .BI write " [ file ]"
331 Write picture to
332 .I file.
333 If argument is missing, the current file name is used.
334 .TP
335 .BR ^Z
336 Stop the program.
337 The screen will be redrawn when the program resumes.
338 .SH ENVIRONMENT
339 RAYPATH the directories to check for auxiliary files.
340 DISPLAY_GAMMA the value to use for monitor gamma correction.
341 .SH AUTHOR
342 Greg Ward
343 .SH "SEE ALSO"
344 getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1)
