--- ray/doc/man/man1/rvu.1 2013/10/18 17:04:13 1.6 +++ ray/doc/man/man1/rvu.1 2017/08/13 20:11:04 1.11 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rvu.1,v 1.6 2013/10/18 17:04:13 greg Exp $" +.\" RCSid "$Id: rvu.1,v 1.11 2017/08/13 20:11:04 greg Exp $" .TH RVU 1 1/1/04 RADIANCE .SH NAME rvu - generate RADIANCE images interactively @@ -42,7 +42,7 @@ A command argument beginning with an at sign ('@') is replaced by the contents of the given file. The options are the same as for rpict(1), with a few notable exceptions. The -.I "\-r, \-z, \-S, \-P, \-PP" +.I "\-pd, \-r, \-z, \-S, \-P, \-PP" and .I \-t options are not supported, and @@ -207,7 +207,9 @@ was started by .I rad, then the .I rfile -parameter will initially default to the rad input file used. +parameter will initially default to the +.I rad +input file used. .TP .BI move " [ mag [ x y z ] ]" Move camera @@ -246,7 +248,8 @@ may be changed if the new direction coincides. Similar to the "move" command, but pivots the view about a selected point. The .I angle -is measured in degrees around the view up vector using the right hand rule. +is measured in degrees around the view up vector using the right hand rule, +so a positive value pivots the viewer to the right of the selected point. The optional .I elev is the elevation in degrees from the pivot point; positive raises the view point @@ -265,7 +268,9 @@ color table selection. .BI rotate " angle [ elev [ mag ] ]" Rotate the camera horizontally by .I angle -degrees. +degrees using the right-hand rule. +A positive value rotates the view towards the left, and a negative value +looks to the right. If an elevation is specified, the camera looks upward .I elev degrees. @@ -356,8 +361,10 @@ Stop the program. The screen will be redrawn when the program resumes. .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. +.br DISPLAY_GAMMA the value to use for monitor gamma correction. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1) +getinfo(1), lookamb(1), mkpmap(1), +oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1)
