--- ray/doc/man/man1/rvu.1 2008/08/21 07:05:58 1.5 +++ ray/doc/man/man1/rvu.1 2013/10/19 18:40:26 1.8 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rvu.1,v 1.5 2008/08/21 07:05:58 greg Exp $" +.\" RCSid "$Id: rvu.1,v 1.8 2013/10/19 18:40:26 greg Exp $" .TH RVU 1 1/1/04 RADIANCE .SH NAME rvu - generate RADIANCE images interactively @@ -159,13 +159,13 @@ Set focus distance for depth-of-field sampling. If a distance in world coordinates is absent, then the cursor is used to choose a point in the scene on which to focus. (The focus distance setting does not affect rendering in -.I rview, +.I rvu, but can be used in .I rpict with the .I \-pd option to simulate depth-of-field on views saved from -.I rview.) +.I rvu.) .TP .BI frame " [ xmin ymin xmax ymax ]" Set frame for refinement. @@ -230,11 +230,24 @@ Care must be taken to avoid moving behind or inside ot Restart the image, using the specified number of rendering processes. Usually used after the "set" command. .TP +.BI origin " [ xo yo zo [ xd yd zd ] ]" +Change view origin to the indicated world position +.I "xo yo zo" +looking in the direction +.I "xd yd zd." +If the direction is missing, the current view direction is used. +If the origin is missing, the cursor is used to select the +view origin, and the direction will be determined by the +(reoriented) surface normal. +The view type and size will not be altered, but the up vector +may be changed if the new direction coincides. +.TP .BI pivot " angle [ elev [ mag [ x y z ] ] ]" Similar to the "move" command, but pivots the view about a selected point. The .I angle -is measured in degrees around the view up vector using the right hand rule. +is measured in degrees around the view up vector using the right hand rule, +so a positive value pivots the viewer to the right of the selected point. The optional .I elev is the elevation in degrees from the pivot point; positive raises the view point @@ -253,7 +266,9 @@ color table selection. .BI rotate " angle [ elev [ mag ] ]" Rotate the camera horizontally by .I angle -degrees. +degrees using the right-hand rule. +A positive value rotates the view towards the left, and a negative value +looks to the right. If an elevation is specified, the camera looks upward .I elev degrees. @@ -344,6 +359,7 @@ Stop the program. The screen will be redrawn when the program resumes. .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. +.br DISPLAY_GAMMA the value to use for monitor gamma correction. .SH AUTHOR Greg Ward
