--- ray/doc/man/man1/rvu.1 2008/08/21 07:05:58 1.5 +++ ray/doc/man/man1/rvu.1 2018/03/30 23:14:07 1.13 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rvu.1,v 1.5 2008/08/21 07:05:58 greg Exp $" +.\" RCSid "$Id: rvu.1,v 1.13 2018/03/30 23:14:07 greg Exp $" .TH RVU 1 1/1/04 RADIANCE .SH NAME rvu - generate RADIANCE images interactively @@ -42,7 +42,7 @@ A command argument beginning with an at sign ('@') is replaced by the contents of the given file. The options are the same as for rpict(1), with a few notable exceptions. The -.I "\-r, \-z, \-S, \-P, \-PP" +.I "\-pd, \-r, \-z, \-S, \-P, \-PP" and .I \-t options are not supported, and @@ -159,13 +159,13 @@ Set focus distance for depth-of-field sampling. If a distance in world coordinates is absent, then the cursor is used to choose a point in the scene on which to focus. (The focus distance setting does not affect rendering in -.I rview, +.I rvu, but can be used in .I rpict with the .I \-pd option to simulate depth-of-field on views saved from -.I rview.) +.I rvu.) .TP .BI frame " [ xmin ymin xmax ymax ]" Set frame for refinement. @@ -207,7 +207,9 @@ was started by .I rad, then the .I rfile -parameter will initially default to the rad input file used. +parameter will initially default to the +.I rad +input file used. .TP .BI move " [ mag [ x y z ] ]" Move camera @@ -230,11 +232,28 @@ Care must be taken to avoid moving behind or inside ot Restart the image, using the specified number of rendering processes. Usually used after the "set" command. .TP +.BI origin " [ d | xo yo zo [ xd yd zd ] ]" +Move the view forward or backwards the distance specified by a single +.I d +argument along the view direction vector. +If 3 or more arguments are given, move the +view origin to the indicated world position +.I "xo yo zo" +looking in the direction +.I "xd yd zd." +If the direction is unspecified, the current view direction is used. +Without arguments, the cursor is used to select the +view origin, and the direction will be determined by the +(reoriented) surface normal. +The view type and size will not be altered, but the up vector +may be changed if the new direction coincides. +.TP .BI pivot " angle [ elev [ mag [ x y z ] ] ]" Similar to the "move" command, but pivots the view about a selected point. The .I angle -is measured in degrees around the view up vector using the right hand rule. +is measured in degrees around the view up vector using the right hand rule, +so a positive value pivots the viewer to the right of the selected point. The optional .I elev is the elevation in degrees from the pivot point; positive raises the view point @@ -253,7 +272,9 @@ color table selection. .BI rotate " angle [ elev [ mag ] ]" Rotate the camera horizontally by .I angle -degrees. +degrees using the right-hand rule. +A positive value rotates the view towards the left, and a negative value +looks to the right. If an elevation is specified, the camera looks upward .I elev degrees. @@ -344,8 +365,10 @@ Stop the program. The screen will be redrawn when the program resumes. .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. +.br DISPLAY_GAMMA the value to use for monitor gamma correction. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1) +getinfo(1), lookamb(1), mkpmap(1), +oconv(1), pfilt(1), rad(1), rpict(1), rtpict(1), rtrace(1)
