--- ray/doc/man/man1/rvu.1 2004/01/01 19:31:45 1.1 +++ ray/doc/man/man1/rvu.1 2005/06/13 20:07:55 1.3 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rvu.1,v 1.1 2004/01/01 19:31:45 greg Exp $" +.\" RCSid "$Id: rvu.1,v 1.3 2005/06/13 20:07:55 greg Exp $" .TH RVU 1 1/1/04 RADIANCE .SH NAME rvu - generate RADIANCE images interactively @@ -147,6 +147,19 @@ is absent, or an '@' is followed by nothing, then the cursor is used to pick a specific image location for normalization. .TP +.BI focus " [distance]" +Set focus distance for depth-of-field sampling. +If a distance in world coordinates is absent, then the cursor +is used to choose a point in the scene on which to focus. +(The focus distance setting does not affect rendering in +.I rview, +but can be used in +.I rpict +with the +.I \-pd +option to simulate depth-of-field on views saved from +.I rview.) +.TP .BI frame " [ xmin ymin xmax ymax ]" Set frame for refinement. If coordinates are absent, the cursor is used to @@ -275,6 +288,7 @@ medium sampling (ms), pixel sample (ps), pixel threshold (pt), back face visibility (bv), +random sampling (R), specular jitter (sj), and specular threshold (st). Once a variable has been changed, the "new" command can be used
