--- ray/doc/man/man1/rvu.1 2013/10/19 18:40:26 1.8 +++ ray/doc/man/man1/rvu.1 2018/03/20 02:40:38 1.12 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rvu.1,v 1.8 2013/10/19 18:40:26 greg Exp $" +.\" RCSid "$Id: rvu.1,v 1.12 2018/03/20 02:40:38 greg Exp $" .TH RVU 1 1/1/04 RADIANCE .SH NAME rvu - generate RADIANCE images interactively @@ -42,7 +42,7 @@ A command argument beginning with an at sign ('@') is replaced by the contents of the given file. The options are the same as for rpict(1), with a few notable exceptions. The -.I "\-r, \-z, \-S, \-P, \-PP" +.I "\-pd, \-r, \-z, \-S, \-P, \-PP" and .I \-t options are not supported, and @@ -207,7 +207,9 @@ was started by .I rad, then the .I rfile -parameter will initially default to the rad input file used. +parameter will initially default to the +.I rad +input file used. .TP .BI move " [ mag [ x y z ] ]" Move camera @@ -364,4 +366,5 @@ DISPLAY_GAMMA the value to use for monitor gamma corr .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1) +getinfo(1), lookamb(1), mkpmap(1), +oconv(1), pfilt(1), rad(1), rpict(1), rtpict(1), rtrace(1)
