--- ray/doc/man/man1/rvu.1 2018/03/20 02:40:38 1.12 +++ ray/doc/man/man1/rvu.1 2018/03/30 23:14:07 1.13 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rvu.1,v 1.12 2018/03/20 02:40:38 greg Exp $" +.\" RCSid "$Id: rvu.1,v 1.13 2018/03/30 23:14:07 greg Exp $" .TH RVU 1 1/1/04 RADIANCE .SH NAME rvu - generate RADIANCE images interactively @@ -232,13 +232,17 @@ Care must be taken to avoid moving behind or inside ot Restart the image, using the specified number of rendering processes. Usually used after the "set" command. .TP -.BI origin " [ xo yo zo [ xd yd zd ] ]" -Change view origin to the indicated world position +.BI origin " [ d | xo yo zo [ xd yd zd ] ]" +Move the view forward or backwards the distance specified by a single +.I d +argument along the view direction vector. +If 3 or more arguments are given, move the +view origin to the indicated world position .I "xo yo zo" looking in the direction .I "xd yd zd." -If the direction is missing, the current view direction is used. -If the origin is missing, the cursor is used to select the +If the direction is unspecified, the current view direction is used. +Without arguments, the cursor is used to select the view origin, and the direction will be determined by the (reoriented) surface normal. The view type and size will not be altered, but the up vector
