root/Development/ray/doc/man/man1/rvu.1
Revision: 1.13
Committed: Fri Mar 30 23:14:07 2018 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R3, rad5R2
Changes since 1.12: +9 -5 lines
Added single-argument mode to John M's "origin" command in rvu
# User Rev Content
1 greg 1.13 .\" RCSid "$Id: rvu.1,v 1.12 2018/03/20 02:40:38 greg Exp $"
2 greg 1.1 .TH RVU 1 1/1/04 RADIANCE
3     .SH NAME
4     rvu - generate RADIANCE images interactively
5     .SH SYNOPSIS
6     .B rvu
7     [
8     .B "rpict options"
9     ][
10 greg 1.5 .B "\-n nproc"
11     ][
12 greg 1.1 .B "\-o dev"
13     ][
14     .B \-b
15     ][
16     .B "\-pe exposure"
17     ]
18     [
19     .B $EVAR
20     ]
21     [
22     .B @file
23     ]
24     .B octree
25     .br
26     .B "rvu [ options ] \-defaults"
27     .br
28     .B "rvu \-devices"
29     .SH DESCRIPTION
30     .I Rvu
31     generates RADIANCE images using
32     .I octree.
33     (The octree may be given as the output of a command enclosed in quotes
34     and preceded by a `!'.)\0
35     Options specify the viewing parameters as well as
36     giving some control over the calculation.
37     Options may be given on the command line and/or read from the
38     environment and/or read from a file.
39     A command argument beginning with a dollar sign ('$') is immediately
40     replaced by the contents of the given environment variable.
41     A command argument beginning with an at sign ('@') is immediately
42     replaced by the contents of the given file.
43     The options are the same as for rpict(1), with a few notable exceptions.
44     The
45 greg 1.9 .I "\-pd, \-r, \-z, \-S, \-P, \-PP"
46 greg 1.1 and
47     .I \-t
48     options are not supported, and
49     .I \-o
50     specifies which output device is being used instead of the output
51     file.
52     The
53     .I "\-x, \-y"
54     and
55     .I \-pa
56     options are unnecessary, since
57     .I rvu
58     scales the display image to the specified output device.
59     Additionally, the
60     .I \-b
61     option improves the display on greyscale monitors, and
62     .I \-pe
63     may be used to set an initial exposure value.
64     .PP
65 greg 1.5 The
66     .I \-n
67     option may be used to specify multiple processes,
68     to accelerate rendering.
69     .PP
70 greg 1.1 In the second form, the default values
71     for the options are printed with a brief explanation.
72     In the third form, the list of supported output devices
73     is displayed.
74     .PP
75     .I rvu
76     starts rendering the image from the selected viewpoint and
77     gradually improves the resolution of the display until
78     interrupted by keyboard input.
79     .I rvu
80     then issues a prompt (usually ':') and accepts a command
81     line from the user.
82     .I rvu
83     may also stop its calculation and wait for command input if
84     the resolution of the display has reached the resolution of the
85     graphics device.
86     At this point, it will give the 'done:' prompt and await further
87     instructions.
88     If
89     .I rvu
90     runs out of memory due to lack of resources to store its computed
91     image, it will give the 'out of memory:' prompt.
92     At this prompt, the user can save the image, quit, or even restart
93     a new image, although this is not generally recommended
94     on virtual memory machines for efficiency reasons.
95     .PP
96     .I rvu
97     is not meant to be a rendering program, and we strongly recommend that
98     .I rpict(1)
99     be used instead for that purpose.
100     Since
101     .I rpict(1)
102     does not store its image in memory or update any display of its output,
103     it is much faster and less wasteful of its resources than
104     .I rvu.
105     .I rvu
106     is intended as a quick interactive program for deciding viewpoints
107     and debugging scene descriptions and is not suited for producing
108     polished images.
109     .SH COMMANDS
110     Once the program starts, a number of commands can be used
111     to control it.
112     A command is given by its name, which can be abbreviated,
113     followed by its arguments.
114     .TP 10n
115     .BI aim " [ mag [ x y z ] ]"
116     Zoom in by
117     .I "mag"
118     on point
119     .I "x y z".
120     The view point is held constant;
121     only the view direction and size are changed.
122     If
123     .I "x y z"
124     is missing, the cursor is used to select the view center.
125     A negative magnification factor means zoom out.
126     The default factor is one.
127     .TP
128     .BR ^C
129     Interrupt.
130     Go to the command line.
131     .TP
132     .BI exposure " [ spec ]"
133     Adjust exposure.
134     The number
135     .I spec
136     is a multiplier used to compensate the average exposure.
137     A value of 1 renormalizes the image to the computed average, which
138     is usually done immediately after startup.
139     If
140     .I spec
141     begins with a '+' or '-',
142     the compensation is interpreted in f-stops (ie. the power of two).
143     If
144     .I spec
145     begins with an '=', an absolute setting is performed.
146     An '=' by itself permits interactive display and setting of the exposure.
147     If
148     .I spec
149     begins with an '@', the exposure is adjusted to present similar
150     visibility to what would be experienced in the real environment.
151     If
152     .I spec
153     is absent, or an '@' is followed by nothing, then
154     the cursor is used to pick a specific image
155     location for normalization.
156     .TP
157 greg 1.2 .BI focus " [distance]"
158     Set focus distance for depth-of-field sampling.
159     If a distance in world coordinates is absent, then the cursor
160     is used to choose a point in the scene on which to focus.
161     (The focus distance setting does not affect rendering in
162 greg 1.6 .I rvu,
163 greg 1.2 but can be used in
164     .I rpict
165     with the
166     .I \-pd
167     option to simulate depth-of-field on views saved from
168 greg 1.6 .I rvu.)
169 greg 1.2 .TP
170 greg 1.1 .BI frame " [ xmin ymin xmax ymax ]"
171     Set frame for refinement.
172     If coordinates are absent, the cursor is used to
173     pick frame boundaries.
174     If ``all'' is specified, the frame is reset to the entire image.
175     .TP
176     .BR free
177     Free cached object structures and associated data.
178     This command may be useful when memory is low and a completely
179     different view is being generated from the one previous.
180     .TP
181     .BI last " [ file ]"
182     Restore the previous view.
183     If a view or picture
184     .I file
185     is specified, the parameters are taken from the last view entry
186     in the file.
187     .TP
188     .BI L " [ vw [ rfile ] ]"
189     Load parameters for view
190     .I vw
191     from the
192     .I rad(1)
193     input file,
194     .I rfile.
195     Both
196     .I vw
197     and
198     .I rfile
199     must be given the first call, but subsequent calls will use the last
200     .I rfile
201     as a default, and "1" as the default view (ie. the first view
202     appearing in
203     .I rfile).
204     If
205     .I rvu
206     was started by
207     .I rad,
208     then the
209     .I rfile
210 greg 1.11 parameter will initially default to the
211     .I rad
212     input file used.
213 greg 1.1 .TP
214     .BI move " [ mag [ x y z ] ]"
215     Move camera
216     .I mag
217     times closer to point
218     .I "x y z".
219     For a perspective projection (or fisheye view),
220     only the view point is changed;
221     the view direction and size remain constant.
222     The view size must be modified in a parallel projection since
223     it determines magnification.
224     If
225     .I "x y z"
226     is missing, the cursor is used to select the view center.
227     A negative magnification factor decreases the object size.
228     The default factor is one.
229     Care must be taken to avoid moving behind or inside other objects.
230     .TP
231 greg 1.5 .BI new " [ nproc ]"
232     Restart the image, using the specified number of rendering processes.
233 greg 1.1 Usually used after the "set" command.
234     .TP
235 greg 1.13 .BI origin " [ d | xo yo zo [ xd yd zd ] ]"
236     Move the view forward or backwards the distance specified by a single
237     .I d
238     argument along the view direction vector.
239     If 3 or more arguments are given, move the
240     view origin to the indicated world position
241 greg 1.6 .I "xo yo zo"
242     looking in the direction
243     .I "xd yd zd."
244 greg 1.13 If the direction is unspecified, the current view direction is used.
245     Without arguments, the cursor is used to select the
246 greg 1.6 view origin, and the direction will be determined by the
247     (reoriented) surface normal.
248     The view type and size will not be altered, but the up vector
249     may be changed if the new direction coincides.
250     .TP
251 greg 1.1 .BI pivot " angle [ elev [ mag [ x y z ] ] ]"
252     Similar to the "move" command, but pivots the view about a selected point.
253     The
254     .I angle
255 greg 1.8 is measured in degrees around the view up vector using the right hand rule,
256     so a positive value pivots the viewer to the right of the selected point.
257 greg 1.1 The optional
258     .I elev
259     is the elevation in degrees from the pivot point; positive raises the view point
260     to look downward and negative lowers the view point to look upward.
261     .TP
262     .BR quit
263     Quit the program.
264     .TP
265     .BR ^R
266     Redraw the image.
267     Use when the display gets corrupted.
268     On some displays, occassionally forcing a redraw can improve appearance,
269     as more color information is available and the driver can make a better
270     color table selection.
271     .TP
272     .BI rotate " angle [ elev [ mag ] ]"
273     Rotate the camera horizontally by
274     .I angle
275 greg 1.8 degrees using the right-hand rule.
276     A positive value rotates the view towards the left, and a negative value
277     looks to the right.
278 greg 1.1 If an elevation is specified, the camera looks upward
279     .I elev
280     degrees.
281     (Negative means look downward.)
282     .TP
283     .BI set " [ var [ val ] ]"
284     Check/change program variable.
285     If
286     .I var
287     is absent, the list of available variables is displayed.
288     If
289     .I val
290     is absent, the current value of the variable is displayed
291     and changed interactively.
292     Otherwise, the variable
293     .I var
294     assumes the value
295     .I val.
296     Variables include:
297     ambient value (av),
298     ambient value weight (aw),
299     ambient bounces (ab),
300     ambient accuracy (aa),
301     ambient divisions (ad),
302     ambient radius (ar),
303     ambient samples (as),
304     black&white (b),
305 greg 1.4 back face visibility (bv),
306 greg 1.1 direct jitter (dj),
307     direct sampling (ds),
308     direct threshold (dt),
309     direct visibility (dv),
310     irradiance (i),
311     limit weight (lw),
312     limit recursion (lr),
313     medium extinction (me),
314     medium albedo (ma),
315     medium eccentricity (mg),
316     medium sampling (ms),
317     pixel sample (ps),
318     pixel threshold (pt),
319 greg 1.4 specular jitter (sj),
320     specular threshold (st), and
321     uncorrelated sampling (u).
322 greg 1.1 Once a variable has been changed, the "new" command can be used
323     to recompute the image with the new parameters.
324     If a program variable is not available here, it may show up under
325     some other command or it may be impossible to change
326     once the program is running.
327     .TP
328     .BI trace " [ xbeg ybeg zbeg xdir ydir zdir ]"
329     Trace a ray.
330     If the ray origin and direction are absent, the cursor is used
331     to pick a location in the image to trace.
332     The object intersected and its material, location and value are displayed.
333     .TP
334     .BI view " [ file [ comments ] ]"
335     Check/change view parameters.
336     If
337     .I file
338     is present, the view parameters are appended to a file, followed by
339     .I comments
340     if any.
341     Alternatively, view options may be given directly on the command line
342     instead of an output view file.
343     Otherwise, view parameters are displayed and changed interactively.
344     .TP
345     .BI V " [ vw [ rfile ] ]"
346     Append the current view as view
347     .I vw
348     in the rad file
349     .I rfile.
350     Compliment to
351     .I L
352     command.
353     Note that the view is simply appended to the file, and previous
354     views with the same name should be removed before using the file
355     with
356     .I rad.
357     .TP
358     .BI write " [ file ]"
359     Write picture to
360     .I file.
361     If argument is missing, the current file name is used.
362     .TP
363     .BR ^Z
364     Stop the program.
365     The screen will be redrawn when the program resumes.
366     .SH ENVIRONMENT
367     RAYPATH the directories to check for auxiliary files.
368 greg 1.7 .br
369 greg 1.1 DISPLAY_GAMMA the value to use for monitor gamma correction.
370     .SH AUTHOR
371     Greg Ward
372     .SH "SEE ALSO"
373 greg 1.10 getinfo(1), lookamb(1), mkpmap(1),
374 greg 1.12 oconv(1), pfilt(1), rad(1), rpict(1), rtpict(1), rtrace(1)
