root/radiance/ray/doc/man/man1/rvu.1
Fri Mar 30 23:14:07 2018 UTC (7 years, 2 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Changes since 1.12: +9 -5 lines
Diff to previous 1.12 , to selected 1.2
Added single-argument mode to John M's "origin" command in rvu
Tue Mar 20 02:40:38 2018 UTC (7 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.2
Wrote rtpict program to run rpict as if it had a -n option
Sun Aug 13 20:11:04 2017 UTC (7 years, 10 months ago) by greg
Diff to previous 1.10 , to selected 1.2
Added information about re-using the rad input file
Tue May 26 10:00:47 2015 UTC (10 years ago) by greg
Changes since 1.9: +3 -2 lines
Diff to previous 1.9 , to selected 1.2
Thu Dec 5 18:12:42 2013 UTC (11 years, 6 months ago) by greg
Diff to previous 1.8 , to selected 1.2
Added mention that -pd is not supported
Sat Oct 19 18:40:26 2013 UTC (11 years, 8 months ago) by greg
Changes since 1.7: +6 -3 lines
Diff to previous 1.7 , to selected 1.2
Improved specificity on rotations
Fri Oct 18 17:20:55 2013 UTC (11 years, 8 months ago) by greg
Fixed formatting
Fri Oct 18 17:04:13 2013 UTC (11 years, 8 months ago) by greg
Changes since 1.5: +15 -3 lines
Added rvu "origin" command requested by John M.
Thu Aug 21 07:05:58 2008 UTC (16 years, 10 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 1.4: +10 -3 lines
Tue Jun 14 03:34:14 2005 UTC (20 years ago) by greg
Changes since 1.3: +5 -5 lines
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:55 2005 UTC (20 years ago) by greg
Changes since 1.2: +2 -1 lines
Diff to previous 1.2
Fri Jan 21 00:52:59 2005 UTC (20 years, 5 months ago) by greg
Changes since 1.1: +14 -1 lines
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Diff to selected 1.2
