1 |
greg |
1.4 |
.\" RCSid "$Id: rvu.1,v 1.3 2005/06/13 20:07:55 greg Exp $" |
2 |
greg |
1.1 |
.TH RVU 1 1/1/04 RADIANCE |
3 |
.SH NAME |
4 |
rvu - generate RADIANCE images interactively |
5 |
.SH SYNOPSIS |
6 |
.B rvu |
7 |
8 |
.B "rpict options" |
9 |
10 |
.B "\-o dev" |
11 |
12 |
.B \-b |
13 |
14 |
.B "\-pe exposure" |
15 |
16 |
17 |
.B $EVAR |
18 |
19 |
20 |
.B @file |
21 |
22 |
.B octree |
23 |
.br |
24 |
.B "rvu [ options ] \-defaults" |
25 |
.br |
26 |
.B "rvu \-devices" |
27 |
.SH DESCRIPTION |
28 |
.I Rvu |
29 |
generates RADIANCE images using |
30 |
.I octree. |
31 |
(The octree may be given as the output of a command enclosed in quotes |
32 |
and preceded by a `!'.)\0 |
33 |
Options specify the viewing parameters as well as |
34 |
giving some control over the calculation. |
35 |
Options may be given on the command line and/or read from the |
36 |
environment and/or read from a file. |
37 |
A command argument beginning with a dollar sign ('$') is immediately |
38 |
replaced by the contents of the given environment variable. |
39 |
A command argument beginning with an at sign ('@') is immediately |
40 |
replaced by the contents of the given file. |
41 |
The options are the same as for rpict(1), with a few notable exceptions. |
42 |
The |
43 |
.I "\-r, \-z, \-S, \-P, \-PP" |
44 |
and |
45 |
.I \-t |
46 |
options are not supported, and |
47 |
.I \-o |
48 |
specifies which output device is being used instead of the output |
49 |
file. |
50 |
The |
51 |
.I "\-x, \-y" |
52 |
and |
53 |
.I \-pa |
54 |
options are unnecessary, since |
55 |
.I rvu |
56 |
scales the display image to the specified output device. |
57 |
Additionally, the |
58 |
.I \-b |
59 |
option improves the display on greyscale monitors, and |
60 |
.I \-pe |
61 |
may be used to set an initial exposure value. |
62 |
.PP |
63 |
In the second form, the default values |
64 |
for the options are printed with a brief explanation. |
65 |
In the third form, the list of supported output devices |
66 |
is displayed. |
67 |
.PP |
68 |
.I rvu |
69 |
starts rendering the image from the selected viewpoint and |
70 |
gradually improves the resolution of the display until |
71 |
interrupted by keyboard input. |
72 |
.I rvu |
73 |
then issues a prompt (usually ':') and accepts a command |
74 |
line from the user. |
75 |
.I rvu |
76 |
may also stop its calculation and wait for command input if |
77 |
the resolution of the display has reached the resolution of the |
78 |
graphics device. |
79 |
At this point, it will give the 'done:' prompt and await further |
80 |
instructions. |
81 |
If |
82 |
.I rvu |
83 |
runs out of memory due to lack of resources to store its computed |
84 |
image, it will give the 'out of memory:' prompt. |
85 |
At this prompt, the user can save the image, quit, or even restart |
86 |
a new image, although this is not generally recommended |
87 |
on virtual memory machines for efficiency reasons. |
88 |
.PP |
89 |
.I rvu |
90 |
is not meant to be a rendering program, and we strongly recommend that |
91 |
.I rpict(1) |
92 |
be used instead for that purpose. |
93 |
Since |
94 |
.I rpict(1) |
95 |
does not store its image in memory or update any display of its output, |
96 |
it is much faster and less wasteful of its resources than |
97 |
.I rvu. |
98 |
.I rvu |
99 |
is intended as a quick interactive program for deciding viewpoints |
100 |
and debugging scene descriptions and is not suited for producing |
101 |
polished images. |
102 |
.SH COMMANDS |
103 |
Once the program starts, a number of commands can be used |
104 |
to control it. |
105 |
A command is given by its name, which can be abbreviated, |
106 |
followed by its arguments. |
107 |
.TP 10n |
108 |
.BI aim " [ mag [ x y z ] ]" |
109 |
Zoom in by |
110 |
.I "mag" |
111 |
on point |
112 |
.I "x y z". |
113 |
The view point is held constant; |
114 |
only the view direction and size are changed. |
115 |
If |
116 |
.I "x y z" |
117 |
is missing, the cursor is used to select the view center. |
118 |
A negative magnification factor means zoom out. |
119 |
The default factor is one. |
120 |
.TP |
121 |
.BR ^C |
122 |
Interrupt. |
123 |
Go to the command line. |
124 |
.TP |
125 |
.BI exposure " [ spec ]" |
126 |
Adjust exposure. |
127 |
The number |
128 |
.I spec |
129 |
is a multiplier used to compensate the average exposure. |
130 |
A value of 1 renormalizes the image to the computed average, which |
131 |
is usually done immediately after startup. |
132 |
If |
133 |
.I spec |
134 |
begins with a '+' or '-', |
135 |
the compensation is interpreted in f-stops (ie. the power of two). |
136 |
If |
137 |
.I spec |
138 |
begins with an '=', an absolute setting is performed. |
139 |
An '=' by itself permits interactive display and setting of the exposure. |
140 |
If |
141 |
.I spec |
142 |
begins with an '@', the exposure is adjusted to present similar |
143 |
visibility to what would be experienced in the real environment. |
144 |
If |
145 |
.I spec |
146 |
is absent, or an '@' is followed by nothing, then |
147 |
the cursor is used to pick a specific image |
148 |
location for normalization. |
149 |
.TP |
150 |
greg |
1.2 |
.BI focus " [distance]" |
151 |
Set focus distance for depth-of-field sampling. |
152 |
If a distance in world coordinates is absent, then the cursor |
153 |
is used to choose a point in the scene on which to focus. |
154 |
(The focus distance setting does not affect rendering in |
155 |
.I rview, |
156 |
but can be used in |
157 |
.I rpict |
158 |
with the |
159 |
.I \-pd |
160 |
option to simulate depth-of-field on views saved from |
161 |
.I rview.) |
162 |
.TP |
163 |
greg |
1.1 |
.BI frame " [ xmin ymin xmax ymax ]" |
164 |
Set frame for refinement. |
165 |
If coordinates are absent, the cursor is used to |
166 |
pick frame boundaries. |
167 |
If ``all'' is specified, the frame is reset to the entire image. |
168 |
.TP |
169 |
.BR free |
170 |
Free cached object structures and associated data. |
171 |
This command may be useful when memory is low and a completely |
172 |
different view is being generated from the one previous. |
173 |
.TP |
174 |
.BI last " [ file ]" |
175 |
Restore the previous view. |
176 |
If a view or picture |
177 |
.I file |
178 |
is specified, the parameters are taken from the last view entry |
179 |
in the file. |
180 |
.TP |
181 |
.BI L " [ vw [ rfile ] ]" |
182 |
Load parameters for view |
183 |
.I vw |
184 |
from the |
185 |
.I rad(1) |
186 |
input file, |
187 |
.I rfile. |
188 |
Both |
189 |
.I vw |
190 |
and |
191 |
.I rfile |
192 |
must be given the first call, but subsequent calls will use the last |
193 |
.I rfile |
194 |
as a default, and "1" as the default view (ie. the first view |
195 |
appearing in |
196 |
.I rfile). |
197 |
If |
198 |
.I rvu |
199 |
was started by |
200 |
.I rad, |
201 |
then the |
202 |
.I rfile |
203 |
parameter will initially default to the rad input file used. |
204 |
.TP |
205 |
.BI move " [ mag [ x y z ] ]" |
206 |
Move camera |
207 |
.I mag |
208 |
times closer to point |
209 |
.I "x y z". |
210 |
For a perspective projection (or fisheye view), |
211 |
only the view point is changed; |
212 |
the view direction and size remain constant. |
213 |
The view size must be modified in a parallel projection since |
214 |
it determines magnification. |
215 |
If |
216 |
.I "x y z" |
217 |
218 |
A negative magnification factor decreases the object size. |
219 |
220 |
Care must be taken to avoid moving behind or inside other objects. |
221 |
.TP |
222 |
.BR new |
223 |
Restart the image. |
224 |
Usually used after the "set" command. |
225 |
.TP |
226 |
.BI pivot " angle [ elev [ mag [ x y z ] ] ]" |
227 |
Similar to the "move" command, but pivots the view about a selected point. |
228 |
The |
229 |
.I angle |
230 |
is measured in degrees around the view up vector using the right hand rule. |
231 |
The optional |
232 |
.I elev |
233 |
is the elevation in degrees from the pivot point; positive raises the view point |
234 |
to look downward and negative lowers the view point to look upward. |
235 |
.TP |
236 |
.BR quit |
237 |
Quit the program. |
238 |
.TP |
239 |
.BR ^R |
240 |
Redraw the image. |
241 |
Use when the display gets corrupted. |
242 |
On some displays, occassionally forcing a redraw can improve appearance, |
243 |
as more color information is available and the driver can make a better |
244 |
color table selection. |
245 |
.TP |
246 |
.BI rotate " angle [ elev [ mag ] ]" |
247 |
Rotate the camera horizontally by |
248 |
.I angle |
249 |
degrees. |
250 |
If an elevation is specified, the camera looks upward |
251 |
.I elev |
252 |
degrees. |
253 |
(Negative means look downward.) |
254 |
.TP |
255 |
.BI set " [ var [ val ] ]" |
256 |
Check/change program variable. |
257 |
If |
258 |
.I var |
259 |
is absent, the list of available variables is displayed. |
260 |
If |
261 |
.I val |
262 |
is absent, the current value of the variable is displayed |
263 |
and changed interactively. |
264 |
Otherwise, the variable |
265 |
.I var |
266 |
assumes the value |
267 |
.I val. |
268 |
Variables include: |
269 |
ambient value (av), |
270 |
ambient value weight (aw), |
271 |
ambient bounces (ab), |
272 |
ambient accuracy (aa), |
273 |
ambient divisions (ad), |
274 |
ambient radius (ar), |
275 |
ambient samples (as), |
276 |
black&white (b), |
277 |
greg |
1.4 |
back face visibility (bv), |
278 |
greg |
1.1 |
direct jitter (dj), |
279 |
direct sampling (ds), |
280 |
direct threshold (dt), |
281 |
direct visibility (dv), |
282 |
irradiance (i), |
283 |
limit weight (lw), |
284 |
limit recursion (lr), |
285 |
medium extinction (me), |
286 |
medium albedo (ma), |
287 |
medium eccentricity (mg), |
288 |
medium sampling (ms), |
289 |
pixel sample (ps), |
290 |
pixel threshold (pt), |
291 |
greg |
1.4 |
specular jitter (sj), |
292 |
specular threshold (st), and |
293 |
uncorrelated sampling (u). |
294 |
greg |
1.1 |
Once a variable has been changed, the "new" command can be used |
295 |
to recompute the image with the new parameters. |
296 |
If a program variable is not available here, it may show up under |
297 |
some other command or it may be impossible to change |
298 |
once the program is running. |
299 |
.TP |
300 |
.BI trace " [ xbeg ybeg zbeg xdir ydir zdir ]" |
301 |
Trace a ray. |
302 |
If the ray origin and direction are absent, the cursor is used |
303 |
to pick a location in the image to trace. |
304 |
The object intersected and its material, location and value are displayed. |
305 |
.TP |
306 |
.BI view " [ file [ comments ] ]" |
307 |
Check/change view parameters. |
308 |
If |
309 |
.I file |
310 |
is present, the view parameters are appended to a file, followed by |
311 |
.I comments |
312 |
if any. |
313 |
Alternatively, view options may be given directly on the command line |
314 |
instead of an output view file. |
315 |
Otherwise, view parameters are displayed and changed interactively. |
316 |
.TP |
317 |
.BI V " [ vw [ rfile ] ]" |
318 |
Append the current view as view |
319 |
.I vw |
320 |
in the rad file |
321 |
.I rfile. |
322 |
Compliment to |
323 |
.I L |
324 |
command. |
325 |
Note that the view is simply appended to the file, and previous |
326 |
views with the same name should be removed before using the file |
327 |
with |
328 |
.I rad. |
329 |
.TP |
330 |
.BI write " [ file ]" |
331 |
Write picture to |
332 |
.I file. |
333 |
If argument is missing, the current file name is used. |
334 |
.TP |
335 |
.BR ^Z |
336 |
Stop the program. |
337 |
The screen will be redrawn when the program resumes. |
338 |
.SH ENVIRONMENT |
339 |
RAYPATH the directories to check for auxiliary files. |
340 |
DISPLAY_GAMMA the value to use for monitor gamma correction. |
341 |
.SH AUTHOR |
342 |
Greg Ward |
343 |
.SH "SEE ALSO" |
344 |
getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1) |
