root/Development/ray/doc/man/man1/rview.1
Revision: 1.3
Committed: Thu Jan 1 19:31:45 2004 UTC (22 years ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.3 .\" RCSid "$Id: rview.1,v 1.2 2003/12/09 15:59:07 greg Exp $"
2 greg 1.1 .TH RVIEW 1 2/14/96 RADIANCE
3     .SH NAME
4     rview - generate RADIANCE images interactively
5     .SH SYNOPSIS
6     .B rview
7     [
8     .B "rpict options"
9     ][
10     .B "\-o dev"
11     ][
12     .B \-b
13     ][
14     .B "\-pe exposure"
15     ]
16     [
17     .B $EVAR
18     ]
19     [
20     .B @file
21     ]
22     .B octree
23     .br
24     .B "rview [ options ] \-defaults"
25     .br
26     .B "rview \-devices"
27     .SH DESCRIPTION
28     .I Rview
29     generates RADIANCE images using
30     .I octree.
31     (The octree may be given as the output of a command enclosed in quotes
32     and preceded by a `!'.)\0
33     Options specify the viewing parameters as well as
34     giving some control over the calculation.
35     Options may be given on the command line and/or read from the
36     environment and/or read from a file.
37     A command argument beginning with a dollar sign ('$') is immediately
38     replaced by the contents of the given environment variable.
39     A command argument beginning with an at sign ('@') is immediately
40     replaced by the contents of the given file.
41     The options are the same as for rpict(1), with a few notable exceptions.
42     The
43     .I "\-r, \-z, \-S, \-P, \-PP"
44     and
45     .I \-t
46     options are not supported, and
47     .I \-o
48     specifies which output device is being used instead of the output
49     file.
50     The
51     .I "\-x, \-y"
52     and
53     .I \-pa
54     options are unnecessary, since
55     .I rview
56     scales the display image to the specified output device.
57     Additionally, the
58     .I \-b
59     option improves the display on greyscale monitors, and
60     .I \-pe
61     may be used to set an initial exposure value.
62     .PP
63     In the second form, the default values
64     for the options are printed with a brief explanation.
65     In the third form, the list of supported output devices
66     is displayed.
67     .PP
68     .I Rview
69     starts rendering the image from the selected viewpoint and
70     gradually improves the resolution of the display until
71     interrupted by keyboard input.
72     .I Rview
73     then issues a prompt (usually ':') and accepts a command
74     line from the user.
75     .I Rview
76     may also stop its calculation and wait for command input if
77     the resolution of the display has reached the resolution of the
78     graphics device.
79     At this point, it will give the 'done:' prompt and await further
80     instructions.
81     If
82     .I rview
83     runs out of memory due to lack of resources to store its computed
84     image, it will give the 'out of memory:' prompt.
85     At this prompt, the user can save the image, quit, or even restart
86     a new image, although this is not generally recommended
87     on virtual memory machines for efficiency reasons.
88     .PP
89     .I Rview
90     is not meant to be a rendering program, and we strongly recommend that
91     .I rpict(1)
92     be used instead for that purpose.
93     Since
94     .I rpict(1)
95     does not store its image in memory or update any display of its output,
96     it is much faster and less wasteful of its resources than
97     .I rview.
98     .I Rview
99     is intended as a quick interactive program for deciding viewpoints
100     and debugging scene descriptions and is not suited for producing
101     polished images.
102     .SH COMMANDS
103     Once the program starts, a number of commands can be used
104     to control it.
105     A command is given by its name, which can be abbreviated,
106     followed by its arguments.
107     .TP 10n
108     .BI aim " [ mag [ x y z ] ]"
109     Zoom in by
110     .I "mag"
111     on point
112     .I "x y z".
113     The view point is held constant;
114     only the view direction and size are changed.
115     If
116     .I "x y z"
117     is missing, the cursor is used to select the view center.
118     A negative magnification factor means zoom out.
119     The default factor is one.
120     .TP
121     .BR ^C
122     Interrupt.
123     Go to the command line.
124     .TP
125     .BI exposure " [ spec ]"
126     Adjust exposure.
127     The number
128     .I spec
129     is a multiplier used to compensate the average exposure.
130     A value of 1 renormalizes the image to the computed average, which
131     is usually done immediately after startup.
132     If
133     .I spec
134     begins with a '+' or '-',
135     the compensation is interpreted in f-stops (ie. the power of two).
136     If
137     .I spec
138     begins with an '=', an absolute setting is performed.
139     An '=' by itself permits interactive display and setting of the exposure.
140     If
141     .I spec
142     begins with an '@', the exposure is adjusted to present similar
143     visibility to what would be experienced in the real environment.
144     If
145     .I spec
146     is absent, or an '@' is followed by nothing, then
147     the cursor is used to pick a specific image
148     location for normalization.
149     .TP
150     .BI frame " [ xmin ymin xmax ymax ]"
151     Set frame for refinement.
152     If coordinates are absent, the cursor is used to
153     pick frame boundaries.
154     If ``all'' is specified, the frame is reset to the entire image.
155     .TP
156     .BR free
157     Free cached object structures and associated data.
158     This command may be useful when memory is low and a completely
159     different view is being generated from the one previous.
160     .TP
161     .BI last " [ file ]"
162     Restore the previous view.
163     If a view or picture
164     .I file
165     is specified, the parameters are taken from the last view entry
166     in the file.
167     .TP
168     .BI L " [ vw [ rfile ] ]"
169     Load parameters for view
170     .I vw
171     from the
172     .I rad(1)
173     input file,
174     .I rfile.
175     Both
176     .I vw
177     and
178     .I rfile
179     must be given the first call, but subsequent calls will use the last
180     .I rfile
181     as a default, and "1" as the default view (ie. the first view
182     appearing in
183     .I rfile).
184     If
185     .I rview
186     was started by
187     .I rad,
188     then the
189     .I rfile
190     parameter will initially default to the rad input file used.
191     .TP
192     .BI move " [ mag [ x y z ] ]"
193     Move camera
194     .I mag
195     times closer to point
196     .I "x y z".
197     For a perspective projection (or fisheye view),
198     only the view point is changed;
199     the view direction and size remain constant.
200     The view size must be modified in a parallel projection since
201     it determines magnification.
202     If
203     .I "x y z"
204     is missing, the cursor is used to select the view center.
205     A negative magnification factor decreases the object size.
206     The default factor is one.
207     Care must be taken to avoid moving behind or inside other objects.
208     .TP
209     .BR new
210     Restart the image.
211     Usually used after the "set" command.
212     .TP
213     .BI pivot " angle [ elev [ mag [ x y z ] ] ]"
214     Similar to the "move" command, but pivots the view about a selected point.
215     The
216     .I angle
217     is measured in degrees around the view up vector using the right hand rule.
218     The optional
219     .I elev
220     is the elevation in degrees from the pivot point; positive raises the view point
221     to look downward and negative lowers the view point to look upward.
222     .TP
223     .BR quit
224     Quit the program.
225     .TP
226     .BR ^R
227     Redraw the image.
228     Use when the display gets corrupted.
229     On some displays, occassionally forcing a redraw can improve appearance,
230     as more color information is available and the driver can make a better
231     color table selection.
232     .TP
233     .BI rotate " angle [ elev [ mag ] ]"
234     Rotate the camera horizontally by
235     .I angle
236     degrees.
237     If an elevation is specified, the camera looks upward
238     .I elev
239     degrees.
240     (Negative means look downward.)
241     .TP
242     .BI set " [ var [ val ] ]"
243     Check/change program variable.
244     If
245     .I var
246     is absent, the list of available variables is displayed.
247     If
248     .I val
249     is absent, the current value of the variable is displayed
250     and changed interactively.
251     Otherwise, the variable
252     .I var
253     assumes the value
254     .I val.
255     Variables include:
256     ambient value (av),
257     ambient value weight (aw),
258     ambient bounces (ab),
259     ambient accuracy (aa),
260     ambient divisions (ad),
261     ambient radius (ar),
262     ambient samples (as),
263     black&white (b),
264     direct jitter (dj),
265     direct sampling (ds),
266     direct threshold (dt),
267     direct visibility (dv),
268     irradiance (i),
269     limit weight (lw),
270     limit recursion (lr),
271     medium extinction (me),
272     medium albedo (ma),
273     medium eccentricity (mg),
274     medium sampling (ms),
275     pixel sample (ps),
276     pixel threshold (pt),
277     back face visibility (bv),
278     specular jitter (sj), and
279     specular threshold (st).
280     Once a variable has been changed, the "new" command can be used
281     to recompute the image with the new parameters.
282     If a program variable is not available here, it may show up under
283     some other command or it may be impossible to change
284     once the program is running.
285     .TP
286     .BI trace " [ xbeg ybeg zbeg xdir ydir zdir ]"
287     Trace a ray.
288     If the ray origin and direction are absent, the cursor is used
289     to pick a location in the image to trace.
290     The object intersected and its material, location and value are displayed.
291     .TP
292     .BI view " [ file [ comments ] ]"
293     Check/change view parameters.
294     If
295     .I file
296     is present, the view parameters are appended to a file, followed by
297     .I comments
298     if any.
299     Alternatively, view options may be given directly on the command line
300     instead of an output view file.
301     Otherwise, view parameters are displayed and changed interactively.
302     .TP
303     .BI V " [ vw [ rfile ] ]"
304     Append the current view as view
305     .I vw
306     in the rad file
307     .I rfile.
308     Compliment to
309     .I L
310     command.
311     Note that the view is simply appended to the file, and previous
312     views with the same name should be removed before using the file
313     with
314     .I rad.
315     .TP
316     .BI write " [ file ]"
317     Write picture to
318     .I file.
319     If argument is missing, the current file name is used.
320     .TP
321     .BR ^Z
322     Stop the program.
323     The screen will be redrawn when the program resumes.
324     .SH ENVIRONMENT
325     RAYPATH the directories to check for auxiliary files.
326     DISPLAY_GAMMA the value to use for monitor gamma correction.
327     .SH AUTHOR
328     Greg Ward
329     .SH "SEE ALSO"
330     getinfo(1), lookamb(1), oconv(1), pfilt(1), rad(1), rpict(1), rtrace(1)
