root/radiance/ray/doc/man/man1/rtrace.1
Wed Apr 23 15:09:03 2025 UTC (7 weeks, 2 days ago) by greg
Changes since 1.41: +6 -3 lines
Diff to previous 1.41
docs: Wording fixes to man pages regarding -e and -f options
Tue Apr 22 17:12:25 2025 UTC (7 weeks, 3 days ago) by greg
Changes since 1.40: +11 -2 lines
Diff to previous 1.40
Tue Dec 12 16:31:45 2023 UTC (18 months ago) by greg
Changes since 1.39: +3 -3 lines
Diff to previous 1.39
Wed Dec 6 01:27:00 2023 UTC (18 months, 1 week ago) by greg
Changes since 1.38: +5 -3 lines
Diff to previous 1.38
docs(rmtxcomb): Added man page for new rmtxcomb tool
Wed Nov 15 19:23:37 2023 UTC (18 months, 4 weeks ago) by greg
Changes since 1.37: +4 -7 lines
Diff to previous 1.37
docs: Made note that outputs for -pY, -pS, and -pM are luminance values
Wed Nov 15 18:02:52 2023 UTC (18 months, 4 weeks ago) by greg
Changes since 1.36: +43 -2 lines
Diff to previous 1.36
Wed Oct 19 21:25:20 2022 UTC (2 years, 7 months ago) by greg
Changes since 1.35: +20 -2 lines
Diff to previous 1.35
Wed Oct 19 18:23:14 2022 UTC (2 years, 7 months ago) by greg
Changes since 1.34: +16 -16 lines
Diff to previous 1.34
docs: made use of "virtual" and "secondary" sources more consistent
Wed Jan 8 21:18:51 2020 UTC (5 years, 5 months ago) by greg
Changes since 1.33: +3 -2 lines
Diff to previous 1.33
Added reference to rsplit
Thu Jul 4 01:07:25 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.32: +7 -5 lines
Diff to previous 1.32
Made -f?c RGBE output compatible with any of 'vVWrx' options and added warning
Fri Jan 11 21:12:24 2019 UTC (6 years, 5 months ago) by greg
Changes since 1.31: +3 -3 lines
Diff to previous 1.31
Fixed incorrect wording on -lr option
Tue Nov 13 19:58:33 2018 UTC (6 years, 7 months ago) by greg
Changes since 1.30: +9 -1 lines
Diff to previous 1.30
Tue Mar 20 02:40:38 2018 UTC (7 years, 2 months ago) by greg
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
Wrote rtpict program to run rpict as if it had a -n option
Fri Jan 26 18:30:27 2018 UTC (7 years, 4 months ago) by rschregle
Changes since 1.28: +4 -2 lines
Diff to previous 1.28
Documented treatment of contrib photons as global under rpict/rtrace
Wed May 18 12:45:55 2016 UTC (9 years ago) by rschregle
Changes since 1.27: +28 -1 lines
Diff to previous 1.27
Updated man pages with pmap parallelisation and ooC options
Fri Jun 5 08:49:01 2015 UTC (10 years ago) by rschregle
Changes since 1.26: +21 -11 lines
Diff to previous 1.26
Revised -am and -ab options, the latter defaulting to 1 in pmap mode
Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
Changes since 1.25: +65 -5 lines
Diff to previous 1.25
Sat Jan 25 18:27:39 2014 UTC (11 years, 4 months ago) by greg
Changes since 1.24: +4 -5 lines
Diff to previous 1.24
Thu Nov 15 19:41:03 2012 UTC (12 years, 7 months ago) by greg
Changes since 1.23: +2 -2 lines
Diff to previous 1.23
Thu Jun 14 22:42:21 2012 UTC (13 years ago) by greg
Diff to previous 1.22
Fri Oct 8 22:08:26 2010 UTC (14 years, 8 months ago) by greg
Changes since 1.21: +8 -8 lines
Diff to previous 1.21
Sun Sep 26 15:49:39 2010 UTC (14 years, 8 months ago) by greg
Changes since 1.20: +7 -2 lines
Diff to previous 1.20
Eliminated flushing with -x >1 if -y also set to improve -n performance
Tue Jan 26 04:42:16 2010 UTC (15 years, 4 months ago) by greg
Changes since 1.19: +4 -3 lines
Diff to previous 1.19
Corrected description of -lr option.
Sun Dec 13 19:13:03 2009 UTC (15 years, 6 months ago) by greg
Changes since 1.18: +3 -5 lines
Diff to previous 1.18
Sat Dec 12 19:00:59 2009 UTC (15 years, 6 months ago) by greg
Changes since 1.17: +21 -1 lines
Diff to previous 1.17
Wed Mar 11 02:27:26 2009 UTC (16 years, 3 months ago) by greg
Diff to previous 1.16
Fixed error in example
Mon Nov 10 19:08:17 2008 UTC (16 years, 7 months ago) by greg
Changes since 1.15: +4 -4 lines
Diff to previous 1.15
Tue Sep 4 17:36:41 2007 UTC (17 years, 9 months ago) by greg
Diff to previous 1.14
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Sun Feb 5 22:22:20 2006 UTC (19 years, 4 months ago) by greg
Changes since 1.13: +3 -1 lines
Diff to previous 1.13
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Tue Jun 14 03:34:14 2005 UTC (20 years ago) by greg
Diff to previous 1.12
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:55 2005 UTC (20 years ago) by greg
Changes since 1.11: +7 -1 lines
Diff to previous 1.11
Tue May 31 18:01:08 2005 UTC (20 years ago) by greg
Changes since 1.10: +20 -4 lines
Diff to previous 1.10
Fri May 27 19:15:28 2005 UTC (20 years ago) by greg
Diff to previous 1.9
Wording tweaks
Thu May 26 06:55:22 2005 UTC (20 years ago) by greg
Changes since 1.8: +9 -9 lines
Diff to previous 1.8
Wed May 25 04:44:24 2005 UTC (20 years ago) by greg
Changes since 1.7: +11 -2 lines
Diff to previous 1.7
Tue Apr 19 01:15:06 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.6: +7 -3 lines
Diff to previous 1.6
Thu Apr 14 18:04:12 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.5: +21 -19 lines
Diff to previous 1.5
Wed Feb 16 05:40:07 2005 UTC (20 years, 4 months ago) by greg
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Tue Dec 9 15:59:07 2003 UTC (21 years, 6 months ago) by greg
Fixed RCSid specification
Fri Apr 18 17:29:21 2003 UTC (22 years, 2 months ago) by greg
Added rtrace -oc option to output local (u,v) coordinates
Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Added documentation to repository
