root/radiance/ray/doc/man/man1/rtrace.1
Revision: 1.42
Committed: Wed Apr 23 15:09:03 2025 UTC (3 weeks, 6 days ago) by greg
Changes since 1.41: +6 -3 lines
docs: Wording fixes to man pages regarding -e and -f options
1 .\" RCSid "$Id: rtrace.1,v 1.41 2025/04/22 17:12:25 greg Exp $"
2 .TH RTRACE 1 10/17/97 RADIANCE
3 .SH NAME
4 rtrace - trace rays in RADIANCE scene
5 .SH SYNOPSIS
6 .B rtrace
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 .B octree
17 .br
18 .B "rtrace [ options ] \-defaults"
19 .br
20 .B "rtrace \-features [feat1 ..]"
21 .SH DESCRIPTION
22 .I Rtrace
23 traces rays from the standard input through the RADIANCE scene given by
24 .I octree
25 and sends the results to the standard output.
26 (The octree may be given as the output of a command enclosed in quotes
27 and preceded by a `!'.)\0
28 Input for each ray is:
29
30 xorg yorg zorg xdir ydir zdir
31
32 If the direction vector is (0,0,0), a bogus record
33 is printed and the output is flushed if the
34 .I -x
35 value is one or zero.
36 (See the notes on this option below.)\0
37 This may be useful for programs that run
38 .I rtrace
39 as a separate process.
40 .PP
41 In the second form shown above, the default values
42 for the options (modified by those options present)
43 are printed with a brief explanation.
44 .PP
45 In the third form, a list of supported features is sent
46 to the standard output, one per line.
47 If additional arguments follow, they are checked for presence in
48 this list.
49 If a feature includes subfeatures, these may be checked as well by
50 specifying:
51 .nf
52
53 rtrace -features FeatName=subfeat1,subfeat2
54
55 .fi
56 If any named feature or subfeature is missing, an error is
57 reported and the program returns an error status.
58 If all of the named features are present, a zero status is returned.
59 .PP
60 Options may be given on the command line and/or read from the
61 environment and/or read from a file.
62 A command argument beginning with a dollar sign ('$') is immediately
63 replaced by the contents of the given environment variable.
64 A command argument beginning with an at sign ('@') is immediately
65 replaced by the contents of the given file.
66 Most options are followed by one or more arguments, which must be
67 separated from the option and each other by white space.
68 The exceptions to this rule are the boolean options.
69 Normally, the appearance of a boolean option causes a feature to
70 be "toggled", that is switched from off to on or on to off
71 depending on its previous state.
72 Boolean options may also be set
73 explicitly by following them immediately with a '+' or '-', meaning
74 on or off, respectively.
75 Synonyms for '+' are any of the characters "yYtT1", and synonyms
76 for '-' are any of the characters "nNfF0".
77 All other characters will generate an error.
78 .TP 10n
79 .BI -f io
80 Format input according to the character
81 .I i
82 and output according to the character
83 .I o.
84 .I Rtrace
85 understands the following input and output formats: 'a' for
86 ascii, 'f' for single-precision floating point,
87 and 'd' for double-precision floating point.
88 In addition to these three choices, the character 'c' may be used
89 to denote 4-byte RGBE (Radiance) color format
90 for the output of individual color values only, and the
91 .I \-x
92 and
93 .I \-y
94 options should also be specified to create a valid output picture.
95 If the output character is missing, the input format is used.
96 .IP
97 Note that there is no space between this option and its argument.
98 .TP
99 .BI -o spec
100 Produce output fields according to
101 .I spec.
102 Characters are interpreted as follows:
103 .IP
104 o origin (input)
105 .IP
106 d direction (normalized)
107 .IP
108 v value (radiance)
109 .IP
110 V contribution (radiance)
111 .IP
112 w weight
113 .IP
114 W color coefficient
115 .IP
116 l effective length of ray
117 .IP
118 L first intersection distance
119 .IP
120 c local (u,v) coordinates
121 .IP
122 p point of intersection
123 .IP
124 n normal at intersection (perturbed)
125 .IP
126 N normal at intersection (unperturbed)
127 .IP
128 s surface name
129 .IP
130 m modifier name
131 .IP
132 M material name
133 .IP
134 r mirrored value contribution
135 .IP
136 x unmirrored value contribution
137 .IP
138 R mirrored ray length
139 .IP
140 X unmirrored ray length
141 .IP
142 ~ tilde (end of trace marker)
143 .IP
144 If the letter 't' appears in
145 .I spec,
146 then the fields following will be printed for every ray traced,
147 not just the final result.
148 If the capital letter 'T' is given instead of 't', then all rays will
149 be reported, including shadow testing rays to light sources.
150 Spawned rays are indented one tab for each level.
151 The tilde marker ('~') is a handy way of differentiating the final ray
152 value from daughter values in a traced ray tree, and usually appears
153 right before the 't' or 'T' output flags.
154 E.g.,
155 .I \-ov~TmW
156 will emit a tilde followed by a tab at the end of each trace,
157 which can be easily distinguished even in binary output.
158 .IP
159 Note that there is no space between this option and its argument.
160 .TP
161 .BI -te \ mod
162 Append
163 .I mod
164 to the trace exclude list,
165 so that it will not be reported by the trace option
166 .I (\-o*t*).
167 Any ray striking an object having
168 .I mod
169 as its modifier will not be reported to the standard output with
170 the rest of the rays being traced.
171 This option has no effect unless either the 't' or 'T'
172 option has been given as part of the output specifier.
173 Any number of excluded modifiers may be given, but each
174 must appear in a separate option.
175 .TP
176 .BI -ti \ mod
177 Add
178 .I mod
179 to the trace include list,
180 so that it will be reported by the trace option.
181 The program can use either an include list or an exclude
182 list, but not both.
183 .TP
184 .BI -tE \ file
185 Same as
186 .I \-te,
187 except read modifiers to be excluded from
188 .I file.
189 The RAYPATH environment variable determines which directories are
190 searched for this file.
191 The modifier names are separated by white space in the file.
192 .TP
193 .BI -tI \ file
194 Same as
195 .I \-ti,
196 except read modifiers to be included from
197 .I file.
198 .TP
199 .BR \-i
200 Boolean switch to compute irradiance rather than radiance values.
201 This only affects the final result, substituting a Lambertian
202 surface and multiplying the radiance by pi.
203 Glass and other transparent surfaces are ignored during this stage.
204 Light sources still appear with their original radiance values,
205 though the
206 .I \-dv
207 option (below) may be used to override this.
208 This option is especially useful in
209 conjunction with ximage(1) for computing irradiance at scene points.
210 .TP
211 .BR \-u
212 Boolean switch to control uncorrelated random sampling.
213 When "off", a low-discrepancy sequence is used, which reduces
214 variance but can result in a brushed appearance in specular highlights.
215 When "on", pure Monte Carlo sampling is used in all calculations.
216 .TP
217 .BR \-I
218 Boolean switch to compute irradiance rather than radiance,
219 with the input origin and direction interpreted instead
220 as measurement point and orientation.
221 .TP
222 .BR \-h
223 Boolean switch for information header on output.
224 .TP
225 .BI -x \ res
226 Set the x resolution to
227 .I res.
228 The output will be flushed after every
229 .I res
230 input rays if
231 .I \-y
232 is set to zero.
233 A value of one means that every ray will be flushed, whatever
234 the setting of
235 .I \-y.
236 A value of zero means that no output flushing will take place.
237 .TP
238 .BI -y \ res
239 Set the y resolution to
240 .I res.
241 The program will exit after
242 .I res
243 scanlines have been processed, where a scanline is the number of rays
244 given by the
245 .I \-x
246 option, or 1 if
247 .I \-x
248 is zero.
249 A value of zero means the program will not halt until the end
250 of file is reached.
251 .IP
252 If both
253 .I \-x
254 and
255 .I \-y
256 options are given, a resolution string is printed at the beginning
257 of the output.
258 This is mostly useful for recovering image dimensions with
259 .I pvalue(1),
260 and for creating valid Radiance picture files using the color output
261 format.
262 (See the
263 .I \-f\*
264 option, above.)
265 .TP
266 .BI -n \ nproc
267 Execute in parallel on
268 .I nproc
269 local processes.
270 This option is incompatible with the
271 .I \-P
272 and
273 .I \-PP,
274 options.
275 Multiple processes also do not work properly with ray tree output
276 using any of the
277 .I \-o*t*
278 options.
279 There is no benefit from specifying more processes than there are
280 cores available on the system or the
281 .I \-x
282 setting, which forces a wait at each flush.
283 .TP
284 .BI -f \ source
285 Load definitions from the file
286 .I source
287 and assign at the global level.
288 The usual set of library directories is searched based on the
289 .I RAYPATH
290 environment variable.
291 .TP
292 .BI -e \ expr
293 Set additional definitions from
294 .I expr.
295 .TP
296 .BI -dj \ frac
297 Set the direct jittering to
298 .I frac.
299 A value of zero samples each source at specific sample points
300 (see the
301 .I \-ds
302 option below), giving a smoother but somewhat less accurate
303 rendering.
304 A positive value causes rays to be distributed over each
305 source sample according to its size, resulting in more accurate
306 penumbras.
307 This option should never be greater than 1, and may even
308 cause problems (such as speckle) when the value is smaller.
309 A warning about aiming failure will issued if
310 .I frac
311 is too large.
312 .TP
313 .BI -ds \ frac
314 Set the direct sampling ratio to
315 .I frac.
316 A light source will be subdivided until
317 the width of each sample area divided by the distance
318 to the illuminated point is below this ratio.
319 This assures accuracy in regions close to large area sources
320 at a slight computational expense.
321 A value of zero turns source subdivision off, sending at most one
322 shadow ray to each light source.
323 .TP
324 .BI -dt \ frac
325 Set the direct threshold to
326 .I frac.
327 Shadow testing will stop when the potential contribution of at least
328 the next and at most all remaining light sources is less than
329 this fraction of the accumulated value.
330 (See the
331 .I \-dc
332 option below.)
333 The remaining light source contributions are approximated
334 statistically.
335 A value of zero means that all light sources will be tested for shadow.
336 .TP
337 .BI \-dc \ frac
338 Set the direct certainty to
339 .I frac.
340 A value of one guarantees that the absolute accuracy of the direct calculation
341 will be equal to or better than that given in the
342 .I \-dt
343 specification.
344 A value of zero only insures that all shadow lines resulting in a contrast
345 change greater than the
346 .I \-dt
347 specification will be calculated.
348 .TP
349 .BI -dr \ N
350 Set the number of relays for virtual sources to
351 .I N.
352 A value of 0 means that virtual sources will be ignored.
353 A value of 1 means that sources will be made into first generation
354 virtual sources; a value of 2 means that first generation
355 virtual sources will also be made into second generation virtual
356 sources, and so on.
357 .TP
358 .BI -dp \ D
359 Set the virtual source presampling density to D.
360 This is the number of samples per steradian
361 that will be used to determine ahead of time whether or not
362 it is worth following shadow rays through all the reflections and/or
363 transmissions associated with a virtual source path.
364 A value of 0 means that the full virtual source path will always
365 be tested for shadows if it is tested at all.
366 .TP
367 .BR \-dv
368 Boolean switch for light source visibility.
369 With this switch off, sources will be black when viewed directly
370 although they will still participate in the direct calculation.
371 This option is mostly for the program
372 .I mkillum(1)
373 to avoid inappropriate counting of light sources, but it
374 may also be desirable in conjunction with the
375 .I \-i
376 option.
377 .TP
378 .BI -ss \ samp
379 Set the specular sampling to
380 .I samp.
381 For values less than 1, this is the degree to which the highlights
382 are sampled for rough specular materials.
383 A value greater than one causes multiple ray samples to be sent
384 to reduce noise at a commmesurate cost.
385 A value of zero means that no jittering will take place, and all
386 reflections will appear sharp even when they should be diffuse.
387 .TP
388 .BI -st \ frac
389 Set the specular sampling threshold to
390 .I frac.
391 This is the minimum fraction of reflection or transmission, under which
392 no specular sampling is performed.
393 A value of zero means that highlights will always be sampled by
394 tracing reflected or transmitted rays.
395 A value of one means that specular sampling is never used.
396 Highlights from light sources will always be correct, but
397 reflections from other surfaces will be approximated using an
398 ambient value.
399 A sampling threshold between zero and one offers a compromise between image
400 accuracy and rendering time.
401 .TP
402 .BR -bv
403 Boolean switch for back face visibility.
404 With this switch off, back faces of all objects will be invisible
405 to view rays.
406 This is dangerous unless the model was constructed such that
407 all surface normals face outward.
408 Although turning off back face visibility does not save much
409 computation time under most circumstances, it may be useful as a
410 tool for scene debugging, or for seeing through one-sided walls from
411 the outside.
412 .TP
413 .BI -av " red grn blu"
414 Set the ambient value to a radiance of
415 .I "red grn blu".
416 This is the final value used in place of an
417 indirect light calculation.
418 If the number of ambient bounces is one or greater and the ambient
419 value weight is non-zero (see
420 .I -aw
421 and
422 .I -ab
423 below), this value may be modified by the computed indirect values
424 to improve overall accuracy.
425 .TP
426 .BI -aw \ N
427 Set the relative weight of the ambient value given with the
428 .I -av
429 option to
430 .I N.
431 As new indirect irradiances are computed, they will modify the
432 default ambient value in a moving average, with the specified weight
433 assigned to the initial value given on the command and all other
434 weights set to 1.
435 If a value of 0 is given with this option, then the initial ambient
436 value is never modified.
437 This is the safest value for scenes with large differences in
438 indirect contributions, such as when both indoor and outdoor
439 (daylight) areas are visible.
440 .TP
441 .BI -ab \ N
442 Set the number of ambient bounces to
443 .I N.
444 This is the maximum number of diffuse bounces computed by the indirect
445 calculation. A value of zero implies no indirect calculation.
446 .IP
447 This value defaults to 1 in photon mapping mode (see
448 .I -ap
449 below), implying that global photon irradiance is always computed via
450 .I one
451 ambient bounce; this behaviour applies to any positive number of ambient
452 bounces, regardless of the actual value specified. A negative value enables
453 a preview mode that directly visualises the irradiance from the global
454 photon map without any ambient bounces.
455 .TP
456 .BI -ar \ res
457 Set the ambient resolution to
458 .I res.
459 This number will determine the maximum density of ambient values
460 used in interpolation.
461 Error will start to increase on surfaces spaced closer than
462 the scene size divided by the ambient resolution.
463 The maximum ambient value density is the scene size times the
464 ambient accuracy (see the
465 .I \-aa
466 option below) divided by the ambient resolution.
467 The scene size can be determined using
468 .I getinfo(1)
469 with the
470 .I \-d
471 option on the input octree.
472 .TP
473 .BI -aa \ acc
474 Set the ambient accuracy to
475 .I acc.
476 This value will approximately equal the error
477 from indirect irradiance interpolation.
478 A value of zero implies no interpolation.
479 .TP
480 .BI -ad \ N
481 Set the number of ambient divisions to
482 .I N.
483 The error in the Monte Carlo calculation of indirect
484 irradiance will be inversely proportional to the square
485 root of this number.
486 A value of zero implies no indirect calculation.
487 .TP
488 .BI -as \ N
489 Set the number of ambient super-samples to
490 .I N.
491 Super-samples are applied only to the ambient divisions which
492 show a significant change.
493 .TP
494 .BI -af \ fname
495 Set the ambient file to
496 .I fname.
497 This is where indirect irradiance will be stored and retrieved.
498 Normally, indirect irradiance values are kept in memory and
499 lost when the program finishes or dies.
500 By using a file, different invocations can share irradiance
501 values, saving time in the computation.
502 The ambient file is in a machine-independent binary format
503 which can be examined with
504 .I lookamb(1).
505 .IP
506 The ambient file may also be used as a means of communication and
507 data sharing between simultaneously executing processes.
508 The same file may be used by multiple processes, possibly running on
509 different machines and accessing the file via the network (ie.
510 .I nfs(4)).
511 The network lock manager
512 .I lockd(8)
513 is used to insure that this information is used consistently.
514 .IP
515 If any calculation parameters are changed or the scene
516 is modified, the old ambient file should be removed so that
517 the calculation can start over from scratch.
518 For convenience, the original ambient parameters are listed in the
519 header of the ambient file.
520 .I Getinfo(1)
521 may be used to print out this information.
522 .TP
523 .BI -ae \ mod
524 Append
525 .I mod
526 to the ambient exclude list,
527 so that it will not be considered during the indirect calculation.
528 This is a hack for speeding the indirect computation by
529 ignoring certain objects.
530 Any object having
531 .I mod
532 as its modifier will get the default ambient
533 level rather than a calculated value.
534 Any number of excluded modifiers may be given, but each
535 must appear in a separate option.
536 .TP
537 .BI -ai \ mod
538 Add
539 .I mod
540 to the ambient include list,
541 so that it will be considered during the indirect calculation.
542 The program can use either an include list or an exclude
543 list, but not both.
544 .TP
545 .BI -aE \ file
546 Same as
547 .I \-ae,
548 except read modifiers to be excluded from
549 .I file.
550 The RAYPATH environment variable determines which directories are
551 searched for this file.
552 The modifier names are separated by white space in the file.
553 .TP
554 .BI -aI \ file
555 Same as
556 .I \-ai,
557 except read modifiers to be included from
558 .I file.
559 .TP
560 .BI -ap " file [bwidth1 [bwidth2]]"
561 Enable photon mapping mode. Loads a photon map generated with
562 .I mkpmap(1)
563 from
564 .I file,
565 and evaluates the indirect irradiance depending on the photon type
566 (automagically detected) using density estimates with a bandwidth of
567 .I bwidth1
568 photons, or the default bandwidth if none is specified (a warning will be
569 issued in this case).
570 .IP
571 Global photon irradiance is evaluated as part of the ambient calculation (see
572 .I \-ab
573 above), caustic photon irradiance is evaluated at primary rays, and
574 indirect inscattering in
575 .I mist
576 is accounted for by volume photons. Contribution photons are treated as
577 global photons by
578 .I rtrace.
579 .IP
580 Additionally specifying
581 .I bwidth2
582 enables bias compensation for the density estimates with a
583 minimum and maximum bandwidth of
584 .I bwidth1
585 and
586 .I bwidth2,
587 respectively.
588 .IP
589 Global photon irradiance may be optionally precomputed by
590 .I mkpmap(1),
591 in which case the bandwidth, if specified, is ignored, as the nearest photon
592 is invariably looked up.
593 .IP
594 Using direct photons replaces the direct calculation with density estimates
595 for debugging and validation of photon emission.
596 .TP
597 .BI -am " frac"
598 Maximum search radius for photon map lookups. Without this option, an
599 initial maximum search radius is estimated for each photon map from the
600 average photon distance to the distribution's centre of gravity. It is then
601 adapted to the photon density in subsequent lookups. This option imposes a
602 global fixed maximum search radius for
603 .I all
604 photon maps, thus defeating the automatic adaptation. It is useful when
605 multiple warnings about short photon lookups are issued. Note that this
606 option does not conflict with the bandwidth specified with the
607 .I \-ap
608 option; the number of photons found will not exceed the latter, but may be
609 lower if the maximum search radius contains fewer photons, thus resulting in
610 short lookups. Setting this radius too large, on the other hand, may
611 degrade performance.
612 .TP
613 .BI -ac " pagesize"
614 Set the photon cache page size when using out-of-core photon mapping. The
615 photon cache reduces disk I/O incurred by on-demand loading (paging) of
616 photons, and thus increases performance. This
617 is expressed as a (float) multiple of the density estimate bandwidth
618 specified with
619 .I \-ap
620 under the assumption that photon lookups are local to a cache page. Cache
621 performance is sensitive to this parameter: larger pagesizes will reduce the
622 paging frequency at the expense of higher latency when paging does occur.
623 Sensible values are in the range 4 (default) to 16.
624 .TP
625 .BI -aC " cachesize"
626 Set the total number of photons cached when using out-of-core photon
627 mapping, taking into account the pagesize specified by
628 .I \-ac.
629 Note that this is approximate as the number of cache pages is rounded to
630 the nearest prime. This allows adapting the cache to the available physical
631 memory. In conjunction with the
632 .I \-n
633 option, this is the cache size
634 .I per parallel process.
635 Cache performance is less sensitive to this parameter,
636 and reasonable performance can obtained with as few as 10k photons. The
637 default is 1M. This option recognises multiplier suffixes (k = 1e3, M =
638 1e6), both in upper and lower case.
639 .TP
640 .BI -me " rext gext bext"
641 Set the global medium extinction coefficient to the indicated color,
642 in units of 1/distance (distance in world coordinates).
643 Light will be scattered or absorbed over distance according to
644 this value.
645 The ratio of scattering to total scattering plus absorption is set
646 by the albedo parameter, described below.
647 .TP
648 .BI -ma " ralb galb balb"
649 Set the global medium albedo to the given value between 0\00\00
650 and 1\01\01.
651 A zero value means that all light not transmitted by the medium
652 is absorbed.
653 A unitary value means that all light not transmitted by the medium
654 is scattered in some new direction.
655 The isotropy of scattering is determined by the Heyney-Greenstein
656 parameter, described below.
657 .TP
658 .BI \-mg \ gecc
659 Set the medium Heyney-Greenstein eccentricity parameter to
660 .I gecc.
661 This parameter determines how strongly scattering favors the forward
662 direction.
663 A value of 0 indicates perfectly isotropic scattering.
664 As this parameter approaches 1, scattering tends to prefer the
665 forward direction.
666 .TP
667 .BI \-ms \ sampdist
668 Set the medium sampling distance to
669 .I sampdist,
670 in world coordinate units.
671 During source scattering, this will be the average distance between
672 adjacent samples.
673 A value of 0 means that only one sample will be taken per light
674 source within a given scattering volume.
675 .TP
676 .BI -lr \ N
677 Limit reflections to a maximum of
678 .I N,
679 if N is a positive integer.
680 If
681 .I N
682 is zero or negative, then Russian roulette is used for ray
683 termination, and the
684 .I -lw
685 setting (below) must be positive.
686 If N is a negative integer, then this limits the maximum
687 number of reflections even with Russian roulette.
688 In scenes with dielectrics and total internal reflection,
689 a setting of 0 (no limit) may cause a stack overflow.
690 .TP
691 .BI -lw \ frac
692 Limit the weight of each ray to a minimum of
693 .I frac.
694 During ray-tracing, a record is kept of the estimated contribution
695 (weight) a ray would have in the image.
696 If this weight is less than the specified minimum and the
697 .I -lr
698 setting (above) is positive, the ray is not traced.
699 Otherwise, Russian roulette is used to
700 continue rays with a probability equal to the ray weight
701 divided by the given
702 .I frac.
703 .TP
704 .BR \-ld
705 Boolean switch to limit ray distance.
706 If this option is set, then rays will only be traced as far as the
707 magnitude of each direction vector.
708 Otherwise, vector magnitude is ignored and rays are traced to infinity.
709 .TP
710 .BI -cs \ Ns
711 Use
712 .I Ns
713 bands for spectral sampling rather than the default RGB calculation space.
714 The maximum setting is controlled by the compiler macro MAXCSAMP, and
715 defaults to 24.
716 Larger values for Ns will be reduced to MAXCSAMP.
717 .TP
718 .BI -cw " nmA nmB"
719 Set extrema to the given wavelengths for spectral sampling.
720 The default is 380 and 780 nanometers.
721 The order specified does not matter.
722 .TP
723 .BR \-co
724 Boolean switch turns on spectral data output if selected.
725 The default is to reduce spectral results to RGB, but see the related
726 .I \-p*
727 options, below.
728 .TP
729 .BI -pc " xr yr xg yg xb yb xw yw"
730 Use the specified chromaticity pairs for output primaries and white
731 point rather than the standard RGB color space.
732 .TP
733 .BR \-pRGB
734 Output standard RGB values (the default).
735 .TP
736 .BR \-pXYZ
737 Output standard CIE XYZ tristimulus values rather than RGB.
738 .TP
739 .BR \-pY
740 Produce a single output channel corresponding to photopic luminance.
741 .TP
742 .BR \-pS
743 Produce a single output channel corresponding to scotopic luminance.
744 .TP
745 .BR \-pM
746 Produce a single output channel corresponding to melanopic luminance.
747 .TP
748 .BI -e \ efile
749 Send error messages and progress reports to
750 .I efile
751 instead of the standard error.
752 .TP
753 .BR \-w
754 Boolean switch to suppress warning messages.
755 .TP
756 .BI \-P \ pfile
757 Execute in a persistent mode, using
758 .I pfile
759 as the control file.
760 Persistent execution means that after reaching end-of-file on
761 its input,
762 .I rtrace
763 will fork a child process that will wait for another
764 .I rtrace
765 command with the same
766 .I \-P
767 option to attach to it.
768 (Note that since the rest of the command line options will be those
769 of the original invocation, it is not necessary to give any arguments
770 besides
771 .I \-P
772 for subsequent calls.)
773 Killing the process is achieved with the
774 .I kill(1)
775 command.
776 (The process ID in the first line of
777 .I pfile
778 may be used to identify the waiting
779 .I rtrace
780 process.)
781 This option may be used with the
782 .I \-fr
783 option of
784 .I pinterp(1)
785 to avoid the cost of starting up
786 .I rtrace
787 many times.
788 .TP
789 .BI \-PP \ pfile
790 Execute in continuous-forking persistent mode, using
791 .I pfile
792 as the control file.
793 The difference between this option and the
794 .I \-P
795 option described above is the creation of multiple duplicate
796 processes to handle any number of attaches.
797 This provides a simple and reliable mechanism of memory sharing
798 on most multiprocessing platforms, since the
799 .I fork(2)
800 system call will share memory on a copy-on-write basis.
801 .SH NOTES
802 Photons are generally surface bound (an exception are volume photons), thus
803 the ambient irradiance in photon mapping mode will be biased at positions
804 which do not lie on a surface.
805 .SH EXAMPLES
806 To compute radiance values for the rays listed in samples.inp:
807 .IP "" .2i
808 rtrace \-ov scene.oct < samples.inp > radiance.out
809 .PP
810 To compute irradiance values at locations selected with the 't'
811 command of
812 .I ximage(1):
813 .IP "" .2i
814 ximage scene.hdr | rtrace \-h \-x 1 \-i scene.oct | rcalc \-e '$1=47.4*$1+120*$2+11.6*$3'
815 .PP
816 To record the object identifier corresponding to each pixel in an image:
817 .IP "" .2i
818 vwrays \-fd scene.hdr | rtrace \-fda `vwrays \-d scene.hdr` \-os scene.oct
819 .PP
820 To compute an image with an unusual view mapping:
821 .IP "" .2i
822 cnt 480 640 | rcalc \-e 'xr:640;yr:480' \-f unusual_view.cal | rtrace
823 \-x 640 \-y 480 \-fac scene.oct > unusual.hdr
824 .PP
825 To compute ambient irradiance in photon mapping mode from a global photon
826 map global.pm via one ambient bounce, and from a caustic photon map
827 caustic.pm at sensor positions in samples.inp:
828 .IP "" .2i
829 rtrace -h -ov -ab 1 -ap global.pm 50 -ap caustic.pm 50 scene.oct <
830 samples.inp > illum.out
831 .SH ENVIRONMENT
832 RAYPATH the directories to check for auxiliary files.
833 .SH FILES
834 /tmp/rtXXXXXX common header information for picture sequence
835 .SH DIAGNOSTICS
836 If the program terminates from an input related error, the exit status
837 will be 1.
838 A system related error results in an exit status of 2.
839 If the program receives a signal that is caught, it will exit with a status
840 of 3.
841 In each case, an error message will be printed to the standard error, or
842 to the file designated by the
843 .I \-e
844 option.
845 .SH AUTHOR
846 Greg Ward
847 .SH "SEE ALSO"
848 dctimestep(1), getinfo(1), lookamb(1),
849 mkpmap(1), oconv(1), pfilt(1), pinterp(1),
850 pvalue(1), rcalc(1), rcomb(1), rcontrib(1), rcrop(1),
851 rmtxop(1), rsplit(1),
852 rpict(1), rtpict(1), rvu(1), vwrays(1), ximage(1)
