1 |
.\" RCSid "$Id: rtrace.1,v 1.33 2019/07/04 01:07:25 greg Exp $" |
2 |
.TH RTRACE 1 10/17/97 RADIANCE |
3 |
.SH NAME |
4 |
rtrace - trace rays in RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B rtrace |
7 |
8 |
.B options |
9 |
10 |
11 |
.B $EVAR |
12 |
13 |
14 |
.B @file |
15 |
16 |
.B octree |
17 |
.br |
18 |
.B "rtrace [ options ] \-defaults" |
19 |
.SH DESCRIPTION |
20 |
.I Rtrace |
21 |
traces rays from the standard input through the RADIANCE scene given by |
22 |
.I octree |
23 |
and sends the results to the standard output. |
24 |
(The octree may be given as the output of a command enclosed in quotes |
25 |
and preceded by a `!'.)\0 |
26 |
Input for each ray is: |
27 |
28 |
xorg yorg zorg xdir ydir zdir |
29 |
30 |
If the direction vector is (0,0,0), a bogus record |
31 |
is printed and the output is flushed if the |
32 |
.I -x |
33 |
value is one or zero. |
34 |
(See the notes on this option below.)\0 |
35 |
This may be useful for programs that run |
36 |
.I rtrace |
37 |
as a separate process. |
38 |
In the second form, the default values |
39 |
for the options (modified by those options present) |
40 |
are printed with a brief explanation. |
41 |
.PP |
42 |
Options may be given on the command line and/or read from the |
43 |
environment and/or read from a file. |
44 |
A command argument beginning with a dollar sign ('$') is immediately |
45 |
replaced by the contents of the given environment variable. |
46 |
A command argument beginning with an at sign ('@') is immediately |
47 |
replaced by the contents of the given file. |
48 |
Most options are followed by one or more arguments, which must be |
49 |
separated from the option and each other by white space. |
50 |
The exceptions to this rule are the boolean options. |
51 |
Normally, the appearance of a boolean option causes a feature to |
52 |
be "toggled", that is switched from off to on or on to off |
53 |
depending on its previous state. |
54 |
Boolean options may also be set |
55 |
explicitly by following them immediately with a '+' or '-', meaning |
56 |
on or off, respectively. |
57 |
Synonyms for '+' are any of the characters "yYtT1", and synonyms |
58 |
for '-' are any of the characters "nNfF0". |
59 |
All other characters will generate an error. |
60 |
.TP 10n |
61 |
.BI -f io |
62 |
Format input according to the character |
63 |
.I i |
64 |
and output according to the character |
65 |
.I o. |
66 |
.I Rtrace |
67 |
understands the following input and output formats: 'a' for |
68 |
ascii, 'f' for single-precision floating point, |
69 |
and 'd' for double-precision floating point. |
70 |
In addition to these three choices, the character 'c' may be used |
71 |
to denote 4-byte RGBE (Radiance) color format |
72 |
for the output of individual color values only, and the |
73 |
.I \-x |
74 |
and |
75 |
.I \-y |
76 |
options should also be specified to create a valid output picture. |
77 |
If the output character is missing, the input format is used. |
78 |
.IP |
79 |
Note that there is no space between this option and its argument. |
80 |
.TP |
81 |
.BI -o spec |
82 |
Produce output fields according to |
83 |
.I spec. |
84 |
Characters are interpreted as follows: |
85 |
.IP |
86 |
o origin (input) |
87 |
.IP |
88 |
d direction (normalized) |
89 |
.IP |
90 |
v value (radiance) |
91 |
.IP |
92 |
V contribution (radiance) |
93 |
.IP |
94 |
w weight |
95 |
.IP |
96 |
W color coefficient |
97 |
.IP |
98 |
l effective length of ray |
99 |
.IP |
100 |
L first intersection distance |
101 |
.IP |
102 |
c local (u,v) coordinates |
103 |
.IP |
104 |
p point of intersection |
105 |
.IP |
106 |
n normal at intersection (perturbed) |
107 |
.IP |
108 |
N normal at intersection (unperturbed) |
109 |
.IP |
110 |
s surface name |
111 |
.IP |
112 |
m modifier name |
113 |
.IP |
114 |
M material name |
115 |
.IP |
116 |
r mirrored value contribution |
117 |
.IP |
118 |
x unmirrored value contribution |
119 |
.IP |
120 |
R mirrored ray length |
121 |
.IP |
122 |
X unmirrored ray length |
123 |
.IP |
124 |
~ tilde (end of trace marker) |
125 |
.IP |
126 |
If the letter 't' appears in |
127 |
.I spec, |
128 |
then the fields following will be printed for every ray traced, |
129 |
not just the final result. |
130 |
If the capital letter 'T' is given instead of 't', then all rays will |
131 |
be reported, including shadow testing rays to light sources. |
132 |
Spawned rays are indented one tab for each level. |
133 |
The tilde marker ('~') is a handy way of differentiating the final ray |
134 |
value from daughter values in a traced ray tree, and usually appears |
135 |
right before the 't' or 'T' output flags. |
136 |
E.g., |
137 |
.I \-ov~TmW |
138 |
will emit a tilde followed by a tab at the end of each trace, |
139 |
which can be easily distinguished even in binary output. |
140 |
.IP |
141 |
142 |
.TP |
143 |
.BI -te \ mod |
144 |
Append |
145 |
.I mod |
146 |
to the trace exclude list, |
147 |
so that it will not be reported by the trace option |
148 |
.I (\-o*t*). |
149 |
Any ray striking an object having |
150 |
.I mod |
151 |
as its modifier will not be reported to the standard output with |
152 |
the rest of the rays being traced. |
153 |
This option has no effect unless either the 't' or 'T' |
154 |
option has been given as part of the output specifier. |
155 |
Any number of excluded modifiers may be given, but each |
156 |
must appear in a separate option. |
157 |
.TP |
158 |
.BI -ti \ mod |
159 |
Add |
160 |
.I mod |
161 |
to the trace include list, |
162 |
so that it will be reported by the trace option. |
163 |
The program can use either an include list or an exclude |
164 |
list, but not both. |
165 |
.TP |
166 |
.BI -tE \ file |
167 |
Same as |
168 |
.I \-te, |
169 |
except read modifiers to be excluded from |
170 |
.I file. |
171 |
The RAYPATH environment variable determines which directories are |
172 |
searched for this file. |
173 |
The modifier names are separated by white space in the file. |
174 |
.TP |
175 |
.BI -tI \ file |
176 |
Same as |
177 |
.I \-ti, |
178 |
except read modifiers to be included from |
179 |
.I file. |
180 |
.TP |
181 |
.BR \-i |
182 |
Boolean switch to compute irradiance rather than radiance values. |
183 |
This only affects the final result, substituting a Lambertian |
184 |
surface and multiplying the radiance by pi. |
185 |
Glass and other transparent surfaces are ignored during this stage. |
186 |
Light sources still appear with their original radiance values, |
187 |
though the |
188 |
.I \-dv |
189 |
option (below) may be used to override this. |
190 |
This option is especially useful in |
191 |
conjunction with ximage(1) for computing illuminance at scene points. |
192 |
.TP |
193 |
.BR \-u |
194 |
Boolean switch to control uncorrelated random sampling. |
195 |
When "off", a low-discrepancy sequence is used, which reduces |
196 |
variance but can result in a brushed appearance in specular highlights. |
197 |
When "on", pure Monte Carlo sampling is used in all calculations. |
198 |
.TP |
199 |
.BR \-I |
200 |
Boolean switch to compute irradiance rather than radiance, |
201 |
with the input origin and direction interpreted instead |
202 |
as measurement point and orientation. |
203 |
.TP |
204 |
.BR \-h |
205 |
Boolean switch for information header on output. |
206 |
.TP |
207 |
.BI -x \ res |
208 |
Set the x resolution to |
209 |
.I res. |
210 |
The output will be flushed after every |
211 |
.I res |
212 |
input rays if |
213 |
.I \-y |
214 |
is set to zero. |
215 |
A value of one means that every ray will be flushed, whatever |
216 |
the setting of |
217 |
.I \-y. |
218 |
A value of zero means that no output flushing will take place. |
219 |
.TP |
220 |
.BI -y \ res |
221 |
Set the y resolution to |
222 |
.I res. |
223 |
The program will exit after |
224 |
.I res |
225 |
scanlines have been processed, where a scanline is the number of rays |
226 |
given by the |
227 |
.I \-x |
228 |
option, or 1 if |
229 |
.I \-x |
230 |
is zero. |
231 |
A value of zero means the program will not halt until the end |
232 |
of file is reached. |
233 |
.IP |
234 |
If both |
235 |
.I \-x |
236 |
and |
237 |
.I \-y |
238 |
options are given, a resolution string is printed at the beginning |
239 |
of the output. |
240 |
This is mostly useful for recovering image dimensions with |
241 |
.I pvalue(1), |
242 |
and for creating valid Radiance picture files using the color output |
243 |
format. |
244 |
(See the |
245 |
.I \-f |
246 |
option, above.) |
247 |
.TP |
248 |
.BI -n \ nproc |
249 |
Execute in parallel on |
250 |
.I nproc |
251 |
local processes. |
252 |
This option is incompatible with the |
253 |
.I \-P |
254 |
and |
255 |
.I \-PP, |
256 |
options. |
257 |
Multiple processes also do not work properly with ray tree output |
258 |
using any of the |
259 |
.I \-o*t* |
260 |
options. |
261 |
There is no benefit from specifying more processes than there are |
262 |
cores available on the system or the |
263 |
.I \-x |
264 |
setting, which forces a wait at each flush. |
265 |
.TP |
266 |
.BI -dj \ frac |
267 |
Set the direct jittering to |
268 |
.I frac. |
269 |
A value of zero samples each source at specific sample points |
270 |
(see the |
271 |
.I \-ds |
272 |
option below), giving a smoother but somewhat less accurate |
273 |
rendering. |
274 |
A positive value causes rays to be distributed over each |
275 |
source sample according to its size, resulting in more accurate |
276 |
penumbras. |
277 |
This option should never be greater than 1, and may even |
278 |
cause problems (such as speckle) when the value is smaller. |
279 |
A warning about aiming failure will issued if |
280 |
.I frac |
281 |
is too large. |
282 |
.TP |
283 |
.BI -ds \ frac |
284 |
Set the direct sampling ratio to |
285 |
.I frac. |
286 |
A light source will be subdivided until |
287 |
the width of each sample area divided by the distance |
288 |
to the illuminated point is below this ratio. |
289 |
This assures accuracy in regions close to large area sources |
290 |
at a slight computational expense. |
291 |
A value of zero turns source subdivision off, sending at most one |
292 |
shadow ray to each light source. |
293 |
.TP |
294 |
.BI -dt \ frac |
295 |
Set the direct threshold to |
296 |
.I frac. |
297 |
Shadow testing will stop when the potential contribution of at least |
298 |
the next and at most all remaining light sources is less than |
299 |
this fraction of the accumulated value. |
300 |
(See the |
301 |
.I \-dc |
302 |
option below.) |
303 |
The remaining light source contributions are approximated |
304 |
statistically. |
305 |
A value of zero means that all light sources will be tested for shadow. |
306 |
.TP |
307 |
.BI \-dc \ frac |
308 |
Set the direct certainty to |
309 |
.I frac. |
310 |
A value of one guarantees that the absolute accuracy of the direct calculation |
311 |
will be equal to or better than that given in the |
312 |
.I \-dt |
313 |
specification. |
314 |
A value of zero only insures that all shadow lines resulting in a contrast |
315 |
change greater than the |
316 |
.I \-dt |
317 |
specification will be calculated. |
318 |
.TP |
319 |
.BI -dr \ N |
320 |
Set the number of relays for secondary sources to |
321 |
.I N. |
322 |
A value of 0 means that secondary sources will be ignored. |
323 |
A value of 1 means that sources will be made into first generation |
324 |
secondary sources; a value of 2 means that first generation |
325 |
secondary sources will also be made into second generation secondary |
326 |
sources, and so on. |
327 |
.TP |
328 |
.BI -dp \ D |
329 |
Set the secondary source presampling density to D. |
330 |
This is the number of samples per steradian |
331 |
that will be used to determine ahead of time whether or not |
332 |
it is worth following shadow rays through all the reflections and/or |
333 |
transmissions associated with a secondary source path. |
334 |
A value of 0 means that the full secondary source path will always |
335 |
be tested for shadows if it is tested at all. |
336 |
.TP |
337 |
.BR \-dv |
338 |
Boolean switch for light source visibility. |
339 |
With this switch off, sources will be black when viewed directly |
340 |
although they will still participate in the direct calculation. |
341 |
This option is mostly for the program |
342 |
.I mkillum(1) |
343 |
to avoid inappropriate counting of light sources, but it |
344 |
may also be desirable in conjunction with the |
345 |
.I \-i |
346 |
option. |
347 |
.TP |
348 |
.BI -ss \ samp |
349 |
Set the specular sampling to |
350 |
.I samp. |
351 |
For values less than 1, this is the degree to which the highlights |
352 |
are sampled for rough specular materials. |
353 |
A value greater than one causes multiple ray samples to be sent |
354 |
to reduce noise at a commmesurate cost. |
355 |
A value of zero means that no jittering will take place, and all |
356 |
reflections will appear sharp even when they should be diffuse. |
357 |
.TP |
358 |
.BI -st \ frac |
359 |
Set the specular sampling threshold to |
360 |
.I frac. |
361 |
This is the minimum fraction of reflection or transmission, under which |
362 |
no specular sampling is performed. |
363 |
A value of zero means that highlights will always be sampled by |
364 |
tracing reflected or transmitted rays. |
365 |
A value of one means that specular sampling is never used. |
366 |
Highlights from light sources will always be correct, but |
367 |
reflections from other surfaces will be approximated using an |
368 |
ambient value. |
369 |
A sampling threshold between zero and one offers a compromise between image |
370 |
accuracy and rendering time. |
371 |
.TP |
372 |
.BR -bv |
373 |
Boolean switch for back face visibility. |
374 |
With this switch off, back faces of all objects will be invisible |
375 |
to view rays. |
376 |
This is dangerous unless the model was constructed such that |
377 |
all surface normals face outward. |
378 |
Although turning off back face visibility does not save much |
379 |
computation time under most circumstances, it may be useful as a |
380 |
tool for scene debugging, or for seeing through one-sided walls from |
381 |
the outside. |
382 |
.TP |
383 |
.BI -av " red grn blu" |
384 |
Set the ambient value to a radiance of |
385 |
.I "red grn blu". |
386 |
This is the final value used in place of an |
387 |
indirect light calculation. |
388 |
If the number of ambient bounces is one or greater and the ambient |
389 |
value weight is non-zero (see |
390 |
.I -aw |
391 |
and |
392 |
.I -ab |
393 |
below), this value may be modified by the computed indirect values |
394 |
to improve overall accuracy. |
395 |
.TP |
396 |
.BI -aw \ N |
397 |
Set the relative weight of the ambient value given with the |
398 |
.I -av |
399 |
option to |
400 |
.I N. |
401 |
As new indirect irradiances are computed, they will modify the |
402 |
default ambient value in a moving average, with the specified weight |
403 |
assigned to the initial value given on the command and all other |
404 |
weights set to 1. |
405 |
If a value of 0 is given with this option, then the initial ambient |
406 |
value is never modified. |
407 |
This is the safest value for scenes with large differences in |
408 |
indirect contributions, such as when both indoor and outdoor |
409 |
(daylight) areas are visible. |
410 |
.TP |
411 |
.BI -ab \ N |
412 |
Set the number of ambient bounces to |
413 |
.I N. |
414 |
This is the maximum number of diffuse bounces computed by the indirect |
415 |
calculation. A value of zero implies no indirect calculation. |
416 |
.IP |
417 |
This value defaults to 1 in photon mapping mode (see |
418 |
.I -ap |
419 |
below), implying that global photon irradiance is always computed via |
420 |
.I one |
421 |
ambient bounce; this behaviour applies to any positive number of ambient |
422 |
bounces, regardless of the actual value specified. A negative value enables |
423 |
a preview mode that directly visualises the irradiance from the global |
424 |
photon map without any ambient bounces. |
425 |
.TP |
426 |
.BI -ar \ res |
427 |
Set the ambient resolution to |
428 |
.I res. |
429 |
This number will determine the maximum density of ambient values |
430 |
used in interpolation. |
431 |
Error will start to increase on surfaces spaced closer than |
432 |
the scene size divided by the ambient resolution. |
433 |
The maximum ambient value density is the scene size times the |
434 |
ambient accuracy (see the |
435 |
.I \-aa |
436 |
option below) divided by the ambient resolution. |
437 |
The scene size can be determined using |
438 |
.I getinfo(1) |
439 |
with the |
440 |
.I \-d |
441 |
option on the input octree. |
442 |
.TP |
443 |
.BI -aa \ acc |
444 |
Set the ambient accuracy to |
445 |
.I acc. |
446 |
This value will approximately equal the error |
447 |
from indirect illuminance interpolation. |
448 |
A value of zero implies no interpolation. |
449 |
.TP |
450 |
.BI -ad \ N |
451 |
Set the number of ambient divisions to |
452 |
.I N. |
453 |
The error in the Monte Carlo calculation of indirect |
454 |
illuminance will be inversely proportional to the square |
455 |
root of this number. |
456 |
457 |
.TP |
458 |
.BI -as \ N |
459 |
Set the number of ambient super-samples to |
460 |
.I N. |
461 |
Super-samples are applied only to the ambient divisions which |
462 |
show a significant change. |
463 |
.TP |
464 |
.BI -af \ fname |
465 |
Set the ambient file to |
466 |
.I fname. |
467 |
This is where indirect illuminance will be stored and retrieved. |
468 |
Normally, indirect illuminance values are kept in memory and |
469 |
lost when the program finishes or dies. |
470 |
By using a file, different invocations can share illuminance |
471 |
values, saving time in the computation. |
472 |
The ambient file is in a machine-independent binary format |
473 |
which can be examined with |
474 |
.I lookamb(1). |
475 |
.IP |
476 |
The ambient file may also be used as a means of communication and |
477 |
data sharing between simultaneously executing processes. |
478 |
The same file may be used by multiple processes, possibly running on |
479 |
different machines and accessing the file via the network (ie. |
480 |
.I nfs(4)). |
481 |
The network lock manager |
482 |
.I lockd(8) |
483 |
is used to insure that this information is used consistently. |
484 |
.IP |
485 |
If any calculation parameters are changed or the scene |
486 |
is modified, the old ambient file should be removed so that |
487 |
the calculation can start over from scratch. |
488 |
For convenience, the original ambient parameters are listed in the |
489 |
header of the ambient file. |
490 |
.I Getinfo(1) |
491 |
may be used to print out this information. |
492 |
.TP |
493 |
.BI -ae \ mod |
494 |
Append |
495 |
.I mod |
496 |
to the ambient exclude list, |
497 |
so that it will not be considered during the indirect calculation. |
498 |
This is a hack for speeding the indirect computation by |
499 |
ignoring certain objects. |
500 |
Any object having |
501 |
.I mod |
502 |
as its modifier will get the default ambient |
503 |
level rather than a calculated value. |
504 |
505 |
506 |
.TP |
507 |
.BI -ai \ mod |
508 |
Add |
509 |
.I mod |
510 |
to the ambient include list, |
511 |
so that it will be considered during the indirect calculation. |
512 |
513 |
514 |
.TP |
515 |
.BI -aE \ file |
516 |
Same as |
517 |
.I \-ae, |
518 |
519 |
.I file. |
520 |
521 |
522 |
523 |
.TP |
524 |
.BI -aI \ file |
525 |
Same as |
526 |
.I \-ai, |
527 |
528 |
.I file. |
529 |
.TP |
530 |
.BI -ap " file [bwidth1 [bwidth2]]" |
531 |
Enable photon mapping mode. Loads a photon map generated with |
532 |
.I mkpmap(1) |
533 |
from |
534 |
.I file, |
535 |
and evaluates the indirect irradiance depending on the photon type |
536 |
(automagically detected) using density estimates with a bandwidth of |
537 |
.I bwidth1 |
538 |
photons, or the default bandwidth if none is specified (a warning will be |
539 |
issued in this case). |
540 |
.IP |
541 |
Global photon irradiance is evaluated as part of the ambient calculation (see |
542 |
.I \-ab |
543 |
above), caustic photon irradiance is evaluated at primary rays, and |
544 |
indirect inscattering in |
545 |
.I mist |
546 |
is accounted for by volume photons. Contribution photons are treated as |
547 |
global photons by |
548 |
.I rtrace. |
549 |
.IP |
550 |
Additionally specifying |
551 |
.I bwidth2 |
552 |
enables bias compensation for the density estimates with a |
553 |
minimum and maximum bandwidth of |
554 |
.I bwidth1 |
555 |
and |
556 |
.I bwidth2, |
557 |
respectively. |
558 |
.IP |
559 |
Global photon irradiance may be optionally precomputed by |
560 |
.I mkpmap(1), |
561 |
in which case the bandwidth, if specified, is ignored, as the nearest photon |
562 |
is invariably looked up. |
563 |
.IP |
564 |
Using direct photons replaces the direct calculation with density estimates |
565 |
for debugging and validation of photon emission. |
566 |
.TP |
567 |
.BI -am " frac" |
568 |
Maximum search radius for photon map lookups. Without this option, an |
569 |
initial maximum search radius is estimated for each photon map from the |
570 |
average photon distance to the distribution's centre of gravity. It is then |
571 |
adapted to the photon density in subsequent lookups. This option imposes a |
572 |
global fixed maximum search radius for |
573 |
.I all |
574 |
photon maps, thus defeating the automatic adaptation. It is useful when |
575 |
multiple warnings about short photon lookups are issued. Note that this |
576 |
option does not conflict with the bandwidth specified with the |
577 |
.I \-ap |
578 |
option; the number of photons found will not exceed the latter, but may be |
579 |
lower if the maximum search radius contains fewer photons, thus resulting in |
580 |
short lookups. Setting this radius too large, on the other hand, may |
581 |
degrade performance. |
582 |
.TP |
583 |
.BI -ac " pagesize" |
584 |
Set the photon cache page size when using out-of-core photon mapping. The |
585 |
photon cache reduces disk I/O incurred by on-demand loading (paging) of |
586 |
photons, and thus increases performance. This |
587 |
is expressed as a (float) multiple of the density estimate bandwidth |
588 |
specified with |
589 |
.I \-ap |
590 |
under the assumption that photon lookups are local to a cache page. Cache |
591 |
performance is sensitive to this parameter: larger pagesizes will reduce the |
592 |
paging frequency at the expense of higher latency when paging does occur. |
593 |
Sensible values are in the range 4 (default) to 16. |
594 |
.TP |
595 |
.BI -aC " cachesize" |
596 |
Set the total number of photons cached when using out-of-core photon |
597 |
mapping, taking into account the pagesize specified by |
598 |
.I \-ac. |
599 |
Note that this is approximate as the number of cache pages is rounded to |
600 |
the nearest prime. This allows adapting the cache to the available physical |
601 |
memory. In conjunction with the |
602 |
.I \-n |
603 |
option, this is the cache size |
604 |
.I per parallel process. |
605 |
Cache performance is less sensitive to this parameter, |
606 |
and reasonable performance can obtained with as few as 10k photons. The |
607 |
default is 1M. This option recognises multiplier suffixes (k = 1e3, M = |
608 |
1e6), both in upper and lower case. |
609 |
.TP |
610 |
.BI -me " rext gext bext" |
611 |
Set the global medium extinction coefficient to the indicated color, |
612 |
in units of 1/distance (distance in world coordinates). |
613 |
Light will be scattered or absorbed over distance according to |
614 |
this value. |
615 |
The ratio of scattering to total scattering plus absorption is set |
616 |
by the albedo parameter, described below. |
617 |
.TP |
618 |
.BI -ma " ralb galb balb" |
619 |
Set the global medium albedo to the given value between 0\00\00 |
620 |
and 1\01\01. |
621 |
A zero value means that all light not transmitted by the medium |
622 |
is absorbed. |
623 |
A unitary value means that all light not transmitted by the medium |
624 |
is scattered in some new direction. |
625 |
The isotropy of scattering is determined by the Heyney-Greenstein |
626 |
627 |
.TP |
628 |
.BI \-mg \ gecc |
629 |
Set the medium Heyney-Greenstein eccentricity parameter to |
630 |
.I gecc. |
631 |
This parameter determines how strongly scattering favors the forward |
632 |
direction. |
633 |
A value of 0 indicates perfectly isotropic scattering. |
634 |
As this parameter approaches 1, scattering tends to prefer the |
635 |
forward direction. |
636 |
.TP |
637 |
.BI \-ms \ sampdist |
638 |
Set the medium sampling distance to |
639 |
.I sampdist, |
640 |
in world coordinate units. |
641 |
During source scattering, this will be the average distance between |
642 |
adjacent samples. |
643 |
A value of 0 means that only one sample will be taken per light |
644 |
source within a given scattering volume. |
645 |
.TP |
646 |
.BI -lr \ N |
647 |
Limit reflections to a maximum of |
648 |
.I N, |
649 |
if N is a positive integer. |
650 |
If |
651 |
.I N |
652 |
is zero or negative, then Russian roulette is used for ray |
653 |
termination, and the |
654 |
.I -lw |
655 |
setting (below) must be positive. |
656 |
If N is a negative integer, then this limits the maximum |
657 |
number of reflections even with Russian roulette. |
658 |
In scenes with dielectrics and total internal reflection, |
659 |
a setting of 0 (no limit) may cause a stack overflow. |
660 |
.TP |
661 |
.BI -lw \ frac |
662 |
Limit the weight of each ray to a minimum of |
663 |
.I frac. |
664 |
During ray-tracing, a record is kept of the estimated contribution |
665 |
(weight) a ray would have in the image. |
666 |
If this weight is less than the specified minimum and the |
667 |
.I -lr |
668 |
setting (above) is positive, the ray is not traced. |
669 |
Otherwise, Russian roulette is used to |
670 |
continue rays with a probability equal to the ray weight |
671 |
divided by the given |
672 |
.I frac. |
673 |
.TP |
674 |
.BR -ld |
675 |
Boolean switch to limit ray distance. |
676 |
If this option is set, then rays will only be traced as far as the |
677 |
magnitude of each direction vector. |
678 |
Otherwise, vector magnitude is ignored and rays are traced to infinity. |
679 |
.TP |
680 |
.BI -e \ efile |
681 |
Send error messages and progress reports to |
682 |
.I efile |
683 |
instead of the standard error. |
684 |
.TP |
685 |
.BR \-w |
686 |
Boolean switch to suppress warning messages. |
687 |
.TP |
688 |
.BI \-P \ pfile |
689 |
Execute in a persistent mode, using |
690 |
.I pfile |
691 |
as the control file. |
692 |
Persistent execution means that after reaching end-of-file on |
693 |
its input, |
694 |
.I rtrace |
695 |
will fork a child process that will wait for another |
696 |
.I rtrace |
697 |
command with the same |
698 |
.I \-P |
699 |
option to attach to it. |
700 |
(Note that since the rest of the command line options will be those |
701 |
of the original invocation, it is not necessary to give any arguments |
702 |
besides |
703 |
.I \-P |
704 |
for subsequent calls.) |
705 |
Killing the process is achieved with the |
706 |
.I kill(1) |
707 |
command. |
708 |
(The process ID in the first line of |
709 |
.I pfile |
710 |
may be used to identify the waiting |
711 |
.I rtrace |
712 |
process.) |
713 |
This option may be used with the |
714 |
.I \-fr |
715 |
option of |
716 |
.I pinterp(1) |
717 |
to avoid the cost of starting up |
718 |
.I rtrace |
719 |
many times. |
720 |
.TP |
721 |
.BI \-PP \ pfile |
722 |
Execute in continuous-forking persistent mode, using |
723 |
.I pfile |
724 |
725 |
The difference between this option and the |
726 |
.I \-P |
727 |
option described above is the creation of multiple duplicate |
728 |
processes to handle any number of attaches. |
729 |
This provides a simple and reliable mechanism of memory sharing |
730 |
on most multiprocessing platforms, since the |
731 |
.I fork(2) |
732 |
system call will share memory on a copy-on-write basis. |
733 |
.SH NOTES |
734 |
Photons are generally surface bound (an exception are volume photons), thus |
735 |
the ambient irradiance in photon mapping mode will be biased at positions |
736 |
which do not lie on a surface. |
737 |
.SH EXAMPLES |
738 |
To compute radiance values for the rays listed in samples.inp: |
739 |
.IP "" .2i |
740 |
rtrace \-ov scene.oct < samples.inp > radiance.out |
741 |
.PP |
742 |
To compute illuminance values at locations selected with the 't' |
743 |
command of |
744 |
.I ximage(1): |
745 |
.IP "" .2i |
746 |
ximage scene.hdr | rtrace \-h \-x 1 \-i scene.oct | rcalc \-e '$1=47.4*$1+120*$2+11.6*$3' |
747 |
.PP |
748 |
To record the object identifier corresponding to each pixel in an image: |
749 |
.IP "" .2i |
750 |
vwrays \-fd scene.hdr | rtrace \-fda `vwrays \-d scene.hdr` \-os scene.oct |
751 |
.PP |
752 |
To compute an image with an unusual view mapping: |
753 |
.IP "" .2i |
754 |
cnt 480 640 | rcalc \-e 'xr:640;yr:480' \-f unusual_view.cal | rtrace |
755 |
\-x 640 \-y 480 \-fac scene.oct > unusual.hdr |
756 |
.PP |
757 |
To compute ambient illuminance in photon mapping mode from a global photon |
758 |
map global.pm via one ambient bounce, and from a caustic photon map |
759 |
caustic.pm at sensor positions in samples.inp: |
760 |
.IP "" .2i |
761 |
rtrace -h -ov -ab 1 -ap global.pm 50 -ap caustic.pm 50 scene.oct < |
762 |
samples.inp > illum.out |
763 |
.SH ENVIRONMENT |
764 |
RAYPATH the directories to check for auxiliary files. |
765 |
.SH FILES |
766 |
/tmp/rtXXXXXX common header information for picture sequence |
767 |
.SH DIAGNOSTICS |
768 |
If the program terminates from an input related error, the exit status |
769 |
will be 1. |
770 |
A system related error results in an exit status of 2. |
771 |
If the program receives a signal that is caught, it will exit with a status |
772 |
of 3. |
773 |
In each case, an error message will be printed to the standard error, or |
774 |
to the file designated by the |
775 |
.I \-e |
776 |
option. |
777 |
.SH AUTHOR |
778 |
Greg Ward |
779 |
.SH "SEE ALSO" |
780 |
getinfo(1), lookamb(1), mkpmap(1), oconv(1), pfilt(1), pinterp(1), |
781 |
pvalue(1), rcontrib(1), rsplit(1), |
782 |
rpict(1), rtpict(1), rvu(1), vwrays(1), ximage(1) |
