root/radiance/ray/doc/man/man1/rtrace.1
Revision: 1.14
Committed: Sun Feb 5 22:22:20 2006 UTC (19 years, 4 months ago) by greg
Changes since 1.13: +3 -1 lines
Added -V option to rtcontrib and -oV option to rtrace to report contributions
1 .\" RCSid "$Id: rtrace.1,v 1.13 2005/06/14 03:34:14 greg Exp $"
2 .TH RTRACE 1 10/17/97 RADIANCE
3 .SH NAME
4 rtrace - trace rays in RADIANCE scene
5 .SH SYNOPSIS
6 .B rtrace
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 .B octree
17 .br
18 .B "rtrace [ options ] \-defaults"
19 .SH DESCRIPTION
20 .I Rtrace
21 traces rays from the standard input through the RADIANCE scene given by
22 .I octree
23 and sends the results to the standard output.
24 (The octree may be given as the output of a command enclosed in quotes
25 and preceded by a `!'.)\0
26 Input for each ray is:
27
28 xorg yorg zorg xdir ydir zdir
29
30 If the direction vector is (0,0,0), a bogus record
31 is printed and the output is flushed if the
32 .I -x
33 value is unset or zero.
34 (See the notes on this option below.)\0
35 This may be useful for programs that run
36 .I rtrace
37 as a separate process.
38 In the second form, the default values
39 for the options (modified by those options present)
40 are printed with a brief explanation.
41 .PP
42 Options may be given on the command line and/or read from the
43 environment and/or read from a file.
44 A command argument beginning with a dollar sign ('$') is immediately
45 replaced by the contents of the given environment variable.
46 A command argument beginning with an at sign ('@') is immediately
47 replaced by the contents of the given file.
48 Most options are followed by one or more arguments, which must be
49 separated from the option and each other by white space.
50 The exceptions to this rule are the boolean options.
51 Normally, the appearance of a boolean option causes a feature to
52 be "toggled", that is switched from off to on or on to off
53 depending on its previous state.
54 Boolean options may also be set
55 explicitly by following them immediately with a '+' or '-', meaning
56 on or off, respectively.
57 Synonyms for '+' are any of the characters "yYtT1", and synonyms
58 for '-' are any of the characters "nNfF0".
59 All other characters will generate an error.
60 .TP 10n
61 .BI -f io
62 Format input according to the character
63 .I i
64 and output according to the character
65 .I o.
66 .I Rtrace
67 understands the following input and output formats: 'a' for
68 ascii, 'f' for single-precision floating point,
69 and 'd' for double-precision floating point.
70 In addition to these three choices, the character 'c' may be used
71 to denote 4-byte floating point (Radiance) color format
72 for the output of values only
73 .I (\-ov
74 option, below).
75 If the output character is missing, the input format is used.
76 .IP
77 Note that there is no space between this option and its argument.
78 .TP
79 .BI -o spec
80 Produce output fields according to
81 .I spec.
82 Characters are interpreted as follows:
83 .IP
84 o origin (input)
85 .IP
86 d direction (normalized)
87 .IP
88 v value (radiance)
89 .IP
90 V contribution (radiance)
91 .IP
92 w weight
93 .IP
94 W color coefficient
95 .IP
96 l effective length of ray
97 .IP
98 L first intersection distance
99 .IP
100 c local (u,v) coordinates
101 .IP
102 p point of intersection
103 .IP
104 n normal at intersection (perturbed)
105 .IP
106 N normal at intersection (unperturbed)
107 .IP
108 s surface name
109 .IP
110 m modifier name
111 .IP
112 M material name
113 .IP
114 ~ tilde (end of trace marker)
115 .IP
116 If the letter 't' appears in
117 .I spec,
118 then the fields following will be printed for every ray traced,
119 not just the final result.
120 If the capital letter 'T' is given instead of 't', then all rays will
121 be reported, including shadow testing rays to light sources.
122 Spawned rays are indented one tab for each level.
123 The tilde marker ('~') is a handy way of differentiating the final ray
124 value from daughter values in a traced ray tree, and usually appears
125 right before the 't' or 'T' output flags.
126 E.g.,
127 .I \-ov~TmW
128 will emit a tilde followed by a tab at the end of each trace,
129 which can be easily distinguished even in binary output.
130 .IP
131 Note that there is no space between this option and its argument.
132 .TP
133 .BI -te \ mod
134 Append
135 .I mod
136 to the trace exclude list,
137 so that it will not be reported by the trace option
138 .I (\-o*t*).
139 Any ray striking an object having
140 .I mod
141 as its modifier will not be reported to the standard output with
142 the rest of the rays being traced.
143 This option has no effect unless either the 't' or 'T'
144 option has been given as part of the output specifier.
145 Any number of excluded modifiers may be given, but each
146 must appear in a separate option.
147 .TP
148 .BI -ti \ mod
149 Add
150 .I mod
151 to the trace include list,
152 so that it will be reported by the trace option.
153 The program can use either an include list or an exclude
154 list, but not both.
155 .TP
156 .BI -tE \ file
157 Same as
158 .I \-te,
159 except read modifiers to be excluded from
160 .I file.
161 The RAYPATH environment variable determines which directories are
162 searched for this file.
163 The modifier names are separated by white space in the file.
164 .TP
165 .BI -tI \ file
166 Same as
167 .I \-ti,
168 except read modifiers to be included from
169 .I file.
170 .TP
171 .BR \-i
172 Boolean switch to compute irradiance rather than radiance values.
173 This only affects the final result, substituting a Lambertian
174 surface and multiplying the radiance by pi.
175 Glass and other transparent surfaces are ignored during this stage.
176 Light sources still appear with their original radiance values,
177 though the
178 .I \-dv
179 option (below) may be used to override this.
180 This option is especially useful in
181 conjunction with ximage(1) for computing illuminance at scene points.
182 .TP
183 .BR \-u
184 Boolean switch to control uncorrelated random sampling.
185 When "off", a low-discrepancy sequence is used, which reduces
186 variance but can result in a brushed appearance in specular highlights.
187 When "on", pure Monte Carlo sampling is used in all calculations.
188 .TP
189 .BR \-I
190 Boolean switch to compute irradiance rather than radiance,
191 with the input origin and direction interpreted instead
192 as measurement point and orientation.
193 .TP
194 .BR \-h
195 Boolean switch for information header on output.
196 .TP
197 .BI -x \ res
198 Set the x resolution to
199 .I res.
200 The output will be flushed after every
201 .I res
202 input rays.
203 A value of zero means that no output flushing will take place.
204 .TP
205 .BI -y \ res
206 Set the y resolution to
207 .I res.
208 The program will exit after
209 .I res
210 scanlines have been processed, where a scanline is the number of rays
211 given by the
212 .I \-x
213 option, or 1 if
214 .I \-x
215 is zero.
216 A value of zero means the program will not halt until the end
217 of file is reached.
218 .IP
219 If both
220 .I \-x
221 and
222 .I \-y
223 options are given, a resolution string is printed at the beginning
224 of the output.
225 This is mostly useful for recovering image dimensions with
226 .I pvalue(1),
227 and for creating valid Radiance picture files using the color output
228 format.
229 (See the
230 .I \-f
231 option, above.)
232 .TP
233 .BI -dj \ frac
234 Set the direct jittering to
235 .I frac.
236 A value of zero samples each source at specific sample points
237 (see the
238 .I \-ds
239 option below), giving a smoother but somewhat less accurate
240 rendering.
241 A positive value causes rays to be distributed over each
242 source sample according to its size, resulting in more accurate
243 penumbras.
244 This option should never be greater than 1, and may even
245 cause problems (such as speckle) when the value is smaller.
246 A warning about aiming failure will issued if
247 .I frac
248 is too large.
249 .TP
250 .BI -ds \ frac
251 Set the direct sampling ratio to
252 .I frac.
253 A light source will be subdivided until
254 the width of each sample area divided by the distance
255 to the illuminated point is below this ratio.
256 This assures accuracy in regions close to large area sources
257 at a slight computational expense.
258 A value of zero turns source subdivision off, sending at most one
259 shadow ray to each light source.
260 .TP
261 .BI -dt \ frac
262 Set the direct threshold to
263 .I frac.
264 Shadow testing will stop when the potential contribution of at least
265 the next and at most all remaining light sources is less than
266 this fraction of the accumulated value.
267 (See the
268 .I \-dc
269 option below.)
270 The remaining light source contributions are approximated
271 statistically.
272 A value of zero means that all light sources will be tested for shadow.
273 .TP
274 .BI \-dc \ frac
275 Set the direct certainty to
276 .I frac.
277 A value of one guarantees that the absolute accuracy of the direct calculation
278 will be equal to or better than that given in the
279 .I \-dt
280 specification.
281 A value of zero only insures that all shadow lines resulting in a contrast
282 change greater than the
283 .I \-dt
284 specification will be calculated.
285 .TP
286 .BI -dr \ N
287 Set the number of relays for secondary sources to
288 .I N.
289 A value of 0 means that secondary sources will be ignored.
290 A value of 1 means that sources will be made into first generation
291 secondary sources; a value of 2 means that first generation
292 secondary sources will also be made into second generation secondary
293 sources, and so on.
294 .TP
295 .BI -dp \ D
296 Set the secondary source presampling density to D.
297 This is the number of samples per steradian
298 that will be used to determine ahead of time whether or not
299 it is worth following shadow rays through all the reflections and/or
300 transmissions associated with a secondary source path.
301 A value of 0 means that the full secondary source path will always
302 be tested for shadows if it is tested at all.
303 .TP
304 .BR \-dv
305 Boolean switch for light source visibility.
306 With this switch off, sources will be black when viewed directly
307 although they will still participate in the direct calculation.
308 This option is mostly for the program
309 .I mkillum(1)
310 to avoid inappropriate counting of light sources, but it
311 may also be desirable in conjunction with the
312 .I \-i
313 option.
314 .TP
315 .BI -sj \ frac
316 Set the specular sampling jitter to
317 .I frac.
318 This is the degree to which the highlights are sampled
319 for rough specular materials.
320 A value of one means that all highlights will be fully sampled
321 using distributed ray tracing.
322 A value of zero means that no jittering will take place, and all
323 reflections will appear sharp even when they should be diffuse.
324 .TP
325 .BI -st \ frac
326 Set the specular sampling threshold to
327 .I frac.
328 This is the minimum fraction of reflection or transmission, under which
329 no specular sampling is performed.
330 A value of zero means that highlights will always be sampled by
331 tracing reflected or transmitted rays.
332 A value of one means that specular sampling is never used.
333 Highlights from light sources will always be correct, but
334 reflections from other surfaces will be approximated using an
335 ambient value.
336 A sampling threshold between zero and one offers a compromise between image
337 accuracy and rendering time.
338 .TP
339 .BR -bv
340 Boolean switch for back face visibility.
341 With this switch off, back faces of opaque objects will be invisible
342 to all rays.
343 This is dangerous unless the model was constructed such that
344 all surface normals on opaque objects face outward.
345 Although turning off back face visibility does not save much
346 computation time under most circumstances, it may be useful as a
347 tool for scene debugging, or for seeing through one-sided walls from
348 the outside.
349 This option has no effect on transparent or translucent materials.
350 .TP
351 .BI -av " red grn blu"
352 Set the ambient value to a radiance of
353 .I "red grn blu".
354 This is the final value used in place of an
355 indirect light calculation.
356 If the number of ambient bounces is one or greater and the ambient
357 value weight is non-zero (see
358 .I -aw
359 and
360 .I -ab
361 below), this value may be modified by the computed indirect values
362 to improve overall accuracy.
363 .TP
364 .BI -aw \ N
365 Set the relative weight of the ambient value given with the
366 .I -av
367 option to
368 .I N.
369 As new indirect irradiances are computed, they will modify the
370 default ambient value in a moving average, with the specified weight
371 assigned to the initial value given on the command and all other
372 weights set to 1.
373 If a value of 0 is given with this option, then the initial ambient
374 value is never modified.
375 This is the safest value for scenes with large differences in
376 indirect contributions, such as when both indoor and outdoor
377 (daylight) areas are visible.
378 .TP
379 .BI -ab \ N
380 Set the number of ambient bounces to
381 .I N.
382 This is the maximum number of diffuse bounces
383 computed by the indirect calculation.
384 A value of zero implies no indirect calculation.
385 .TP
386 .BI -ar \ res
387 Set the ambient resolution to
388 .I res.
389 This number will determine the maximum density of ambient values
390 used in interpolation.
391 Error will start to increase on surfaces spaced closer than
392 the scene size divided by the ambient resolution.
393 The maximum ambient value density is the scene size times the
394 ambient accuracy (see the
395 .I \-aa
396 option below) divided by the ambient resolution.
397 The scene size can be determined using
398 .I getinfo(1)
399 with the
400 .I \-d
401 option on the input octree.
402 .TP
403 .BI -aa \ acc
404 Set the ambient accuracy to
405 .I acc.
406 This value will approximately equal the error
407 from indirect illuminance interpolation.
408 A value of zero implies no interpolation.
409 .TP
410 .BI -ad \ N
411 Set the number of ambient divisions to
412 .I N.
413 The error in the Monte Carlo calculation of indirect
414 illuminance will be inversely proportional to the square
415 root of this number.
416 A value of zero implies no indirect calculation.
417 .TP
418 .BI -as \ N
419 Set the number of ambient super-samples to
420 .I N.
421 Super-samples are applied only to the ambient divisions which
422 show a significant change.
423 .TP
424 .BI -af \ fname
425 Set the ambient file to
426 .I fname.
427 This is where indirect illuminance will be stored and retrieved.
428 Normally, indirect illuminance values are kept in memory and
429 lost when the program finishes or dies.
430 By using a file, different invocations can share illuminance
431 values, saving time in the computation.
432 The ambient file is in a machine-independent binary format
433 which can be examined with
434 .I lookamb(1).
435 .IP
436 The ambient file may also be used as a means of communication and
437 data sharing between simultaneously executing processes.
438 The same file may be used by multiple processes, possibly running on
439 different machines and accessing the file via the network (ie.
440 .I nfs(4)).
441 The network lock manager
442 .I lockd(8)
443 is used to insure that this information is used consistently.
444 .IP
445 If any calculation parameters are changed or the scene
446 is modified, the old ambient file should be removed so that
447 the calculation can start over from scratch.
448 For convenience, the original ambient parameters are listed in the
449 header of the ambient file.
450 .I Getinfo(1)
451 may be used to print out this information.
452 .TP
453 .BI -ae \ mod
454 Append
455 .I mod
456 to the ambient exclude list,
457 so that it will not be considered during the indirect calculation.
458 This is a hack for speeding the indirect computation by
459 ignoring certain objects.
460 Any object having
461 .I mod
462 as its modifier will get the default ambient
463 level rather than a calculated value.
464 Any number of excluded modifiers may be given, but each
465 must appear in a separate option.
466 .TP
467 .BI -ai \ mod
468 Add
469 .I mod
470 to the ambient include list,
471 so that it will be considered during the indirect calculation.
472 The program can use either an include list or an exclude
473 list, but not both.
474 .TP
475 .BI -aE \ file
476 Same as
477 .I \-ae,
478 except read modifiers to be excluded from
479 .I file.
480 The RAYPATH environment variable determines which directories are
481 searched for this file.
482 The modifier names are separated by white space in the file.
483 .TP
484 .BI -aI \ file
485 Same as
486 .I \-ai,
487 except read modifiers to be included from
488 .I file.
489 .TP
490 .BI -me " rext gext bext"
491 Set the global medium extinction coefficient to the indicated color,
492 in units of 1/distance (distance in world coordinates).
493 Light will be scattered or absorbed over distance according to
494 this value.
495 The ratio of scattering to total scattering plus absorption is set
496 by the albedo parameter, described below.
497 .TP
498 .BI -ma " ralb galb balb"
499 Set the global medium albedo to the given value between 0\00\00
500 and 1\01\01.
501 A zero value means that all light not transmitted by the medium
502 is absorbed.
503 A unitary value means that all light not transmitted by the medium
504 is scattered in some new direction.
505 The isotropy of scattering is determined by the Heyney-Greenstein
506 parameter, described below.
507 .TP
508 .BI \-mg \ gecc
509 Set the medium Heyney-Greenstein eccentricity parameter to
510 .I gecc.
511 This parameter determines how strongly scattering favors the forward
512 direction.
513 A value of 0 indicates perfectly isotropic scattering.
514 As this parameter approaches 1, scattering tends to prefer the
515 forward direction.
516 .TP
517 .BI \-ms \ sampdist
518 Set the medium sampling distance to
519 .I sampdist,
520 in world coordinate units.
521 During source scattering, this will be the average distance between
522 adjacent samples.
523 A value of 0 means that only one sample will be taken per light
524 source within a given scattering volume.
525 .TP
526 .BI -lr \ N
527 Limit reflections to a maximum of
528 .I N.
529 If
530 .I N
531 is zero or negative, then Russian roulette is used for ray
532 termination, and the
533 .I -lw
534 setting (below) must be positive.
535 If N is a negative integer, then this sets the upper limit
536 of reflections past which Russian roulette will not be used.
537 In scenes with dielectrics and total internal reflection,
538 a setting of 0 (no limit) may cause a stack overflow.
539 .TP
540 .BI -lw \ frac
541 Limit the weight of each ray to a minimum of
542 .I frac.
543 During ray-tracing, a record is kept of the estimated contribution
544 (weight) a ray would have in the image.
545 If this weight is less than the specified minimum and the
546 .I -lr
547 setting (above) is positive, the ray is not traced.
548 Otherwise, Russian roulette is used to
549 continue rays with a probability equal to the ray weight
550 divided by the given
551 .I frac.
552 .TP
553 .BR -ld
554 Boolean switch to limit ray distance.
555 If this option is set, then rays will only be traced as far as the
556 magnitude of each direction vector.
557 Otherwise, vector magnitude is ignored and rays are traced to infinity.
558 .TP
559 .BI -e \ efile
560 Send error messages and progress reports to
561 .I efile
562 instead of the standard error.
563 .TP
564 .BR \-w
565 Boolean switch to suppress warning messages.
566 .TP
567 .BI \-P \ pfile
568 Execute in a persistent mode, using
569 .I pfile
570 as the control file.
571 Persistent execution means that after reaching end-of-file on
572 its input,
573 .I rtrace
574 will fork a child process that will wait for another
575 .I rtrace
576 command with the same
577 .I \-P
578 option to attach to it.
579 (Note that since the rest of the command line options will be those
580 of the original invocation, it is not necessary to give any arguments
581 besides
582 .I \-P
583 for subsequent calls.)
584 Killing the process is achieved with the
585 .I kill(1)
586 command.
587 (The process ID in the first line of
588 .I pfile
589 may be used to identify the waiting
590 .I rtrace
591 process.)
592 This option may be used with the
593 .I \-fr
594 option of
595 .I pinterp(1)
596 to avoid the cost of starting up
597 .I rtrace
598 many times.
599 .TP
600 .BI \-PP \ pfile
601 Execute in continuous-forking persistent mode, using
602 .I pfile
603 as the control file.
604 The difference between this option and the
605 .I \-P
606 option described above is the creation of multiple duplicate
607 processes to handle any number of attaches.
608 This provides a simple and reliable mechanism of memory sharing
609 on most multiprocessing platforms, since the
610 .I fork(2)
611 system call will share memory on a copy-on-write basis.
612 .SH EXAMPLES
613 To compute radiance values for the rays listed in samples.inp:
614 .IP "" .2i
615 rtrace -ov scene.oct < samples.inp > radiance.out
616 .PP
617 To compute illuminance values at locations selected with the 't'
618 command of
619 .I ximage(1):
620 .IP "" .2i
621 ximage scene.pic | rtrace -h -x 1 -i scene.oct | rcalc -e '$1=47.4*$1+120*$2+11.6*$3'
622 .PP
623 To record the object identifier corresponding to each pixel in an image:
624 .IP "" .2i
625 vwrays -fd scene.pic | rtrace -fda `vwrays -d scene.pic` -os scene.oct
626 .PP
627 To compute an image with an unusual view mapping:
628 .IP "" .2i
629 cnt 640 480 | rcalc -e 'xr:640;yr:480' -f unusual_view.cal | rtrace
630 -x 640 -y 480 -fac scene.oct > unusual.pic
631 .SH ENVIRONMENT
632 RAYPATH the directories to check for auxiliary files.
633 .SH FILES
634 /tmp/rtXXXXXX common header information for picture sequence
635 .SH DIAGNOSTICS
636 If the program terminates from an input related error, the exit status
637 will be 1.
638 A system related error results in an exit status of 2.
639 If the program receives a signal that is caught, it will exit with a status
640 of 3.
641 In each case, an error message will be printed to the standard error, or
642 to the file designated by the
643 .I \-e
644 option.
645 .SH AUTHOR
646 Greg Ward
647 .SH "SEE ALSO"
648 getinfo(1), lookamb(1), oconv(1), pfilt(1), pinterp(1),
649 pvalue(1), rpict(1), rtcontrib(1), rvu(1), vwrays(1), ximage(1)
