root/radiance/ray/doc/man/man1/rtrace.1
Sat Jan 25 18:27:39 2014 UTC (11 years, 3 months ago) by greg
Changes since 1.24: +4 -5 lines
Diff to previous 1.24 , to selected 1.20
Thu Nov 15 19:41:03 2012 UTC (12 years, 5 months ago) by greg
Changes since 1.23: +2 -2 lines
Diff to previous 1.23 , to selected 1.20
Thu Jun 14 22:42:21 2012 UTC (12 years, 10 months ago) by greg
Diff to previous 1.22 , to selected 1.20
Fri Oct 8 22:08:26 2010 UTC (14 years, 7 months ago) by greg
Changes since 1.21: +8 -8 lines
Diff to previous 1.21 , to selected 1.20
Sun Sep 26 15:49:39 2010 UTC (14 years, 7 months ago) by greg
Changes since 1.20: +7 -2 lines
Diff to previous 1.20
Eliminated flushing with -x >1 if -y also set to improve -n performance
Revision 1.20 - (view) (download) (annotate) - [selected]
Tue Jan 26 04:42:16 2010 UTC (15 years, 3 months ago) by greg
Changes since 1.19: +4 -3 lines
Diff to previous 1.19
Corrected description of -lr option.
Sun Dec 13 19:13:03 2009 UTC (15 years, 4 months ago) by greg
Changes since 1.18: +3 -5 lines
Diff to previous 1.18 , to selected 1.20
Sat Dec 12 19:00:59 2009 UTC (15 years, 4 months ago) by greg
Changes since 1.17: +21 -1 lines
Diff to previous 1.17 , to selected 1.20
Wed Mar 11 02:27:26 2009 UTC (16 years, 1 month ago) by greg
Diff to previous 1.16 , to selected 1.20
Fixed error in example
Mon Nov 10 19:08:17 2008 UTC (16 years, 5 months ago) by greg
Changes since 1.15: +4 -4 lines
Diff to previous 1.15 , to selected 1.20
Tue Sep 4 17:36:41 2007 UTC (17 years, 8 months ago) by greg
Diff to previous 1.14 , to selected 1.20
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Sun Feb 5 22:22:20 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.13: +3 -1 lines
Diff to previous 1.13 , to selected 1.20
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Tue Jun 14 03:34:14 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 1.12 , to selected 1.20
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:55 2005 UTC (19 years, 10 months ago) by greg
Changes since 1.11: +7 -1 lines
Diff to previous 1.11 , to selected 1.20
Tue May 31 18:01:08 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.10: +20 -4 lines
Diff to previous 1.10 , to selected 1.20
Fri May 27 19:15:28 2005 UTC (19 years, 11 months ago) by greg
Diff to previous 1.9 , to selected 1.20
Wording tweaks
Thu May 26 06:55:22 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.8: +9 -9 lines
Diff to previous 1.8 , to selected 1.20
Wed May 25 04:44:24 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.7: +11 -2 lines
Diff to previous 1.7 , to selected 1.20
Tue Apr 19 01:15:06 2005 UTC (20 years ago) by greg
Changes since 1.6: +7 -3 lines
Diff to previous 1.6 , to selected 1.20
Thu Apr 14 18:04:12 2005 UTC (20 years ago) by greg
Changes since 1.5: +21 -19 lines
Diff to previous 1.5 , to selected 1.20
Wed Feb 16 05:40:07 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 1.4 , to selected 1.20
Thu Jan 1 19:31:45 2004 UTC (21 years, 4 months ago) by greg
Diff to previous 1.3 , to selected 1.20
Tue Dec 9 15:59:07 2003 UTC (21 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 1.20
Fixed RCSid specification
Fri Apr 18 17:29:21 2003 UTC (22 years ago) by greg
Diff to previous 1.1 , to selected 1.20
Added rtrace -oc option to output local (u,v) coordinates
Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Diff to selected 1.20
Added documentation to repository
