root/radiance/ray/doc/man/man1/rtrace.1
Tue Sep 4 17:36:41 2007 UTC (17 years, 8 months ago) by greg
Diff to previous 1.14
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Sun Feb 5 22:22:20 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.13: +3 -1 lines
Diff to previous 1.13
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Tue Jun 14 03:34:14 2005 UTC (19 years, 10 months ago) by greg
Diff to previous 1.12
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:55 2005 UTC (19 years, 10 months ago) by greg
Changes since 1.11: +7 -1 lines
Diff to previous 1.11
Tue May 31 18:01:08 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.10: +20 -4 lines
Diff to previous 1.10
Fri May 27 19:15:28 2005 UTC (19 years, 11 months ago) by greg
Diff to previous 1.9
Wording tweaks
Thu May 26 06:55:22 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.8: +9 -9 lines
Diff to previous 1.8
Wed May 25 04:44:24 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.7: +11 -2 lines
Diff to previous 1.7
Tue Apr 19 01:15:06 2005 UTC (20 years ago) by greg
Changes since 1.6: +7 -3 lines
Diff to previous 1.6
Thu Apr 14 18:04:12 2005 UTC (20 years ago) by greg
Changes since 1.5: +21 -19 lines
Diff to previous 1.5
Wed Feb 16 05:40:07 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 1.4
Thu Jan 1 19:31:45 2004 UTC (21 years, 4 months ago) by greg
Diff to previous 1.3
Tue Dec 9 15:59:07 2003 UTC (21 years, 5 months ago) by greg
Diff to previous 1.2
Fixed RCSid specification
Fri Apr 18 17:29:21 2003 UTC (22 years ago) by greg
Added rtrace -oc option to output local (u,v) coordinates
Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
