root/radiance/ray/doc/man/man1/rtrace.1
Revision: 1.10
Committed: Fri May 27 19:15:28 2005 UTC (19 years, 11 months ago) by greg
Wording tweaks
1 .\" RCSid "$Id: rtrace.1,v 1.9 2005/05/26 06:55:22 greg Exp $"
2 .TH RTRACE 1 10/17/97 RADIANCE
3 .SH NAME
4 rtrace - trace rays in RADIANCE scene
5 .SH SYNOPSIS
6 .B rtrace
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 .B octree
17 .br
18 .B "rtrace [ options ] \-defaults"
19 .SH DESCRIPTION
20 .I Rtrace
21 traces rays from the standard input through the RADIANCE scene given by
22 .I octree
23 and sends the results to the standard output.
24 (The octree may be given as the output of a command enclosed in quotes
25 and preceded by a `!'.)\0
26 Input for each ray is:
27
28 xorg yorg zorg xdir ydir zdir
29
30 If the direction vector is (0,0,0), a bogus record
31 is printed and the output is flushed if the
32 .I -x
33 value is unset or zero.
34 (See the notes on this option below.)\0
35 This may be useful for programs that run
36 .I rtrace
37 as a separate process.
38 In the second form, the default values
39 for the options (modified by those options present)
40 are printed with a brief explanation.
41 .PP
42 Options may be given on the command line and/or read from the
43 environment and/or read from a file.
44 A command argument beginning with a dollar sign ('$') is immediately
45 replaced by the contents of the given environment variable.
46 A command argument beginning with an at sign ('@') is immediately
47 replaced by the contents of the given file.
48 Most options are followed by one or more arguments, which must be
49 separated from the option and each other by white space.
50 The exceptions to this rule are the boolean options.
51 Normally, the appearance of a boolean option causes a feature to
52 be "toggled", that is switched from off to on or on to off
53 depending on its previous state.
54 Boolean options may also be set
55 explicitly by following them immediately with a '+' or '-', meaning
56 on or off, respectively.
57 Synonyms for '+' are any of the characters "yYtT1", and synonyms
58 for '-' are any of the characters "nNfF0".
59 All other characters will generate an error.
60 .TP 10n
61 .BI -f io
62 Format input according to the character
63 .I i
64 and output according to the character
65 .I o.
66 .I Rtrace
67 understands the following input and output formats: 'a' for
68 ascii, 'f' for single-precision floating point,
69 and 'd' for double-precision floating point.
70 In addition to these three choices, the character 'c' may be used
71 to denote 4-byte floating point (Radiance) color format
72 for the output of values only
73 .I (\-ov
74 option, below).
75 If the output character is missing, the input format is used.
76 .IP
77 Note that there is no space between this option and its argument.
78 .TP
79 .BI -o spec
80 Produce output fields according to
81 .I spec.
82 Characters are interpreted as follows:
83 .IP
84 o origin (input)
85 .IP
86 d direction (normalized)
87 .IP
88 v value (radiance)
89 .IP
90 w weight
91 .IP
92 W color coefficient
93 .IP
94 l effective length of ray
95 .IP
96 L first intersection distance
97 .IP
98 c local (u,v) coordinates
99 .IP
100 p point of intersection
101 .IP
102 n normal at intersection (perturbed)
103 .IP
104 N normal at intersection (unperturbed)
105 .IP
106 s surface name
107 .IP
108 m modifier name
109 .IP
110 M material name
111 .IP
112 ~ tilde (end of trace marker)
113 .IP
114 If the letter 't' appears in
115 .I spec,
116 then the fields following will be printed for every ray traced,
117 not just the final result.
118 If the capital letter 'T' is given instead of 't', then all rays will
119 be reported, including shadow testing rays to light sources.
120 Spawned rays are indented one tab for each level.
121 The tilde marker ('~') is a handy way of differentiating the final ray
122 value from daughter values in a traced ray tree, and usually appears
123 right before the 't' or 'T' output flags.
124 E.g.,
125 .I \-ov~TmW
126 will emit a tilde followed by a tab at the end of each trace,
127 which can be easily distinguished even in binary output.
128 .IP
129 Note that there is no space between this option and its argument.
130 .TP
131 .BI -te \ mod
132 Append
133 .I mod
134 to the trace exclude list,
135 so that it will not be reported by the trace option
136 .I (\-o*t*).
137 Any ray striking an object having
138 .I mod
139 as its modifier will not be reported to the standard output with
140 the rest of the rays being traced.
141 This option has no effect unless either the 't' or 'T'
142 option has been given as part of the output specifier.
143 Any number of excluded modifiers may be given, but each
144 must appear in a separate option.
145 .TP
146 .BI -ti \ mod
147 Add
148 .I mod
149 to the trace include list,
150 so that it will be reported by the trace option.
151 The program can use either an include list or an exclude
152 list, but not both.
153 .TP
154 .BI -tE \ file
155 Same as
156 .I \-te,
157 except read modifiers to be excluded from
158 .I file.
159 The RAYPATH environment variable determines which directories are
160 searched for this file.
161 The modifier names are separated by white space in the file.
162 .TP
163 .BI -tI \ file
164 Same as
165 .I \-ti,
166 except read modifiers to be included from
167 .I file.
168 .TP
169 .BR \-i
170 Boolean switch to compute irradiance rather than radiance values.
171 This only affects the final result, substituting a Lambertian
172 surface and multiplying the radiance by pi.
173 Glass and other transparent surfaces are ignored during this stage.
174 Light sources still appear with their original radiance values,
175 though the
176 .I \-dv
177 option (below) may be used to override this.
178 This option is especially useful in
179 conjunction with ximage(1) for computing illuminance at scene points.
180 .TP
181 .BR \-I
182 Boolean switch to compute irradiance rather than radiance,
183 with the input origin and direction interpreted instead
184 as measurement point and orientation.
185 .TP
186 .BR \-h
187 Boolean switch for information header on output.
188 .TP
189 .BI -x \ res
190 Set the x resolution to
191 .I res.
192 The output will be flushed after every
193 .I res
194 input rays.
195 A value of zero means that no output flushing will take place.
196 .TP
197 .BI -y \ res
198 Set the y resolution to
199 .I res.
200 The program will exit after
201 .I res
202 scanlines have been processed, where a scanline is the number of rays
203 given by the
204 .I \-x
205 option, or 1 if
206 .I \-x
207 is zero.
208 A value of zero means the program will not halt until the end
209 of file is reached.
210 .IP
211 If both
212 .I \-x
213 and
214 .I \-y
215 options are given, a resolution string is printed at the beginning
216 of the output.
217 This is mostly useful for recovering image dimensions with
218 .I pvalue(1),
219 and for creating valid Radiance picture files using the color output
220 format.
221 (See the
222 .I \-f
223 option, above.)
224 .TP
225 .BI -dj \ frac
226 Set the direct jittering to
227 .I frac.
228 A value of zero samples each source at specific sample points
229 (see the
230 .I \-ds
231 option below), giving a smoother but somewhat less accurate
232 rendering.
233 A positive value causes rays to be distributed over each
234 source sample according to its size, resulting in more accurate
235 penumbras.
236 This option should never be greater than 1, and may even
237 cause problems (such as speckle) when the value is smaller.
238 A warning about aiming failure will issued if
239 .I frac
240 is too large.
241 .TP
242 .BI -ds \ frac
243 Set the direct sampling ratio to
244 .I frac.
245 A light source will be subdivided until
246 the width of each sample area divided by the distance
247 to the illuminated point is below this ratio.
248 This assures accuracy in regions close to large area sources
249 at a slight computational expense.
250 A value of zero turns source subdivision off, sending at most one
251 shadow ray to each light source.
252 .TP
253 .BI -dt \ frac
254 Set the direct threshold to
255 .I frac.
256 Shadow testing will stop when the potential contribution of at least
257 the next and at most all remaining light sources is less than
258 this fraction of the accumulated value.
259 (See the
260 .I \-dc
261 option below.)
262 The remaining light source contributions are approximated
263 statistically.
264 A value of zero means that all light sources will be tested for shadow.
265 .TP
266 .BI \-dc \ frac
267 Set the direct certainty to
268 .I frac.
269 A value of one guarantees that the absolute accuracy of the direct calculation
270 will be equal to or better than that given in the
271 .I \-dt
272 specification.
273 A value of zero only insures that all shadow lines resulting in a contrast
274 change greater than the
275 .I \-dt
276 specification will be calculated.
277 .TP
278 .BI -dr \ N
279 Set the number of relays for secondary sources to
280 .I N.
281 A value of 0 means that secondary sources will be ignored.
282 A value of 1 means that sources will be made into first generation
283 secondary sources; a value of 2 means that first generation
284 secondary sources will also be made into second generation secondary
285 sources, and so on.
286 .TP
287 .BI -dp \ D
288 Set the secondary source presampling density to D.
289 This is the number of samples per steradian
290 that will be used to determine ahead of time whether or not
291 it is worth following shadow rays through all the reflections and/or
292 transmissions associated with a secondary source path.
293 A value of 0 means that the full secondary source path will always
294 be tested for shadows if it is tested at all.
295 .TP
296 .BR \-dv
297 Boolean switch for light source visibility.
298 With this switch off, sources will be black when viewed directly
299 although they will still participate in the direct calculation.
300 This option is mostly for the program
301 .I mkillum(1)
302 to avoid inappropriate counting of light sources, but it
303 may also be desirable in conjunction with the
304 .I \-i
305 option.
306 .TP
307 .BI -sj \ frac
308 Set the specular sampling jitter to
309 .I frac.
310 This is the degree to which the highlights are sampled
311 for rough specular materials.
312 A value of one means that all highlights will be fully sampled
313 using distributed ray tracing.
314 A value of zero means that no jittering will take place, and all
315 reflections will appear sharp even when they should be diffuse.
316 .TP
317 .BI -st \ frac
318 Set the specular sampling threshold to
319 .I frac.
320 This is the minimum fraction of reflection or transmission, under which
321 no specular sampling is performed.
322 A value of zero means that highlights will always be sampled by
323 tracing reflected or transmitted rays.
324 A value of one means that specular sampling is never used.
325 Highlights from light sources will always be correct, but
326 reflections from other surfaces will be approximated using an
327 ambient value.
328 A sampling threshold between zero and one offers a compromise between image
329 accuracy and rendering time.
330 .TP
331 .BR -bv
332 Boolean switch for back face visibility.
333 With this switch off, back faces of opaque objects will be invisible
334 to all rays.
335 This is dangerous unless the model was constructed such that
336 all surface normals on opaque objects face outward.
337 Although turning off back face visibility does not save much
338 computation time under most circumstances, it may be useful as a
339 tool for scene debugging, or for seeing through one-sided walls from
340 the outside.
341 This option has no effect on transparent or translucent materials.
342 .TP
343 .BI -av " red grn blu"
344 Set the ambient value to a radiance of
345 .I "red grn blu".
346 This is the final value used in place of an
347 indirect light calculation.
348 If the number of ambient bounces is one or greater and the ambient
349 value weight is non-zero (see
350 .I -aw
351 and
352 .I -ab
353 below), this value may be modified by the computed indirect values
354 to improve overall accuracy.
355 .TP
356 .BI -aw \ N
357 Set the relative weight of the ambient value given with the
358 .I -av
359 option to
360 .I N.
361 As new indirect irradiances are computed, they will modify the
362 default ambient value in a moving average, with the specified weight
363 assigned to the initial value given on the command and all other
364 weights set to 1.
365 If a value of 0 is given with this option, then the initial ambient
366 value is never modified.
367 This is the safest value for scenes with large differences in
368 indirect contributions, such as when both indoor and outdoor
369 (daylight) areas are visible.
370 .TP
371 .BI -ab \ N
372 Set the number of ambient bounces to
373 .I N.
374 This is the maximum number of diffuse bounces
375 computed by the indirect calculation.
376 A value of zero implies no indirect calculation.
377 .TP
378 .BI -ar \ res
379 Set the ambient resolution to
380 .I res.
381 This number will determine the maximum density of ambient values
382 used in interpolation.
383 Error will start to increase on surfaces spaced closer than
384 the scene size divided by the ambient resolution.
385 The maximum ambient value density is the scene size times the
386 ambient accuracy (see the
387 .I \-aa
388 option below) divided by the ambient resolution.
389 The scene size can be determined using
390 .I getinfo(1)
391 with the
392 .I \-d
393 option on the input octree.
394 .TP
395 .BI -aa \ acc
396 Set the ambient accuracy to
397 .I acc.
398 This value will approximately equal the error
399 from indirect illuminance interpolation.
400 A value of zero implies no interpolation.
401 .TP
402 .BI -ad \ N
403 Set the number of ambient divisions to
404 .I N.
405 The error in the Monte Carlo calculation of indirect
406 illuminance will be inversely proportional to the square
407 root of this number.
408 A value of zero implies no indirect calculation.
409 .TP
410 .BI -as \ N
411 Set the number of ambient super-samples to
412 .I N.
413 Super-samples are applied only to the ambient divisions which
414 show a significant change.
415 .TP
416 .BI -af \ fname
417 Set the ambient file to
418 .I fname.
419 This is where indirect illuminance will be stored and retrieved.
420 Normally, indirect illuminance values are kept in memory and
421 lost when the program finishes or dies.
422 By using a file, different invocations can share illuminance
423 values, saving time in the computation.
424 The ambient file is in a machine-independent binary format
425 which can be examined with
426 .I lookamb(1).
427 .IP
428 The ambient file may also be used as a means of communication and
429 data sharing between simultaneously executing processes.
430 The same file may be used by multiple processes, possibly running on
431 different machines and accessing the file via the network (ie.
432 .I nfs(4)).
433 The network lock manager
434 .I lockd(8)
435 is used to insure that this information is used consistently.
436 .IP
437 If any calculation parameters are changed or the scene
438 is modified, the old ambient file should be removed so that
439 the calculation can start over from scratch.
440 For convenience, the original ambient parameters are listed in the
441 header of the ambient file.
442 .I Getinfo(1)
443 may be used to print out this information.
444 .TP
445 .BI -ae \ mod
446 Append
447 .I mod
448 to the ambient exclude list,
449 so that it will not be considered during the indirect calculation.
450 This is a hack for speeding the indirect computation by
451 ignoring certain objects.
452 Any object having
453 .I mod
454 as its modifier will get the default ambient
455 level rather than a calculated value.
456 Any number of excluded modifiers may be given, but each
457 must appear in a separate option.
458 .TP
459 .BI -ai \ mod
460 Add
461 .I mod
462 to the ambient include list,
463 so that it will be considered during the indirect calculation.
464 The program can use either an include list or an exclude
465 list, but not both.
466 .TP
467 .BI -aE \ file
468 Same as
469 .I \-ae,
470 except read modifiers to be excluded from
471 .I file.
472 The RAYPATH environment variable determines which directories are
473 searched for this file.
474 The modifier names are separated by white space in the file.
475 .TP
476 .BI -aI \ file
477 Same as
478 .I \-ai,
479 except read modifiers to be included from
480 .I file.
481 .TP
482 .BI -me " rext gext bext"
483 Set the global medium extinction coefficient to the indicated color,
484 in units of 1/distance (distance in world coordinates).
485 Light will be scattered or absorbed over distance according to
486 this value.
487 The ratio of scattering to total scattering plus absorption is set
488 by the albedo parameter, described below.
489 .TP
490 .BI -ma " ralb galb balb"
491 Set the global medium albedo to the given value between 0\00\00
492 and 1\01\01.
493 A zero value means that all light not transmitted by the medium
494 is absorbed.
495 A unitary value means that all light not transmitted by the medium
496 is scattered in some new direction.
497 The isotropy of scattering is determined by the Heyney-Greenstein
498 parameter, described below.
499 .TP
500 .BI \-mg \ gecc
501 Set the medium Heyney-Greenstein eccentricity parameter to
502 .I gecc.
503 This parameter determines how strongly scattering favors the forward
504 direction.
505 A value of 0 indicates perfectly isotropic scattering.
506 As this parameter approaches 1, scattering tends to prefer the
507 forward direction.
508 .TP
509 .BI \-ms \ sampdist
510 Set the medium sampling distance to
511 .I sampdist,
512 in world coordinate units.
513 During source scattering, this will be the average distance between
514 adjacent samples.
515 A value of 0 means that only one sample will be taken per light
516 source within a given scattering volume.
517 .TP
518 .BI -lr \ N
519 Limit reflections to a maximum of
520 .I N.
521 .TP
522 .BI -lw \ frac
523 Limit the weight of each ray to a minimum of
524 .I frac.
525 During ray-tracing, a record is kept of the final contribution
526 a ray would have to the image.
527 If it is less then the specified minimum, the ray is not traced.
528 .TP
529 .BR -ld
530 Boolean switch to limit ray distance.
531 If this option is set, then rays will only be traced as far as the
532 magnitude of each direction vector.
533 Otherwise, vector magnitude is ignored and rays are traced to infinity.
534 .TP
535 .BI -e \ efile
536 Send error messages and progress reports to
537 .I efile
538 instead of the standard error.
539 .TP
540 .BR \-w
541 Boolean switch to suppress warning messages.
542 .TP
543 .BI \-P \ pfile
544 Execute in a persistent mode, using
545 .I pfile
546 as the control file.
547 Persistent execution means that after reaching end-of-file on
548 its input,
549 .I rtrace
550 will fork a child process that will wait for another
551 .I rtrace
552 command with the same
553 .I \-P
554 option to attach to it.
555 (Note that since the rest of the command line options will be those
556 of the original invocation, it is not necessary to give any arguments
557 besides
558 .I \-P
559 for subsequent calls.)
560 Killing the process is achieved with the
561 .I kill(1)
562 command.
563 (The process ID in the first line of
564 .I pfile
565 may be used to identify the waiting
566 .I rtrace
567 process.)
568 This option may be used with the
569 .I \-fr
570 option of
571 .I pinterp(1)
572 to avoid the cost of starting up
573 .I rtrace
574 many times.
575 .TP
576 .BI \-PP \ pfile
577 Execute in continuous-forking persistent mode, using
578 .I pfile
579 as the control file.
580 The difference between this option and the
581 .I \-P
582 option described above is the creation of multiple duplicate
583 processes to handle any number of attaches.
584 This provides a simple and reliable mechanism of memory sharing
585 on most multiprocessing platforms, since the
586 .I fork(2)
587 system call will share memory on a copy-on-write basis.
588 .SH EXAMPLES
589 To compute radiance values for the rays listed in samples.inp:
590 .IP "" .2i
591 rtrace -ov scene.oct < samples.inp > radiance.out
592 .PP
593 To compute illuminance values at locations selected with the 't'
594 command of
595 .I ximage(1):
596 .IP "" .2i
597 ximage scene.pic | rtrace -h -x 1 -i scene.oct | rcalc -e '$1=47.4*$1+120*$2+11.6*$3'
598 .PP
599 To record the object identifier corresponding to each pixel in an image:
600 .IP "" .2i
601 vwrays -fd scene.pic | rtrace -fda `vwrays -d scene.pic` -os scene.oct
602 .PP
603 To compute an image with an unusual view mapping:
604 .IP "" .2i
605 cnt 640 480 | rcalc -e 'xr:640;yr:480' -f unusual_view.cal | rtrace
606 -x 640 -y 480 -fac scene.oct > unusual.pic
607 .SH ENVIRONMENT
608 RAYPATH the directories to check for auxiliary files.
609 .SH FILES
610 /tmp/rtXXXXXX common header information for picture sequence
611 .SH DIAGNOSTICS
612 If the program terminates from an input related error, the exit status
613 will be 1.
614 A system related error results in an exit status of 2.
615 If the program receives a signal that is caught, it will exit with a status
616 of 3.
617 In each case, an error message will be printed to the standard error, or
618 to the file designated by the
619 .I \-e
620 option.
621 .SH AUTHOR
622 Greg Ward
623 .SH "SEE ALSO"
624 getinfo(1), lookamb(1), oconv(1), pfilt(1), pinterp(1),
625 pvalue(1), rpict(1), rtcontrib(1), rvu(1), vwrays(1), ximage(1)
