| 1 |
.\" RCSid "$Id"
| 2 |
.TH RTRACE 1 10/17/97 RADIANCE
| 3 |
.SH NAME
| 4 |
rtrace - trace rays in RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rtrace
| 7 |
| 8 |
.B options
| 9 |
| 10 |
| 11 |
.B $EVAR
| 12 |
| 13 |
| 14 |
.B @file
| 15 |
| 16 |
.B octree
| 17 |
.br
| 18 |
.B "rtrace [ options ] \-defaults"
| 19 |
.SH DESCRIPTION
| 20 |
.I Rtrace
| 21 |
traces rays from the standard input through the RADIANCE scene given by
| 22 |
.I octree
| 23 |
and sends the results to the standard output.
| 24 |
(The octree may be given as the output of a command enclosed in quotes
| 25 |
and preceded by a `!'.)\0
| 26 |
Input for each ray is:
| 27 |
| 28 |
xorg yorg zorg xdir ydir zdir
| 29 |
| 30 |
If the direction vector is (0,0,0), a bogus record
| 31 |
is printed and the output is flushed if the
| 32 |
.I -x
| 33 |
value is unset or zero.
| 34 |
(See the notes on this option below.)\0
| 35 |
This may be useful for programs that run
| 36 |
.I rtrace
| 37 |
as a separate process.
| 38 |
In the second form, the default values
| 39 |
for the options (modified by those options present)
| 40 |
are printed with a brief explanation.
| 41 |
.PP
| 42 |
Options may be given on the command line and/or read from the
| 43 |
environment and/or read from a file.
| 44 |
A command argument beginning with a dollar sign ('$') is immediately
| 45 |
replaced by the contents of the given environment variable.
| 46 |
A command argument beginning with an at sign ('@') is immediately
| 47 |
replaced by the contents of the given file.
| 48 |
Most options are followed by one or more arguments, which must be
| 49 |
separated from the option and each other by white space.
| 50 |
The exceptions to this rule are the boolean options.
| 51 |
Normally, the appearance of a boolean option causes a feature to
| 52 |
be "toggled", that is switched from off to on or on to off
| 53 |
depending on its previous state.
| 54 |
Boolean options may also be set
| 55 |
explicitly by following them immediately with a '+' or '-', meaning
| 56 |
on or off, respectively.
| 57 |
Synonyms for '+' are any of the characters "yYtT1", and synonyms
| 58 |
for '-' are any of the characters "nNfF0".
| 59 |
All other characters will generate an error.
| 60 |
.TP 10n
| 61 |
.BI -f io
| 62 |
Format input according to the character
| 63 |
.I i
| 64 |
and output according to the character
| 65 |
.I o.
| 66 |
.I Rtrace
| 67 |
understands the following input and output formats: 'a' for
| 68 |
ascii, 'f' for single-precision floating point,
| 69 |
and 'd' for double-precision floating point.
| 70 |
In addition to these three choices, the character 'c' may be used
| 71 |
to denote 4-byte floating point (Radiance) color format
| 72 |
for the output of values only
| 73 |
.I (\-ov
| 74 |
option, below).
| 75 |
If the output character is missing, the input format is used.
| 76 |
.IP
| 77 |
Note that there is no space between this option and its argument.
| 78 |
.TP
| 79 |
.BI -o spec
| 80 |
Produce output fields according to
| 81 |
.I spec.
| 82 |
Characters are interpreted as follows:
| 83 |
.IP
| 84 |
o origin (input)
| 85 |
.IP
| 86 |
d direction (normalized)
| 87 |
.IP
| 88 |
v value (radiance)
| 89 |
.IP
| 90 |
w weight
| 91 |
.IP
| 92 |
l effective length of ray
| 93 |
.IP
| 94 |
L first intersection distance
| 95 |
.IP
| 96 |
p point of intersection
| 97 |
.IP
| 98 |
n normal at intersection (perturbed)
| 99 |
.IP
| 100 |
N normal at intersection (unperturbed)
| 101 |
.IP
| 102 |
s surface name
| 103 |
.IP
| 104 |
m modifier name
| 105 |
.IP
| 106 |
If the letter 't' appears in
| 107 |
.I spec,
| 108 |
then the fields following will be printed for every ray traced,
| 109 |
not just the final result.
| 110 |
Spawned rays are indented one tab for each level.
| 111 |
.IP
| 112 |
| 113 |
.TP
| 114 |
.BI -te \ mat
| 115 |
Append
| 116 |
.I mat
| 117 |
to the trace exclude list,
| 118 |
so that it will not be reported by the trace option
| 119 |
.I (\-o*t*).
| 120 |
Any ray striking an object having
| 121 |
.I mat
| 122 |
as its modifier will not be reported to the standard output with
| 123 |
the rest of the rays being traced.
| 124 |
This option has no effect unless the 't' option has been given as
| 125 |
part of the output specifier.
| 126 |
Any number of excluded materials may be given, but each
| 127 |
must appear in a separate option.
| 128 |
.TP
| 129 |
.BI -ti \ mat
| 130 |
Add
| 131 |
.I mat
| 132 |
to the trace include list,
| 133 |
so that it will be considered during the indirect calculation.
| 134 |
The program can use either an include list or an exclude
| 135 |
list, but not both.
| 136 |
.TP
| 137 |
.BI -tE \ file
| 138 |
Same as
| 139 |
.I \-te,
| 140 |
except read materials to be excluded from
| 141 |
.I file.
| 142 |
The RAYPATH environment variable determines which directories are
| 143 |
searched for this file.
| 144 |
The material names are separated by white space in the file.
| 145 |
.TP
| 146 |
.BI -tI \ file
| 147 |
Same as
| 148 |
.I \-ti,
| 149 |
except read materials to be included from
| 150 |
.I file.
| 151 |
.TP
| 152 |
.BR \-i
| 153 |
Boolean switch to compute irradiance rather than radiance values.
| 154 |
This only affects the final result, substituting a Lambertian
| 155 |
surface and multiplying the radiance by pi.
| 156 |
Glass and other transparent surfaces are ignored during this stage.
| 157 |
Light sources still appear with their original radiance values,
| 158 |
though the
| 159 |
.I \-dv
| 160 |
option (below) may be used to override this.
| 161 |
This option is especially useful in
| 162 |
conjunction with ximage(1) for computing illuminance at scene points.
| 163 |
.TP
| 164 |
.BR \-I
| 165 |
Boolean switch to compute irradiance rather than radiance,
| 166 |
with the input origin and direction interpreted instead
| 167 |
as measurement point and orientation.
| 168 |
.TP
| 169 |
.BR \-h
| 170 |
Boolean switch for information header on output.
| 171 |
.TP
| 172 |
.BI -x \ res
| 173 |
Set the x resolution to
| 174 |
.I res.
| 175 |
The output will be flushed after every
| 176 |
.I res
| 177 |
input rays.
| 178 |
A value of zero means that no output flushing will take place.
| 179 |
.TP
| 180 |
.BI -y \ res
| 181 |
Set the y resolution to
| 182 |
.I res.
| 183 |
The program will exit after
| 184 |
.I res
| 185 |
scanlines have been processed, where a scanline is the number of rays
| 186 |
given by the
| 187 |
.I \-x
| 188 |
option, or 1 if
| 189 |
.I \-x
| 190 |
is zero.
| 191 |
A value of zero means the program will not halt until the end
| 192 |
of file is reached.
| 193 |
.IP
| 194 |
If both
| 195 |
.I \-x
| 196 |
and
| 197 |
.I \-y
| 198 |
options are given, a resolution string is printed at the beginning
| 199 |
of the output.
| 200 |
This is mostly useful for recovering image dimensions with
| 201 |
.I pvalue(1),
| 202 |
and for creating valid Radiance picture files using the color output
| 203 |
format.
| 204 |
(See the
| 205 |
.I \-f
| 206 |
option, above.)
| 207 |
.TP
| 208 |
.BI -dj \ frac
| 209 |
Set the direct jittering to
| 210 |
.I frac.
| 211 |
A value of zero samples each source at specific sample points
| 212 |
(see the
| 213 |
.I \-ds
| 214 |
option below), giving a smoother but somewhat less accurate
| 215 |
rendering.
| 216 |
A positive value causes rays to be distributed over each
| 217 |
source sample according to its size, resulting in more accurate
| 218 |
penumbras.
| 219 |
This option should never be greater than 1, and may even
| 220 |
cause problems (such as speckle) when the value is smaller.
| 221 |
A warning about aiming failure will issued if
| 222 |
.I frac
| 223 |
is too large.
| 224 |
.TP
| 225 |
.BI -ds \ frac
| 226 |
Set the direct sampling ratio to
| 227 |
.I frac.
| 228 |
A light source will be subdivided until
| 229 |
the width of each sample area divided by the distance
| 230 |
to the illuminated point is below this ratio.
| 231 |
This assures accuracy in regions close to large area sources
| 232 |
at a slight computational expense.
| 233 |
A value of zero turns source subdivision off, sending at most one
| 234 |
shadow ray to each light source.
| 235 |
.TP
| 236 |
.BI -dt \ frac
| 237 |
Set the direct threshold to
| 238 |
.I frac.
| 239 |
Shadow testing will stop when the potential contribution of at least
| 240 |
the next and at most all remaining light sources is less than
| 241 |
this fraction of the accumulated value.
| 242 |
(See the
| 243 |
.I \-dc
| 244 |
option below.)
| 245 |
The remaining light source contributions are approximated
| 246 |
statistically.
| 247 |
A value of zero means that all light sources will be tested for shadow.
| 248 |
.TP
| 249 |
.BI \-dc \ frac
| 250 |
Set the direct certainty to
| 251 |
.I frac.
| 252 |
A value of one guarantees that the absolute accuracy of the direct calculation
| 253 |
will be equal to or better than that given in the
| 254 |
.I \-dt
| 255 |
specification.
| 256 |
A value of zero only insures that all shadow lines resulting in a contrast
| 257 |
change greater than the
| 258 |
.I \-dt
| 259 |
specification will be calculated.
| 260 |
.TP
| 261 |
.BI -dr \ N
| 262 |
Set the number of relays for secondary sources to
| 263 |
.I N.
| 264 |
A value of 0 means that secondary sources will be ignored.
| 265 |
A value of 1 means that sources will be made into first generation
| 266 |
secondary sources; a value of 2 means that first generation
| 267 |
secondary sources will also be made into second generation secondary
| 268 |
sources, and so on.
| 269 |
.TP
| 270 |
.BI -dp \ D
| 271 |
Set the secondary source presampling density to D.
| 272 |
This is the number of samples per steradian
| 273 |
that will be used to determine ahead of time whether or not
| 274 |
it is worth following shadow rays through all the reflections and/or
| 275 |
transmissions associated with a secondary source path.
| 276 |
A value of 0 means that the full secondary source path will always
| 277 |
be tested for shadows if it is tested at all.
| 278 |
.TP
| 279 |
.BR \-dv
| 280 |
Boolean switch for light source visibility.
| 281 |
With this switch off, sources will be black when viewed directly
| 282 |
although they will still participate in the direct calculation.
| 283 |
This option is mostly for the program
| 284 |
.I mkillum(1)
| 285 |
to avoid inappropriate counting of light sources, but it
| 286 |
may also be desirable in conjunction with the
| 287 |
.I \-i
| 288 |
option.
| 289 |
.TP
| 290 |
.BI -sj \ frac
| 291 |
Set the specular sampling jitter to
| 292 |
.I frac.
| 293 |
This is the degree to which the highlights are sampled
| 294 |
for rough specular materials.
| 295 |
A value of one means that all highlights will be fully sampled
| 296 |
using distributed ray tracing.
| 297 |
A value of zero means that no jittering will take place, and all
| 298 |
reflections will appear sharp even when they should be diffuse.
| 299 |
.TP
| 300 |
.BI -st \ frac
| 301 |
Set the specular sampling threshold to
| 302 |
.I frac.
| 303 |
This is the minimum fraction of reflection or transmission, under which
| 304 |
no specular sampling is performed.
| 305 |
A value of zero means that highlights will always be sampled by
| 306 |
tracing reflected or transmitted rays.
| 307 |
A value of one means that specular sampling is never used.
| 308 |
Highlights from light sources will always be correct, but
| 309 |
reflections from other surfaces will be approximated using an
| 310 |
ambient value.
| 311 |
A sampling threshold between zero and one offers a compromise between image
| 312 |
accuracy and rendering time.
| 313 |
.TP
| 314 |
.BR -bv
| 315 |
Boolean switch for back face visibility.
| 316 |
With this switch off, back faces of opaque objects will be invisible
| 317 |
to all rays.
| 318 |
This is dangerous unless the model was constructed such that
| 319 |
all surface normals on opaque objects face outward.
| 320 |
Although turning off back face visibility does not save much
| 321 |
computation time under most circumstances, it may be useful as a
| 322 |
tool for scene debugging, or for seeing through one-sided walls from
| 323 |
the outside.
| 324 |
This option has no effect on transparent or translucent materials.
| 325 |
.TP
| 326 |
.BI -av " red grn blu"
| 327 |
Set the ambient value to a radiance of
| 328 |
.I "red grn blu".
| 329 |
This is the final value used in place of an
| 330 |
indirect light calculation.
| 331 |
If the number of ambient bounces is one or greater and the ambient
| 332 |
value weight is non-zero (see
| 333 |
.I -aw
| 334 |
and
| 335 |
.I -ab
| 336 |
below), this value may be modified by the computed indirect values
| 337 |
to improve overall accuracy.
| 338 |
.TP
| 339 |
.BI -aw \ N
| 340 |
Set the relative weight of the ambient value given with the
| 341 |
.I -av
| 342 |
option to
| 343 |
.I N.
| 344 |
As new indirect irradiances are computed, they will modify the
| 345 |
default ambient value in a moving average, with the specified weight
| 346 |
assigned to the initial value given on the command and all other
| 347 |
weights set to 1.
| 348 |
If a value of 0 is given with this option, then the initial ambient
| 349 |
value is never modified.
| 350 |
This is the safest value for scenes with large differences in
| 351 |
indirect contributions, such as when both indoor and outdoor
| 352 |
(daylight) areas are visible.
| 353 |
.TP
| 354 |
.BI -ab \ N
| 355 |
Set the number of ambient bounces to
| 356 |
.I N.
| 357 |
This is the maximum number of diffuse bounces
| 358 |
computed by the indirect calculation.
| 359 |
A value of zero implies no indirect calculation.
| 360 |
.TP
| 361 |
.BI -ar \ res
| 362 |
Set the ambient resolution to
| 363 |
.I res.
| 364 |
This number will determine the maximum density of ambient values
| 365 |
used in interpolation.
| 366 |
Error will start to increase on surfaces spaced closer than
| 367 |
the scene size divided by the ambient resolution.
| 368 |
The maximum ambient value density is the scene size times the
| 369 |
ambient accuracy (see the
| 370 |
.I \-aa
| 371 |
option below) divided by the ambient resolution.
| 372 |
The scene size can be determined using
| 373 |
.I getinfo(1)
| 374 |
with the
| 375 |
.I \-d
| 376 |
option on the input octree.
| 377 |
.TP
| 378 |
.BI -aa \ acc
| 379 |
Set the ambient accuracy to
| 380 |
.I acc.
| 381 |
This value will approximately equal the error
| 382 |
from indirect illuminance interpolation.
| 383 |
A value of zero implies no interpolation.
| 384 |
.TP
| 385 |
.BI -ad \ N
| 386 |
Set the number of ambient divisions to
| 387 |
.I N.
| 388 |
The error in the Monte Carlo calculation of indirect
| 389 |
illuminance will be inversely proportional to the square
| 390 |
root of this number.
| 391 |
| 392 |
.TP
| 393 |
.BI -as \ N
| 394 |
Set the number of ambient super-samples to
| 395 |
.I N.
| 396 |
Super-samples are applied only to the ambient divisions which
| 397 |
show a significant change.
| 398 |
.TP
| 399 |
.BI -af \ fname
| 400 |
Set the ambient file to
| 401 |
.I fname.
| 402 |
This is where indirect illuminance will be stored and retrieved.
| 403 |
Normally, indirect illuminance values are kept in memory and
| 404 |
lost when the program finishes or dies.
| 405 |
By using a file, different invocations can share illuminance
| 406 |
values, saving time in the computation.
| 407 |
The ambient file is in a machine-independent binary format
| 408 |
which can be examined with
| 409 |
.I lookamb(1).
| 410 |
.IP
| 411 |
The ambient file may also be used as a means of communication and
| 412 |
data sharing between simultaneously executing processes.
| 413 |
The same file may be used by multiple processes, possibly running on
| 414 |
different machines and accessing the file via the network (ie.
| 415 |
.I nfs(4)).
| 416 |
The network lock manager
| 417 |
.I lockd(8)
| 418 |
is used to insure that this information is used consistently.
| 419 |
.IP
| 420 |
If any calculation parameters are changed or the scene
| 421 |
is modified, the old ambient file should be removed so that
| 422 |
the calculation can start over from scratch.
| 423 |
For convenience, the original ambient parameters are listed in the
| 424 |
header of the ambient file.
| 425 |
.I Getinfo(1)
| 426 |
may be used to print out this information.
| 427 |
.TP
| 428 |
.BI -ae \ mat
| 429 |
Append
| 430 |
.I mat
| 431 |
to the ambient exclude list,
| 432 |
so that it will not be considered during the indirect calculation.
| 433 |
This is a hack for speeding the indirect computation by
| 434 |
ignoring certain objects.
| 435 |
Any object having
| 436 |
.I mat
| 437 |
as its modifier will get the default ambient
| 438 |
level rather than a calculated value.
| 439 |
| 440 |
| 441 |
.TP
| 442 |
.BI -ai \ mat
| 443 |
Add
| 444 |
.I mat
| 445 |
to the ambient include list,
| 446 |
| 447 |
| 448 |
list, but not both.
| 449 |
.TP
| 450 |
.BI -aE \ file
| 451 |
Same as
| 452 |
.I \-ae,
| 453 |
| 454 |
.I file.
| 455 |
| 456 |
| 457 |
| 458 |
.TP
| 459 |
.BI -aI \ file
| 460 |
Same as
| 461 |
.I \-ai,
| 462 |
| 463 |
.I file.
| 464 |
.TP
| 465 |
.BI -me " rext gext bext"
| 466 |
Set the global medium extinction coefficient to the indicated color,
| 467 |
in units of 1/distance (distance in world coordinates).
| 468 |
Light will be scattered or absorbed over distance according to
| 469 |
this value.
| 470 |
The ratio of scattering to total scattering plus absorption is set
| 471 |
by the albedo parameter, described below.
| 472 |
.TP
| 473 |
.BI -ma " ralb galb balb"
| 474 |
Set the global medium albedo to the given value between 0\00\00
| 475 |
and 1\01\01.
| 476 |
A zero value means that all light not transmitted by the medium
| 477 |
is absorbed.
| 478 |
A unitary value means that all light not transmitted by the medium
| 479 |
is scattered in some new direction.
| 480 |
The isotropy of scattering is determined by the Heyney-Greenstein
| 481 |
| 482 |
.TP
| 483 |
.BI \-mg \ gecc
| 484 |
Set the medium Heyney-Greenstein eccentricity parameter to
| 485 |
.I gecc.
| 486 |
This parameter determines how strongly scattering favors the forward
| 487 |
direction.
| 488 |
A value of 0 indicates perfectly isotropic scattering.
| 489 |
As this parameter approaches 1, scattering tends to prefer the
| 490 |
forward direction.
| 491 |
.TP
| 492 |
.BI \-ms \ sampdist
| 493 |
Set the medium sampling distance to
| 494 |
.I sampdist,
| 495 |
in world coordinate units.
| 496 |
During source scattering, this will be the average distance between
| 497 |
adjacent samples.
| 498 |
A value of 0 means that only one sample will be taken per light
| 499 |
source within a given scattering volume.
| 500 |
.TP
| 501 |
.BI -lr \ N
| 502 |
Limit reflections to a maximum of
| 503 |
.I N.
| 504 |
.TP
| 505 |
.BI -lw \ frac
| 506 |
Limit the weight of each ray to a minimum of
| 507 |
.I frac.
| 508 |
During ray-tracing, a record is kept of the final contribution
| 509 |
a ray would have to the image.
| 510 |
If it is less then the specified minimum, the ray is not traced.
| 511 |
.TP
| 512 |
.BR -ld
| 513 |
Boolean switch to limit ray distance.
| 514 |
If this option is set, then rays will only be traced as far as the
| 515 |
magnitude of each direction vector.
| 516 |
Otherwise, vector magnitude is ignored and rays are traced to infinity.
| 517 |
.TP
| 518 |
.BI -e \ efile
| 519 |
Send error messages and progress reports to
| 520 |
.I efile
| 521 |
instead of the standard error.
| 522 |
.TP
| 523 |
.BR \-w
| 524 |
Boolean switch to suppress warning messages.
| 525 |
.TP
| 526 |
.BI \-P \ pfile
| 527 |
Execute in a persistent mode, using
| 528 |
.I pfile
| 529 |
as the control file.
| 530 |
Persistent execution means that after reaching end-of-file on
| 531 |
its input,
| 532 |
.I rtrace
| 533 |
will fork a child process that will wait for another
| 534 |
.I rtrace
| 535 |
command with the same
| 536 |
.I \-P
| 537 |
option to attach to it.
| 538 |
(Note that since the rest of the command line options will be those
| 539 |
of the original invocation, it is not necessary to give any arguments
| 540 |
besides
| 541 |
.I \-P
| 542 |
for subsequent calls.)
| 543 |
Killing the process is achieved with the
| 544 |
.I kill(1)
| 545 |
command.
| 546 |
(The process ID in the first line of
| 547 |
.I pfile
| 548 |
may be used to identify the waiting
| 549 |
.I rtrace
| 550 |
process.)
| 551 |
This option may be used with the
| 552 |
.I \-fr
| 553 |
option of
| 554 |
.I pinterp(1)
| 555 |
to avoid the cost of starting up
| 556 |
.I rtrace
| 557 |
many times.
| 558 |
.TP
| 559 |
.BI \-PP \ pfile
| 560 |
Execute in continuous-forking persistent mode, using
| 561 |
.I pfile
| 562 |
| 563 |
The difference between this option and the
| 564 |
.I \-P
| 565 |
option described above is the creation of multiple duplicate
| 566 |
processes to handle any number of attaches.
| 567 |
This provides a simple and reliable mechanism of memory sharing
| 568 |
on most multiprocessing platforms, since the
| 569 |
.I fork(2)
| 570 |
system call will share memory on a copy-on-write basis.
| 571 |
.SH EXAMPLES
| 572 |
To compute radiance values for the rays listed in samples.inp:
| 573 |
.IP "" .2i
| 574 |
rtrace -ov scene.oct < samples.inp > radiance.out
| 575 |
.PP
| 576 |
To compute illuminance values at locations selected with the 't'
| 577 |
command of
| 578 |
.I ximage(1):
| 579 |
.IP "" .2i
| 580 |
ximage scene.pic | rtrace -h -x 1 -i scene.oct | rcalc -e '$1=47.4*$1+120*$2+11.6*$3'
| 581 |
.PP
| 582 |
To record the object identifier corresponding to each pixel in an image:
| 583 |
.IP "" .2i
| 584 |
vwrays -fd scene.pic | rtrace -fda `vwrays -d scene.pic` -os scene.oct
| 585 |
.PP
| 586 |
To compute an image with an unusual view mapping:
| 587 |
.IP "" .2i
| 588 |
cnt 640 480 | rcalc -e 'xr:640;yr:480' -f unusual_view.cal | rtrace
| 589 |
-x 640 -y 480 -fac scene.oct > unusual.pic
| 590 |
.SH ENVIRONMENT
| 591 |
RAYPATH the directories to check for auxiliary files.
| 592 |
.SH FILES
| 593 |
/usr/tmp/rtXXXXXX common header information for picture sequence
| 594 |
.SH DIAGNOSTICS
| 595 |
If the program terminates from an input related error, the exit status
| 596 |
will be 1.
| 597 |
A system related error results in an exit status of 2.
| 598 |
If the program receives a signal that is caught, it will exit with a status
| 599 |
of 3.
| 600 |
In each case, an error message will be printed to the standard error, or
| 601 |
to the file designated by the
| 602 |
.I \-e
| 603 |
option.
| 604 |
.SH AUTHOR
| 605 |
Greg Ward
| 606 |
.SH "SEE ALSO"
| 607 |
getinfo(1), lookamb(1), oconv(1), pfilt(1), pinterp(1),
| 608 |
pvalue(1), rpict(1), rview(1), vwrays(1), ximage(1)
