root/Development/ray/doc/man/man1/rtrace.1
Revision: 1.27
Committed: Fri Jun 5 08:49:01 2015 UTC (10 years, 6 months ago) by rschregle
Changes since 1.26: +21 -11 lines
Revised -am and -ab options, the latter defaulting to 1 in pmap mode
1 .\" RCSid "$Id: rtrace.1,v 1.26 2015/02/24 19:39:26 greg Exp $"
2 .TH RTRACE 1 10/17/97 RADIANCE
3 .SH NAME
4 rtrace - trace rays in RADIANCE scene
5 .SH SYNOPSIS
6 .B rtrace
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 .B octree
17 .br
18 .B "rtrace [ options ] \-defaults"
19 .SH DESCRIPTION
20 .I Rtrace
21 traces rays from the standard input through the RADIANCE scene given by
22 .I octree
23 and sends the results to the standard output.
24 (The octree may be given as the output of a command enclosed in quotes
25 and preceded by a `!'.)\0
26 Input for each ray is:
27
28 xorg yorg zorg xdir ydir zdir
29
30 If the direction vector is (0,0,0), a bogus record
31 is printed and the output is flushed if the
32 .I -x
33 value is one or zero.
34 (See the notes on this option below.)\0
35 This may be useful for programs that run
36 .I rtrace
37 as a separate process.
38 In the second form, the default values
39 for the options (modified by those options present)
40 are printed with a brief explanation.
41 .PP
42 Options may be given on the command line and/or read from the
43 environment and/or read from a file.
44 A command argument beginning with a dollar sign ('$') is immediately
45 replaced by the contents of the given environment variable.
46 A command argument beginning with an at sign ('@') is immediately
47 replaced by the contents of the given file.
48 Most options are followed by one or more arguments, which must be
49 separated from the option and each other by white space.
50 The exceptions to this rule are the boolean options.
51 Normally, the appearance of a boolean option causes a feature to
52 be "toggled", that is switched from off to on or on to off
53 depending on its previous state.
54 Boolean options may also be set
55 explicitly by following them immediately with a '+' or '-', meaning
56 on or off, respectively.
57 Synonyms for '+' are any of the characters "yYtT1", and synonyms
58 for '-' are any of the characters "nNfF0".
59 All other characters will generate an error.
60 .TP 10n
61 .BI -f io
62 Format input according to the character
63 .I i
64 and output according to the character
65 .I o.
66 .I Rtrace
67 understands the following input and output formats: 'a' for
68 ascii, 'f' for single-precision floating point,
69 and 'd' for double-precision floating point.
70 In addition to these three choices, the character 'c' may be used
71 to denote 4-byte floating point (Radiance) color format
72 for the output of values only
73 .I (\-ov
74 option, below).
75 If the output character is missing, the input format is used.
76 .IP
77 Note that there is no space between this option and its argument.
78 .TP
79 .BI -o spec
80 Produce output fields according to
81 .I spec.
82 Characters are interpreted as follows:
83 .IP
84 o origin (input)
85 .IP
86 d direction (normalized)
87 .IP
88 v value (radiance)
89 .IP
90 V contribution (radiance)
91 .IP
92 w weight
93 .IP
94 W color coefficient
95 .IP
96 l effective length of ray
97 .IP
98 L first intersection distance
99 .IP
100 c local (u,v) coordinates
101 .IP
102 p point of intersection
103 .IP
104 n normal at intersection (perturbed)
105 .IP
106 N normal at intersection (unperturbed)
107 .IP
108 s surface name
109 .IP
110 m modifier name
111 .IP
112 M material name
113 .IP
114 ~ tilde (end of trace marker)
115 .IP
116 If the letter 't' appears in
117 .I spec,
118 then the fields following will be printed for every ray traced,
119 not just the final result.
120 If the capital letter 'T' is given instead of 't', then all rays will
121 be reported, including shadow testing rays to light sources.
122 Spawned rays are indented one tab for each level.
123 The tilde marker ('~') is a handy way of differentiating the final ray
124 value from daughter values in a traced ray tree, and usually appears
125 right before the 't' or 'T' output flags.
126 E.g.,
127 .I \-ov~TmW
128 will emit a tilde followed by a tab at the end of each trace,
129 which can be easily distinguished even in binary output.
130 .IP
131 Note that there is no space between this option and its argument.
132 .TP
133 .BI -te \ mod
134 Append
135 .I mod
136 to the trace exclude list,
137 so that it will not be reported by the trace option
138 .I (\-o*t*).
139 Any ray striking an object having
140 .I mod
141 as its modifier will not be reported to the standard output with
142 the rest of the rays being traced.
143 This option has no effect unless either the 't' or 'T'
144 option has been given as part of the output specifier.
145 Any number of excluded modifiers may be given, but each
146 must appear in a separate option.
147 .TP
148 .BI -ti \ mod
149 Add
150 .I mod
151 to the trace include list,
152 so that it will be reported by the trace option.
153 The program can use either an include list or an exclude
154 list, but not both.
155 .TP
156 .BI -tE \ file
157 Same as
158 .I \-te,
159 except read modifiers to be excluded from
160 .I file.
161 The RAYPATH environment variable determines which directories are
162 searched for this file.
163 The modifier names are separated by white space in the file.
164 .TP
165 .BI -tI \ file
166 Same as
167 .I \-ti,
168 except read modifiers to be included from
169 .I file.
170 .TP
171 .BR \-i
172 Boolean switch to compute irradiance rather than radiance values.
173 This only affects the final result, substituting a Lambertian
174 surface and multiplying the radiance by pi.
175 Glass and other transparent surfaces are ignored during this stage.
176 Light sources still appear with their original radiance values,
177 though the
178 .I \-dv
179 option (below) may be used to override this.
180 This option is especially useful in
181 conjunction with ximage(1) for computing illuminance at scene points.
182 .TP
183 .BR \-u
184 Boolean switch to control uncorrelated random sampling.
185 When "off", a low-discrepancy sequence is used, which reduces
186 variance but can result in a brushed appearance in specular highlights.
187 When "on", pure Monte Carlo sampling is used in all calculations.
188 .TP
189 .BR \-I
190 Boolean switch to compute irradiance rather than radiance,
191 with the input origin and direction interpreted instead
192 as measurement point and orientation.
193 .TP
194 .BR \-h
195 Boolean switch for information header on output.
196 .TP
197 .BI -x \ res
198 Set the x resolution to
199 .I res.
200 The output will be flushed after every
201 .I res
202 input rays if
203 .I \-y
204 is set to zero.
205 A value of one means that every ray will be flushed, whatever
206 the setting of
207 .I \-y.
208 A value of zero means that no output flushing will take place.
209 .TP
210 .BI -y \ res
211 Set the y resolution to
212 .I res.
213 The program will exit after
214 .I res
215 scanlines have been processed, where a scanline is the number of rays
216 given by the
217 .I \-x
218 option, or 1 if
219 .I \-x
220 is zero.
221 A value of zero means the program will not halt until the end
222 of file is reached.
223 .IP
224 If both
225 .I \-x
226 and
227 .I \-y
228 options are given, a resolution string is printed at the beginning
229 of the output.
230 This is mostly useful for recovering image dimensions with
231 .I pvalue(1),
232 and for creating valid Radiance picture files using the color output
233 format.
234 (See the
235 .I \-f
236 option, above.)
237 .TP
238 .BI -n \ nproc
239 Execute in parallel on
240 .I nproc
241 local processes.
242 This option is incompatible with the
243 .I \-P
244 and
245 .I \-PP,
246 options.
247 Multiple processes also do not work properly with ray tree output
248 using any of the
249 .I \-o*t*
250 options.
251 There is no benefit from specifying more processes than there are
252 cores available on the system or the
253 .I \-x
254 setting, which forces a wait at each flush.
255 .TP
256 .BI -dj \ frac
257 Set the direct jittering to
258 .I frac.
259 A value of zero samples each source at specific sample points
260 (see the
261 .I \-ds
262 option below), giving a smoother but somewhat less accurate
263 rendering.
264 A positive value causes rays to be distributed over each
265 source sample according to its size, resulting in more accurate
266 penumbras.
267 This option should never be greater than 1, and may even
268 cause problems (such as speckle) when the value is smaller.
269 A warning about aiming failure will issued if
270 .I frac
271 is too large.
272 .TP
273 .BI -ds \ frac
274 Set the direct sampling ratio to
275 .I frac.
276 A light source will be subdivided until
277 the width of each sample area divided by the distance
278 to the illuminated point is below this ratio.
279 This assures accuracy in regions close to large area sources
280 at a slight computational expense.
281 A value of zero turns source subdivision off, sending at most one
282 shadow ray to each light source.
283 .TP
284 .BI -dt \ frac
285 Set the direct threshold to
286 .I frac.
287 Shadow testing will stop when the potential contribution of at least
288 the next and at most all remaining light sources is less than
289 this fraction of the accumulated value.
290 (See the
291 .I \-dc
292 option below.)
293 The remaining light source contributions are approximated
294 statistically.
295 A value of zero means that all light sources will be tested for shadow.
296 .TP
297 .BI \-dc \ frac
298 Set the direct certainty to
299 .I frac.
300 A value of one guarantees that the absolute accuracy of the direct calculation
301 will be equal to or better than that given in the
302 .I \-dt
303 specification.
304 A value of zero only insures that all shadow lines resulting in a contrast
305 change greater than the
306 .I \-dt
307 specification will be calculated.
308 .TP
309 .BI -dr \ N
310 Set the number of relays for secondary sources to
311 .I N.
312 A value of 0 means that secondary sources will be ignored.
313 A value of 1 means that sources will be made into first generation
314 secondary sources; a value of 2 means that first generation
315 secondary sources will also be made into second generation secondary
316 sources, and so on.
317 .TP
318 .BI -dp \ D
319 Set the secondary source presampling density to D.
320 This is the number of samples per steradian
321 that will be used to determine ahead of time whether or not
322 it is worth following shadow rays through all the reflections and/or
323 transmissions associated with a secondary source path.
324 A value of 0 means that the full secondary source path will always
325 be tested for shadows if it is tested at all.
326 .TP
327 .BR \-dv
328 Boolean switch for light source visibility.
329 With this switch off, sources will be black when viewed directly
330 although they will still participate in the direct calculation.
331 This option is mostly for the program
332 .I mkillum(1)
333 to avoid inappropriate counting of light sources, but it
334 may also be desirable in conjunction with the
335 .I \-i
336 option.
337 .TP
338 .BI -ss \ samp
339 Set the specular sampling to
340 .I samp.
341 For values less than 1, this is the degree to which the highlights
342 are sampled for rough specular materials.
343 A value greater than one causes multiple ray samples to be sent
344 to reduce noise at a commmesurate cost.
345 A value of zero means that no jittering will take place, and all
346 reflections will appear sharp even when they should be diffuse.
347 .TP
348 .BI -st \ frac
349 Set the specular sampling threshold to
350 .I frac.
351 This is the minimum fraction of reflection or transmission, under which
352 no specular sampling is performed.
353 A value of zero means that highlights will always be sampled by
354 tracing reflected or transmitted rays.
355 A value of one means that specular sampling is never used.
356 Highlights from light sources will always be correct, but
357 reflections from other surfaces will be approximated using an
358 ambient value.
359 A sampling threshold between zero and one offers a compromise between image
360 accuracy and rendering time.
361 .TP
362 .BR -bv
363 Boolean switch for back face visibility.
364 With this switch off, back faces of all objects will be invisible
365 to view rays.
366 This is dangerous unless the model was constructed such that
367 all surface normals face outward.
368 Although turning off back face visibility does not save much
369 computation time under most circumstances, it may be useful as a
370 tool for scene debugging, or for seeing through one-sided walls from
371 the outside.
372 .TP
373 .BI -av " red grn blu"
374 Set the ambient value to a radiance of
375 .I "red grn blu".
376 This is the final value used in place of an
377 indirect light calculation.
378 If the number of ambient bounces is one or greater and the ambient
379 value weight is non-zero (see
380 .I -aw
381 and
382 .I -ab
383 below), this value may be modified by the computed indirect values
384 to improve overall accuracy.
385 .TP
386 .BI -aw \ N
387 Set the relative weight of the ambient value given with the
388 .I -av
389 option to
390 .I N.
391 As new indirect irradiances are computed, they will modify the
392 default ambient value in a moving average, with the specified weight
393 assigned to the initial value given on the command and all other
394 weights set to 1.
395 If a value of 0 is given with this option, then the initial ambient
396 value is never modified.
397 This is the safest value for scenes with large differences in
398 indirect contributions, such as when both indoor and outdoor
399 (daylight) areas are visible.
400 .TP
401 .BI -ab \ N
402 Set the number of ambient bounces to
403 .I N.
404 This is the maximum number of diffuse bounces computed by the indirect
405 calculation. A value of zero implies no indirect calculation.
406 .IP
407 This value defaults to 1 in photon mapping mode (see
408 .I -ap
409 below), implying that global photon irradiance is always computed via
410 .I one
411 ambient bounce; this behaviour applies to any positive number of ambient
412 bounces, regardless of the actual value specified. A negative value enables
413 a preview mode that directly visualises the irradiance from the global
414 photon map without any ambient bounces.
415 .TP
416 .BI -ar \ res
417 Set the ambient resolution to
418 .I res.
419 This number will determine the maximum density of ambient values
420 used in interpolation.
421 Error will start to increase on surfaces spaced closer than
422 the scene size divided by the ambient resolution.
423 The maximum ambient value density is the scene size times the
424 ambient accuracy (see the
425 .I \-aa
426 option below) divided by the ambient resolution.
427 The scene size can be determined using
428 .I getinfo(1)
429 with the
430 .I \-d
431 option on the input octree.
432 .TP
433 .BI -aa \ acc
434 Set the ambient accuracy to
435 .I acc.
436 This value will approximately equal the error
437 from indirect illuminance interpolation.
438 A value of zero implies no interpolation.
439 .TP
440 .BI -ad \ N
441 Set the number of ambient divisions to
442 .I N.
443 The error in the Monte Carlo calculation of indirect
444 illuminance will be inversely proportional to the square
445 root of this number.
446 A value of zero implies no indirect calculation.
447 .TP
448 .BI -as \ N
449 Set the number of ambient super-samples to
450 .I N.
451 Super-samples are applied only to the ambient divisions which
452 show a significant change.
453 .TP
454 .BI -af \ fname
455 Set the ambient file to
456 .I fname.
457 This is where indirect illuminance will be stored and retrieved.
458 Normally, indirect illuminance values are kept in memory and
459 lost when the program finishes or dies.
460 By using a file, different invocations can share illuminance
461 values, saving time in the computation.
462 The ambient file is in a machine-independent binary format
463 which can be examined with
464 .I lookamb(1).
465 .IP
466 The ambient file may also be used as a means of communication and
467 data sharing between simultaneously executing processes.
468 The same file may be used by multiple processes, possibly running on
469 different machines and accessing the file via the network (ie.
470 .I nfs(4)).
471 The network lock manager
472 .I lockd(8)
473 is used to insure that this information is used consistently.
474 .IP
475 If any calculation parameters are changed or the scene
476 is modified, the old ambient file should be removed so that
477 the calculation can start over from scratch.
478 For convenience, the original ambient parameters are listed in the
479 header of the ambient file.
480 .I Getinfo(1)
481 may be used to print out this information.
482 .TP
483 .BI -ae \ mod
484 Append
485 .I mod
486 to the ambient exclude list,
487 so that it will not be considered during the indirect calculation.
488 This is a hack for speeding the indirect computation by
489 ignoring certain objects.
490 Any object having
491 .I mod
492 as its modifier will get the default ambient
493 level rather than a calculated value.
494 Any number of excluded modifiers may be given, but each
495 must appear in a separate option.
496 .TP
497 .BI -ai \ mod
498 Add
499 .I mod
500 to the ambient include list,
501 so that it will be considered during the indirect calculation.
502 The program can use either an include list or an exclude
503 list, but not both.
504 .TP
505 .BI -aE \ file
506 Same as
507 .I \-ae,
508 except read modifiers to be excluded from
509 .I file.
510 The RAYPATH environment variable determines which directories are
511 searched for this file.
512 The modifier names are separated by white space in the file.
513 .TP
514 .BI -aI \ file
515 Same as
516 .I \-ai,
517 except read modifiers to be included from
518 .I file.
519 .TP
520 .BI -ap " file [bwidth1 [bwidth2]]"
521 Enable photon mapping mode. Loads a photon map generated with
522 .I mkpmap(1)
523 from
524 .I file,
525 and evaluates the indirect irradiance depending on the photon type
526 (automagically detected) using density estimates with a bandwidth of
527 .I bwidth1
528 photons, or the default bandwidth if none is specified (a warning will be
529 issued in this case).
530 .IP
531 Global photon irradiance is evaluated as part of the ambient calculation (see
532 .I \-ab
533 above), caustic photon irradiance is evaluated at primary rays, and
534 indirect inscattering in
535 .I mist
536 is accounted for by volume photons.
537 .IP
538 Additionally specifying
539 .I bwidth2
540 enables bias compensation for the density estimates with a
541 minimum and maximum bandwidth of
542 .I bwidth1
543 and
544 .I bwidth2,
545 respectively.
546 .IP
547 Global photon irradiance may be optionally precomputed by
548 .I mkpmap(1),
549 in which case the bandwidth, if specified, is ignored, as the nearest photon
550 is invariably looked up.
551 .IP
552 Using direct photons replaces the direct calculation with density estimates
553 for debugging and validation of photon emission.
554 .TP
555 .BI -am " frac"
556 Maximum search radius for photon map lookups. Without this option, an
557 initial maximum search radius is estimated for each photon map from the
558 average photon distance to the distribution's centre of gravity. It is then
559 adapted to the photon density in subsequent lookups. This option imposes a
560 global fixed maximum search radius for
561 .I all
562 photon maps, thus defeating the automatic adaptation. It is useful when
563 multiple warnings about short photon lookups are issued. Note that this
564 option does not conflict with the bandwidth specified with the
565 .I \-ap
566 option; the number of photons found will not exceed the latter, but may be
567 lower if the maximum search radius contains fewer photons, thus resulting in
568 short lookups. Setting this radius too large, on the other hand, may
569 degrade performance.
570 .TP
571 .BI -me " rext gext bext"
572 Set the global medium extinction coefficient to the indicated color,
573 in units of 1/distance (distance in world coordinates).
574 Light will be scattered or absorbed over distance according to
575 this value.
576 The ratio of scattering to total scattering plus absorption is set
577 by the albedo parameter, described below.
578 .TP
579 .BI -ma " ralb galb balb"
580 Set the global medium albedo to the given value between 0\00\00
581 and 1\01\01.
582 A zero value means that all light not transmitted by the medium
583 is absorbed.
584 A unitary value means that all light not transmitted by the medium
585 is scattered in some new direction.
586 The isotropy of scattering is determined by the Heyney-Greenstein
587 parameter, described below.
588 .TP
589 .BI \-mg \ gecc
590 Set the medium Heyney-Greenstein eccentricity parameter to
591 .I gecc.
592 This parameter determines how strongly scattering favors the forward
593 direction.
594 A value of 0 indicates perfectly isotropic scattering.
595 As this parameter approaches 1, scattering tends to prefer the
596 forward direction.
597 .TP
598 .BI \-ms \ sampdist
599 Set the medium sampling distance to
600 .I sampdist,
601 in world coordinate units.
602 During source scattering, this will be the average distance between
603 adjacent samples.
604 A value of 0 means that only one sample will be taken per light
605 source within a given scattering volume.
606 .TP
607 .BI -lr \ N
608 Limit reflections to a maximum of
609 .I N,
610 if N is a positive integer.
611 If
612 .I N
613 is zero or negative, then Russian roulette is used for ray
614 termination, and the
615 .I -lw
616 setting (below) must be positive.
617 If N is a negative integer, then this sets the upper limit
618 of reflections past which Russian roulette will be used.
619 In scenes with dielectrics and total internal reflection,
620 a setting of 0 (no limit) may cause a stack overflow.
621 .TP
622 .BI -lw \ frac
623 Limit the weight of each ray to a minimum of
624 .I frac.
625 During ray-tracing, a record is kept of the estimated contribution
626 (weight) a ray would have in the image.
627 If this weight is less than the specified minimum and the
628 .I -lr
629 setting (above) is positive, the ray is not traced.
630 Otherwise, Russian roulette is used to
631 continue rays with a probability equal to the ray weight
632 divided by the given
633 .I frac.
634 .TP
635 .BR -ld
636 Boolean switch to limit ray distance.
637 If this option is set, then rays will only be traced as far as the
638 magnitude of each direction vector.
639 Otherwise, vector magnitude is ignored and rays are traced to infinity.
640 .TP
641 .BI -e \ efile
642 Send error messages and progress reports to
643 .I efile
644 instead of the standard error.
645 .TP
646 .BR \-w
647 Boolean switch to suppress warning messages.
648 .TP
649 .BI \-P \ pfile
650 Execute in a persistent mode, using
651 .I pfile
652 as the control file.
653 Persistent execution means that after reaching end-of-file on
654 its input,
655 .I rtrace
656 will fork a child process that will wait for another
657 .I rtrace
658 command with the same
659 .I \-P
660 option to attach to it.
661 (Note that since the rest of the command line options will be those
662 of the original invocation, it is not necessary to give any arguments
663 besides
664 .I \-P
665 for subsequent calls.)
666 Killing the process is achieved with the
667 .I kill(1)
668 command.
669 (The process ID in the first line of
670 .I pfile
671 may be used to identify the waiting
672 .I rtrace
673 process.)
674 This option may be used with the
675 .I \-fr
676 option of
677 .I pinterp(1)
678 to avoid the cost of starting up
679 .I rtrace
680 many times.
681 .TP
682 .BI \-PP \ pfile
683 Execute in continuous-forking persistent mode, using
684 .I pfile
685 as the control file.
686 The difference between this option and the
687 .I \-P
688 option described above is the creation of multiple duplicate
689 processes to handle any number of attaches.
690 This provides a simple and reliable mechanism of memory sharing
691 on most multiprocessing platforms, since the
692 .I fork(2)
693 system call will share memory on a copy-on-write basis.
694 .SH NOTES
695 Photons are generally surface bound (an exception are volume photons), thus
696 the ambient irradiance in photon mapping mode will be biased at positions
697 which do not lie on a surface.
698 .SH EXAMPLES
699 To compute radiance values for the rays listed in samples.inp:
700 .IP "" .2i
701 rtrace \-ov scene.oct < samples.inp > radiance.out
702 .PP
703 To compute illuminance values at locations selected with the 't'
704 command of
705 .I ximage(1):
706 .IP "" .2i
707 ximage scene.hdr | rtrace \-h \-x 1 \-i scene.oct | rcalc \-e '$1=47.4*$1+120*$2+11.6*$3'
708 .PP
709 To record the object identifier corresponding to each pixel in an image:
710 .IP "" .2i
711 vwrays \-fd scene.hdr | rtrace \-fda `vwrays \-d scene.hdr` \-os scene.oct
712 .PP
713 To compute an image with an unusual view mapping:
714 .IP "" .2i
715 cnt 480 640 | rcalc \-e 'xr:640;yr:480' \-f unusual_view.cal | rtrace
716 \-x 640 \-y 480 \-fac scene.oct > unusual.hdr
717 .PP
718 To compute ambient illuminance in photon mapping mode from a global photon
719 map global.pm via one ambient bounce, and from a caustic photon map
720 caustic.pm at sensor positions in samples.inp:
721 .IP "" .2i
722 rtrace -h -ov -ab 1 -ap global.pm 50 -ap caustic.pm 50 scene.oct <
723 samples.inp > illum.out
724 .SH ENVIRONMENT
725 RAYPATH the directories to check for auxiliary files.
726 .SH FILES
727 /tmp/rtXXXXXX common header information for picture sequence
728 .SH DIAGNOSTICS
729 If the program terminates from an input related error, the exit status
730 will be 1.
731 A system related error results in an exit status of 2.
732 If the program receives a signal that is caught, it will exit with a status
733 of 3.
734 In each case, an error message will be printed to the standard error, or
735 to the file designated by the
736 .I \-e
737 option.
738 .SH AUTHOR
739 Greg Ward
740 .SH "SEE ALSO"
741 getinfo(1), lookamb(1), mkpmap(1), oconv(1), pfilt(1), pinterp(1),
742 pvalue(1), rpict(1), rcontrib(1), rvu(1), vwrays(1), ximage(1)
