1 |
.\" RCSid "$Id: rtrace.1,v 1.38 2023/11/15 19:23:37 greg Exp $" |
2 |
.TH RTRACE 1 10/17/97 RADIANCE |
3 |
.SH NAME |
4 |
rtrace - trace rays in RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B rtrace |
7 |
8 |
.B options |
9 |
10 |
11 |
.B $EVAR |
12 |
13 |
14 |
.B @file |
15 |
16 |
.B octree |
17 |
.br |
18 |
.B "rtrace [ options ] \-defaults" |
19 |
.br |
20 |
.B "rtrace \-features [feat1 ..]" |
21 |
.SH DESCRIPTION |
22 |
.I Rtrace |
23 |
traces rays from the standard input through the RADIANCE scene given by |
24 |
.I octree |
25 |
and sends the results to the standard output. |
26 |
(The octree may be given as the output of a command enclosed in quotes |
27 |
and preceded by a `!'.)\0 |
28 |
Input for each ray is: |
29 |
30 |
xorg yorg zorg xdir ydir zdir |
31 |
32 |
If the direction vector is (0,0,0), a bogus record |
33 |
is printed and the output is flushed if the |
34 |
.I -x |
35 |
value is one or zero. |
36 |
(See the notes on this option below.)\0 |
37 |
This may be useful for programs that run |
38 |
.I rtrace |
39 |
as a separate process. |
40 |
.PP |
41 |
In the second form shown above, the default values |
42 |
for the options (modified by those options present) |
43 |
are printed with a brief explanation. |
44 |
.PP |
45 |
In the third form, a list of supported features is sent |
46 |
to the standard output, one per line. |
47 |
If additional arguments follow, they are checked for presence in |
48 |
this list. |
49 |
If a feature includes subfeatures, these may be checked as well by |
50 |
specifying: |
51 |
.nf |
52 |
53 |
rtrace -features FeatName=subfeat1,subfeat2 |
54 |
55 |
.fi |
56 |
If any named feature or subfeature is missing, an error is |
57 |
reported and the program returns an error status. |
58 |
If all of the named features are present, a zero status is returned. |
59 |
.PP |
60 |
Options may be given on the command line and/or read from the |
61 |
environment and/or read from a file. |
62 |
A command argument beginning with a dollar sign ('$') is immediately |
63 |
replaced by the contents of the given environment variable. |
64 |
A command argument beginning with an at sign ('@') is immediately |
65 |
replaced by the contents of the given file. |
66 |
Most options are followed by one or more arguments, which must be |
67 |
separated from the option and each other by white space. |
68 |
The exceptions to this rule are the boolean options. |
69 |
Normally, the appearance of a boolean option causes a feature to |
70 |
be "toggled", that is switched from off to on or on to off |
71 |
depending on its previous state. |
72 |
Boolean options may also be set |
73 |
explicitly by following them immediately with a '+' or '-', meaning |
74 |
on or off, respectively. |
75 |
Synonyms for '+' are any of the characters "yYtT1", and synonyms |
76 |
for '-' are any of the characters "nNfF0". |
77 |
All other characters will generate an error. |
78 |
.TP 10n |
79 |
.BI -f io |
80 |
Format input according to the character |
81 |
.I i |
82 |
and output according to the character |
83 |
.I o. |
84 |
.I Rtrace |
85 |
understands the following input and output formats: 'a' for |
86 |
ascii, 'f' for single-precision floating point, |
87 |
and 'd' for double-precision floating point. |
88 |
In addition to these three choices, the character 'c' may be used |
89 |
to denote 4-byte RGBE (Radiance) color format |
90 |
for the output of individual color values only, and the |
91 |
.I \-x |
92 |
and |
93 |
.I \-y |
94 |
options should also be specified to create a valid output picture. |
95 |
If the output character is missing, the input format is used. |
96 |
.IP |
97 |
Note that there is no space between this option and its argument. |
98 |
.TP |
99 |
.BI -o spec |
100 |
Produce output fields according to |
101 |
.I spec. |
102 |
Characters are interpreted as follows: |
103 |
.IP |
104 |
o origin (input) |
105 |
.IP |
106 |
d direction (normalized) |
107 |
.IP |
108 |
v value (radiance) |
109 |
.IP |
110 |
V contribution (radiance) |
111 |
.IP |
112 |
w weight |
113 |
.IP |
114 |
W color coefficient |
115 |
.IP |
116 |
l effective length of ray |
117 |
.IP |
118 |
L first intersection distance |
119 |
.IP |
120 |
c local (u,v) coordinates |
121 |
.IP |
122 |
p point of intersection |
123 |
.IP |
124 |
n normal at intersection (perturbed) |
125 |
.IP |
126 |
N normal at intersection (unperturbed) |
127 |
.IP |
128 |
s surface name |
129 |
.IP |
130 |
m modifier name |
131 |
.IP |
132 |
M material name |
133 |
.IP |
134 |
r mirrored value contribution |
135 |
.IP |
136 |
x unmirrored value contribution |
137 |
.IP |
138 |
R mirrored ray length |
139 |
.IP |
140 |
X unmirrored ray length |
141 |
.IP |
142 |
~ tilde (end of trace marker) |
143 |
.IP |
144 |
If the letter 't' appears in |
145 |
.I spec, |
146 |
then the fields following will be printed for every ray traced, |
147 |
not just the final result. |
148 |
If the capital letter 'T' is given instead of 't', then all rays will |
149 |
be reported, including shadow testing rays to light sources. |
150 |
Spawned rays are indented one tab for each level. |
151 |
The tilde marker ('~') is a handy way of differentiating the final ray |
152 |
value from daughter values in a traced ray tree, and usually appears |
153 |
right before the 't' or 'T' output flags. |
154 |
E.g., |
155 |
.I \-ov~TmW |
156 |
will emit a tilde followed by a tab at the end of each trace, |
157 |
which can be easily distinguished even in binary output. |
158 |
.IP |
159 |
160 |
.TP |
161 |
.BI -te \ mod |
162 |
Append |
163 |
.I mod |
164 |
to the trace exclude list, |
165 |
so that it will not be reported by the trace option |
166 |
.I (\-o*t*). |
167 |
Any ray striking an object having |
168 |
.I mod |
169 |
as its modifier will not be reported to the standard output with |
170 |
the rest of the rays being traced. |
171 |
This option has no effect unless either the 't' or 'T' |
172 |
option has been given as part of the output specifier. |
173 |
Any number of excluded modifiers may be given, but each |
174 |
must appear in a separate option. |
175 |
.TP |
176 |
.BI -ti \ mod |
177 |
Add |
178 |
.I mod |
179 |
to the trace include list, |
180 |
so that it will be reported by the trace option. |
181 |
The program can use either an include list or an exclude |
182 |
list, but not both. |
183 |
.TP |
184 |
.BI -tE \ file |
185 |
Same as |
186 |
.I \-te, |
187 |
except read modifiers to be excluded from |
188 |
.I file. |
189 |
The RAYPATH environment variable determines which directories are |
190 |
searched for this file. |
191 |
The modifier names are separated by white space in the file. |
192 |
.TP |
193 |
.BI -tI \ file |
194 |
Same as |
195 |
.I \-ti, |
196 |
except read modifiers to be included from |
197 |
.I file. |
198 |
.TP |
199 |
.BR \-i |
200 |
Boolean switch to compute irradiance rather than radiance values. |
201 |
This only affects the final result, substituting a Lambertian |
202 |
surface and multiplying the radiance by pi. |
203 |
Glass and other transparent surfaces are ignored during this stage. |
204 |
Light sources still appear with their original radiance values, |
205 |
though the |
206 |
.I \-dv |
207 |
option (below) may be used to override this. |
208 |
This option is especially useful in |
209 |
conjunction with ximage(1) for computing irradiance at scene points. |
210 |
.TP |
211 |
.BR \-u |
212 |
Boolean switch to control uncorrelated random sampling. |
213 |
When "off", a low-discrepancy sequence is used, which reduces |
214 |
variance but can result in a brushed appearance in specular highlights. |
215 |
When "on", pure Monte Carlo sampling is used in all calculations. |
216 |
.TP |
217 |
.BR \-I |
218 |
Boolean switch to compute irradiance rather than radiance, |
219 |
with the input origin and direction interpreted instead |
220 |
as measurement point and orientation. |
221 |
.TP |
222 |
.BR \-h |
223 |
Boolean switch for information header on output. |
224 |
.TP |
225 |
.BI -x \ res |
226 |
Set the x resolution to |
227 |
.I res. |
228 |
The output will be flushed after every |
229 |
.I res |
230 |
input rays if |
231 |
.I \-y |
232 |
is set to zero. |
233 |
A value of one means that every ray will be flushed, whatever |
234 |
the setting of |
235 |
.I \-y. |
236 |
A value of zero means that no output flushing will take place. |
237 |
.TP |
238 |
.BI -y \ res |
239 |
Set the y resolution to |
240 |
.I res. |
241 |
The program will exit after |
242 |
.I res |
243 |
scanlines have been processed, where a scanline is the number of rays |
244 |
given by the |
245 |
.I \-x |
246 |
option, or 1 if |
247 |
.I \-x |
248 |
is zero. |
249 |
A value of zero means the program will not halt until the end |
250 |
of file is reached. |
251 |
.IP |
252 |
If both |
253 |
.I \-x |
254 |
and |
255 |
.I \-y |
256 |
options are given, a resolution string is printed at the beginning |
257 |
of the output. |
258 |
This is mostly useful for recovering image dimensions with |
259 |
.I pvalue(1), |
260 |
and for creating valid Radiance picture files using the color output |
261 |
format. |
262 |
(See the |
263 |
.I \-f |
264 |
option, above.) |
265 |
.TP |
266 |
.BI -n \ nproc |
267 |
Execute in parallel on |
268 |
.I nproc |
269 |
local processes. |
270 |
This option is incompatible with the |
271 |
.I \-P |
272 |
and |
273 |
.I \-PP, |
274 |
options. |
275 |
Multiple processes also do not work properly with ray tree output |
276 |
using any of the |
277 |
.I \-o*t* |
278 |
options. |
279 |
There is no benefit from specifying more processes than there are |
280 |
cores available on the system or the |
281 |
.I \-x |
282 |
setting, which forces a wait at each flush. |
283 |
.TP |
284 |
.BI -dj \ frac |
285 |
Set the direct jittering to |
286 |
.I frac. |
287 |
A value of zero samples each source at specific sample points |
288 |
(see the |
289 |
.I \-ds |
290 |
option below), giving a smoother but somewhat less accurate |
291 |
rendering. |
292 |
A positive value causes rays to be distributed over each |
293 |
source sample according to its size, resulting in more accurate |
294 |
penumbras. |
295 |
This option should never be greater than 1, and may even |
296 |
cause problems (such as speckle) when the value is smaller. |
297 |
A warning about aiming failure will issued if |
298 |
.I frac |
299 |
is too large. |
300 |
.TP |
301 |
.BI -ds \ frac |
302 |
Set the direct sampling ratio to |
303 |
.I frac. |
304 |
A light source will be subdivided until |
305 |
the width of each sample area divided by the distance |
306 |
to the illuminated point is below this ratio. |
307 |
This assures accuracy in regions close to large area sources |
308 |
at a slight computational expense. |
309 |
A value of zero turns source subdivision off, sending at most one |
310 |
shadow ray to each light source. |
311 |
.TP |
312 |
.BI -dt \ frac |
313 |
Set the direct threshold to |
314 |
.I frac. |
315 |
Shadow testing will stop when the potential contribution of at least |
316 |
the next and at most all remaining light sources is less than |
317 |
this fraction of the accumulated value. |
318 |
(See the |
319 |
.I \-dc |
320 |
option below.) |
321 |
The remaining light source contributions are approximated |
322 |
statistically. |
323 |
A value of zero means that all light sources will be tested for shadow. |
324 |
.TP |
325 |
.BI \-dc \ frac |
326 |
Set the direct certainty to |
327 |
.I frac. |
328 |
A value of one guarantees that the absolute accuracy of the direct calculation |
329 |
will be equal to or better than that given in the |
330 |
.I \-dt |
331 |
specification. |
332 |
A value of zero only insures that all shadow lines resulting in a contrast |
333 |
change greater than the |
334 |
.I \-dt |
335 |
specification will be calculated. |
336 |
.TP |
337 |
.BI -dr \ N |
338 |
Set the number of relays for virtual sources to |
339 |
.I N. |
340 |
A value of 0 means that virtual sources will be ignored. |
341 |
A value of 1 means that sources will be made into first generation |
342 |
virtual sources; a value of 2 means that first generation |
343 |
virtual sources will also be made into second generation virtual |
344 |
sources, and so on. |
345 |
.TP |
346 |
.BI -dp \ D |
347 |
Set the virtual source presampling density to D. |
348 |
This is the number of samples per steradian |
349 |
that will be used to determine ahead of time whether or not |
350 |
it is worth following shadow rays through all the reflections and/or |
351 |
transmissions associated with a virtual source path. |
352 |
A value of 0 means that the full virtual source path will always |
353 |
be tested for shadows if it is tested at all. |
354 |
.TP |
355 |
.BR \-dv |
356 |
Boolean switch for light source visibility. |
357 |
With this switch off, sources will be black when viewed directly |
358 |
although they will still participate in the direct calculation. |
359 |
This option is mostly for the program |
360 |
.I mkillum(1) |
361 |
to avoid inappropriate counting of light sources, but it |
362 |
may also be desirable in conjunction with the |
363 |
.I \-i |
364 |
option. |
365 |
.TP |
366 |
.BI -ss \ samp |
367 |
Set the specular sampling to |
368 |
.I samp. |
369 |
For values less than 1, this is the degree to which the highlights |
370 |
are sampled for rough specular materials. |
371 |
A value greater than one causes multiple ray samples to be sent |
372 |
to reduce noise at a commmesurate cost. |
373 |
A value of zero means that no jittering will take place, and all |
374 |
reflections will appear sharp even when they should be diffuse. |
375 |
.TP |
376 |
.BI -st \ frac |
377 |
Set the specular sampling threshold to |
378 |
.I frac. |
379 |
This is the minimum fraction of reflection or transmission, under which |
380 |
no specular sampling is performed. |
381 |
A value of zero means that highlights will always be sampled by |
382 |
tracing reflected or transmitted rays. |
383 |
A value of one means that specular sampling is never used. |
384 |
Highlights from light sources will always be correct, but |
385 |
reflections from other surfaces will be approximated using an |
386 |
ambient value. |
387 |
A sampling threshold between zero and one offers a compromise between image |
388 |
accuracy and rendering time. |
389 |
.TP |
390 |
.BR -bv |
391 |
Boolean switch for back face visibility. |
392 |
With this switch off, back faces of all objects will be invisible |
393 |
to view rays. |
394 |
This is dangerous unless the model was constructed such that |
395 |
all surface normals face outward. |
396 |
Although turning off back face visibility does not save much |
397 |
computation time under most circumstances, it may be useful as a |
398 |
tool for scene debugging, or for seeing through one-sided walls from |
399 |
the outside. |
400 |
.TP |
401 |
.BI -av " red grn blu" |
402 |
Set the ambient value to a radiance of |
403 |
.I "red grn blu". |
404 |
This is the final value used in place of an |
405 |
indirect light calculation. |
406 |
If the number of ambient bounces is one or greater and the ambient |
407 |
value weight is non-zero (see |
408 |
.I -aw |
409 |
and |
410 |
.I -ab |
411 |
below), this value may be modified by the computed indirect values |
412 |
to improve overall accuracy. |
413 |
.TP |
414 |
.BI -aw \ N |
415 |
Set the relative weight of the ambient value given with the |
416 |
.I -av |
417 |
option to |
418 |
.I N. |
419 |
As new indirect irradiances are computed, they will modify the |
420 |
default ambient value in a moving average, with the specified weight |
421 |
assigned to the initial value given on the command and all other |
422 |
weights set to 1. |
423 |
If a value of 0 is given with this option, then the initial ambient |
424 |
value is never modified. |
425 |
This is the safest value for scenes with large differences in |
426 |
indirect contributions, such as when both indoor and outdoor |
427 |
(daylight) areas are visible. |
428 |
.TP |
429 |
.BI -ab \ N |
430 |
Set the number of ambient bounces to |
431 |
.I N. |
432 |
This is the maximum number of diffuse bounces computed by the indirect |
433 |
calculation. A value of zero implies no indirect calculation. |
434 |
.IP |
435 |
This value defaults to 1 in photon mapping mode (see |
436 |
.I -ap |
437 |
below), implying that global photon irradiance is always computed via |
438 |
.I one |
439 |
ambient bounce; this behaviour applies to any positive number of ambient |
440 |
bounces, regardless of the actual value specified. A negative value enables |
441 |
a preview mode that directly visualises the irradiance from the global |
442 |
photon map without any ambient bounces. |
443 |
.TP |
444 |
.BI -ar \ res |
445 |
Set the ambient resolution to |
446 |
.I res. |
447 |
This number will determine the maximum density of ambient values |
448 |
used in interpolation. |
449 |
Error will start to increase on surfaces spaced closer than |
450 |
the scene size divided by the ambient resolution. |
451 |
The maximum ambient value density is the scene size times the |
452 |
ambient accuracy (see the |
453 |
.I \-aa |
454 |
option below) divided by the ambient resolution. |
455 |
The scene size can be determined using |
456 |
.I getinfo(1) |
457 |
with the |
458 |
.I \-d |
459 |
option on the input octree. |
460 |
.TP |
461 |
.BI -aa \ acc |
462 |
Set the ambient accuracy to |
463 |
.I acc. |
464 |
This value will approximately equal the error |
465 |
from indirect irradiance interpolation. |
466 |
A value of zero implies no interpolation. |
467 |
.TP |
468 |
.BI -ad \ N |
469 |
Set the number of ambient divisions to |
470 |
.I N. |
471 |
The error in the Monte Carlo calculation of indirect |
472 |
irradiance will be inversely proportional to the square |
473 |
root of this number. |
474 |
475 |
.TP |
476 |
.BI -as \ N |
477 |
Set the number of ambient super-samples to |
478 |
.I N. |
479 |
Super-samples are applied only to the ambient divisions which |
480 |
show a significant change. |
481 |
.TP |
482 |
.BI -af \ fname |
483 |
Set the ambient file to |
484 |
.I fname. |
485 |
This is where indirect irradiance will be stored and retrieved. |
486 |
Normally, indirect irradiance values are kept in memory and |
487 |
lost when the program finishes or dies. |
488 |
By using a file, different invocations can share irradiance |
489 |
values, saving time in the computation. |
490 |
The ambient file is in a machine-independent binary format |
491 |
which can be examined with |
492 |
.I lookamb(1). |
493 |
.IP |
494 |
The ambient file may also be used as a means of communication and |
495 |
data sharing between simultaneously executing processes. |
496 |
The same file may be used by multiple processes, possibly running on |
497 |
different machines and accessing the file via the network (ie. |
498 |
.I nfs(4)). |
499 |
The network lock manager |
500 |
.I lockd(8) |
501 |
is used to insure that this information is used consistently. |
502 |
.IP |
503 |
If any calculation parameters are changed or the scene |
504 |
is modified, the old ambient file should be removed so that |
505 |
the calculation can start over from scratch. |
506 |
For convenience, the original ambient parameters are listed in the |
507 |
header of the ambient file. |
508 |
.I Getinfo(1) |
509 |
may be used to print out this information. |
510 |
.TP |
511 |
.BI -ae \ mod |
512 |
Append |
513 |
.I mod |
514 |
to the ambient exclude list, |
515 |
so that it will not be considered during the indirect calculation. |
516 |
This is a hack for speeding the indirect computation by |
517 |
ignoring certain objects. |
518 |
Any object having |
519 |
.I mod |
520 |
as its modifier will get the default ambient |
521 |
level rather than a calculated value. |
522 |
523 |
524 |
.TP |
525 |
.BI -ai \ mod |
526 |
Add |
527 |
.I mod |
528 |
to the ambient include list, |
529 |
so that it will be considered during the indirect calculation. |
530 |
531 |
532 |
.TP |
533 |
.BI -aE \ file |
534 |
Same as |
535 |
.I \-ae, |
536 |
537 |
.I file. |
538 |
539 |
540 |
541 |
.TP |
542 |
.BI -aI \ file |
543 |
Same as |
544 |
.I \-ai, |
545 |
546 |
.I file. |
547 |
.TP |
548 |
.BI -ap " file [bwidth1 [bwidth2]]" |
549 |
Enable photon mapping mode. Loads a photon map generated with |
550 |
.I mkpmap(1) |
551 |
from |
552 |
.I file, |
553 |
and evaluates the indirect irradiance depending on the photon type |
554 |
(automagically detected) using density estimates with a bandwidth of |
555 |
.I bwidth1 |
556 |
photons, or the default bandwidth if none is specified (a warning will be |
557 |
issued in this case). |
558 |
.IP |
559 |
Global photon irradiance is evaluated as part of the ambient calculation (see |
560 |
.I \-ab |
561 |
above), caustic photon irradiance is evaluated at primary rays, and |
562 |
indirect inscattering in |
563 |
.I mist |
564 |
is accounted for by volume photons. Contribution photons are treated as |
565 |
global photons by |
566 |
.I rtrace. |
567 |
.IP |
568 |
Additionally specifying |
569 |
.I bwidth2 |
570 |
enables bias compensation for the density estimates with a |
571 |
minimum and maximum bandwidth of |
572 |
.I bwidth1 |
573 |
and |
574 |
.I bwidth2, |
575 |
respectively. |
576 |
.IP |
577 |
Global photon irradiance may be optionally precomputed by |
578 |
.I mkpmap(1), |
579 |
in which case the bandwidth, if specified, is ignored, as the nearest photon |
580 |
is invariably looked up. |
581 |
.IP |
582 |
Using direct photons replaces the direct calculation with density estimates |
583 |
for debugging and validation of photon emission. |
584 |
.TP |
585 |
.BI -am " frac" |
586 |
Maximum search radius for photon map lookups. Without this option, an |
587 |
initial maximum search radius is estimated for each photon map from the |
588 |
average photon distance to the distribution's centre of gravity. It is then |
589 |
adapted to the photon density in subsequent lookups. This option imposes a |
590 |
global fixed maximum search radius for |
591 |
.I all |
592 |
photon maps, thus defeating the automatic adaptation. It is useful when |
593 |
multiple warnings about short photon lookups are issued. Note that this |
594 |
option does not conflict with the bandwidth specified with the |
595 |
.I \-ap |
596 |
option; the number of photons found will not exceed the latter, but may be |
597 |
lower if the maximum search radius contains fewer photons, thus resulting in |
598 |
short lookups. Setting this radius too large, on the other hand, may |
599 |
degrade performance. |
600 |
.TP |
601 |
.BI -ac " pagesize" |
602 |
Set the photon cache page size when using out-of-core photon mapping. The |
603 |
photon cache reduces disk I/O incurred by on-demand loading (paging) of |
604 |
photons, and thus increases performance. This |
605 |
is expressed as a (float) multiple of the density estimate bandwidth |
606 |
specified with |
607 |
.I \-ap |
608 |
under the assumption that photon lookups are local to a cache page. Cache |
609 |
performance is sensitive to this parameter: larger pagesizes will reduce the |
610 |
paging frequency at the expense of higher latency when paging does occur. |
611 |
Sensible values are in the range 4 (default) to 16. |
612 |
.TP |
613 |
.BI -aC " cachesize" |
614 |
Set the total number of photons cached when using out-of-core photon |
615 |
mapping, taking into account the pagesize specified by |
616 |
.I \-ac. |
617 |
Note that this is approximate as the number of cache pages is rounded to |
618 |
the nearest prime. This allows adapting the cache to the available physical |
619 |
memory. In conjunction with the |
620 |
.I \-n |
621 |
option, this is the cache size |
622 |
.I per parallel process. |
623 |
Cache performance is less sensitive to this parameter, |
624 |
and reasonable performance can obtained with as few as 10k photons. The |
625 |
default is 1M. This option recognises multiplier suffixes (k = 1e3, M = |
626 |
1e6), both in upper and lower case. |
627 |
.TP |
628 |
.BI -me " rext gext bext" |
629 |
Set the global medium extinction coefficient to the indicated color, |
630 |
in units of 1/distance (distance in world coordinates). |
631 |
Light will be scattered or absorbed over distance according to |
632 |
this value. |
633 |
The ratio of scattering to total scattering plus absorption is set |
634 |
by the albedo parameter, described below. |
635 |
.TP |
636 |
.BI -ma " ralb galb balb" |
637 |
Set the global medium albedo to the given value between 0\00\00 |
638 |
and 1\01\01. |
639 |
A zero value means that all light not transmitted by the medium |
640 |
is absorbed. |
641 |
A unitary value means that all light not transmitted by the medium |
642 |
is scattered in some new direction. |
643 |
The isotropy of scattering is determined by the Heyney-Greenstein |
644 |
645 |
.TP |
646 |
.BI \-mg \ gecc |
647 |
Set the medium Heyney-Greenstein eccentricity parameter to |
648 |
.I gecc. |
649 |
This parameter determines how strongly scattering favors the forward |
650 |
direction. |
651 |
A value of 0 indicates perfectly isotropic scattering. |
652 |
As this parameter approaches 1, scattering tends to prefer the |
653 |
forward direction. |
654 |
.TP |
655 |
.BI \-ms \ sampdist |
656 |
Set the medium sampling distance to |
657 |
.I sampdist, |
658 |
in world coordinate units. |
659 |
During source scattering, this will be the average distance between |
660 |
adjacent samples. |
661 |
A value of 0 means that only one sample will be taken per light |
662 |
source within a given scattering volume. |
663 |
.TP |
664 |
.BI -lr \ N |
665 |
Limit reflections to a maximum of |
666 |
.I N, |
667 |
if N is a positive integer. |
668 |
If |
669 |
.I N |
670 |
is zero or negative, then Russian roulette is used for ray |
671 |
termination, and the |
672 |
.I -lw |
673 |
setting (below) must be positive. |
674 |
If N is a negative integer, then this limits the maximum |
675 |
number of reflections even with Russian roulette. |
676 |
In scenes with dielectrics and total internal reflection, |
677 |
a setting of 0 (no limit) may cause a stack overflow. |
678 |
.TP |
679 |
.BI -lw \ frac |
680 |
Limit the weight of each ray to a minimum of |
681 |
.I frac. |
682 |
During ray-tracing, a record is kept of the estimated contribution |
683 |
(weight) a ray would have in the image. |
684 |
If this weight is less than the specified minimum and the |
685 |
.I -lr |
686 |
setting (above) is positive, the ray is not traced. |
687 |
Otherwise, Russian roulette is used to |
688 |
continue rays with a probability equal to the ray weight |
689 |
divided by the given |
690 |
.I frac. |
691 |
.TP |
692 |
.BR \-ld |
693 |
Boolean switch to limit ray distance. |
694 |
If this option is set, then rays will only be traced as far as the |
695 |
magnitude of each direction vector. |
696 |
Otherwise, vector magnitude is ignored and rays are traced to infinity. |
697 |
.TP |
698 |
.BI -cs \ Ns |
699 |
Use |
700 |
.I Ns |
701 |
bands for spectral sampling rather than the default RGB calculation space. |
702 |
The maximum setting is controlled by the compiler macro MAXCSAMP, and |
703 |
defaults to 24. |
704 |
Larger values for Ns will be reduced to MAXCSAMP. |
705 |
.TP |
706 |
.BI -cw " nmA nmB" |
707 |
Set extrema to the given wavelengths for spectral sampling. |
708 |
The default is 380 and 780 nanometers. |
709 |
The order specified does not matter. |
710 |
.TP |
711 |
.BR \-co |
712 |
Boolean switch turns on spectral data output if selected. |
713 |
The default is to reduce spectral results to RGB, but see the related |
714 |
.I \-p* |
715 |
options, below. |
716 |
.TP |
717 |
.BI -pc " xr yr xg yg xb yb xw yw" |
718 |
Use the specified chromaticity pairs for output primaries and white |
719 |
point rather than the standard RGB color space. |
720 |
.TP |
721 |
.BR \-pRGB |
722 |
Output standard RGB values (the default). |
723 |
.TP |
724 |
.BR \-pXYZ |
725 |
Output standard CIE XYZ tristimulus values rather than RGB. |
726 |
.TP |
727 |
.BR \-pY |
728 |
Produce a single output channel corresponding to photopic luminance. |
729 |
.TP |
730 |
.BR \-pS |
731 |
Produce a single output channel corresponding to scotopic luminance. |
732 |
.TP |
733 |
.BR \-pM |
734 |
Produce a single output channel corresponding to melanopic luminance. |
735 |
.TP |
736 |
.BI -e \ efile |
737 |
Send error messages and progress reports to |
738 |
.I efile |
739 |
instead of the standard error. |
740 |
.TP |
741 |
.BR \-w |
742 |
Boolean switch to suppress warning messages. |
743 |
.TP |
744 |
.BI \-P \ pfile |
745 |
Execute in a persistent mode, using |
746 |
.I pfile |
747 |
as the control file. |
748 |
Persistent execution means that after reaching end-of-file on |
749 |
its input, |
750 |
.I rtrace |
751 |
will fork a child process that will wait for another |
752 |
.I rtrace |
753 |
command with the same |
754 |
.I \-P |
755 |
option to attach to it. |
756 |
(Note that since the rest of the command line options will be those |
757 |
of the original invocation, it is not necessary to give any arguments |
758 |
besides |
759 |
.I \-P |
760 |
for subsequent calls.) |
761 |
Killing the process is achieved with the |
762 |
.I kill(1) |
763 |
command. |
764 |
(The process ID in the first line of |
765 |
.I pfile |
766 |
may be used to identify the waiting |
767 |
.I rtrace |
768 |
process.) |
769 |
This option may be used with the |
770 |
.I \-fr |
771 |
option of |
772 |
.I pinterp(1) |
773 |
to avoid the cost of starting up |
774 |
.I rtrace |
775 |
many times. |
776 |
.TP |
777 |
.BI \-PP \ pfile |
778 |
Execute in continuous-forking persistent mode, using |
779 |
.I pfile |
780 |
781 |
The difference between this option and the |
782 |
.I \-P |
783 |
option described above is the creation of multiple duplicate |
784 |
processes to handle any number of attaches. |
785 |
This provides a simple and reliable mechanism of memory sharing |
786 |
on most multiprocessing platforms, since the |
787 |
.I fork(2) |
788 |
system call will share memory on a copy-on-write basis. |
789 |
.SH NOTES |
790 |
Photons are generally surface bound (an exception are volume photons), thus |
791 |
the ambient irradiance in photon mapping mode will be biased at positions |
792 |
which do not lie on a surface. |
793 |
.SH EXAMPLES |
794 |
To compute radiance values for the rays listed in samples.inp: |
795 |
.IP "" .2i |
796 |
rtrace \-ov scene.oct < samples.inp > radiance.out |
797 |
.PP |
798 |
To compute irradiance values at locations selected with the 't' |
799 |
command of |
800 |
.I ximage(1): |
801 |
.IP "" .2i |
802 |
ximage scene.hdr | rtrace \-h \-x 1 \-i scene.oct | rcalc \-e '$1=47.4*$1+120*$2+11.6*$3' |
803 |
.PP |
804 |
To record the object identifier corresponding to each pixel in an image: |
805 |
.IP "" .2i |
806 |
vwrays \-fd scene.hdr | rtrace \-fda `vwrays \-d scene.hdr` \-os scene.oct |
807 |
.PP |
808 |
To compute an image with an unusual view mapping: |
809 |
.IP "" .2i |
810 |
cnt 480 640 | rcalc \-e 'xr:640;yr:480' \-f unusual_view.cal | rtrace |
811 |
\-x 640 \-y 480 \-fac scene.oct > unusual.hdr |
812 |
.PP |
813 |
To compute ambient irradiance in photon mapping mode from a global photon |
814 |
map global.pm via one ambient bounce, and from a caustic photon map |
815 |
caustic.pm at sensor positions in samples.inp: |
816 |
.IP "" .2i |
817 |
rtrace -h -ov -ab 1 -ap global.pm 50 -ap caustic.pm 50 scene.oct < |
818 |
samples.inp > illum.out |
819 |
.SH ENVIRONMENT |
820 |
RAYPATH the directories to check for auxiliary files. |
821 |
.SH FILES |
822 |
/tmp/rtXXXXXX common header information for picture sequence |
823 |
.SH DIAGNOSTICS |
824 |
If the program terminates from an input related error, the exit status |
825 |
will be 1. |
826 |
A system related error results in an exit status of 2. |
827 |
If the program receives a signal that is caught, it will exit with a status |
828 |
of 3. |
829 |
In each case, an error message will be printed to the standard error, or |
830 |
to the file designated by the |
831 |
.I \-e |
832 |
option. |
833 |
.SH AUTHOR |
834 |
Greg Ward |
835 |
.SH "SEE ALSO" |
836 |
dctimestep(1), getinfo(1), lookamb(1), |
837 |
mkpmap(1), oconv(1), pfilt(1), pinterp(1), |
838 |
pvalue(1), rcalc(1), rcontrib(1), rcrop(1), |
839 |
rmtxcomb(1), rmtxop(1), rsplit(1), |
840 |
rpict(1), rtpict(1), rvu(1), vwrays(1), ximage(1) |
